All, When we try to apply single number reach our ability to transfer calls "soft button" changes to mobility from transfer. How can I setup some type of cell phone forwarding that will not effect others ability to transfer a call? Thanks
Hello, I Have an XML file hosted on a local TFTP server here is the file structure:<?xml version="1.0" encoding="UTF-8"?><CiscoIPPhoneDirectory><Title>Fanvil</Title><Prompt>Infomineo</Prompt><DirectoryEntry><Name>Ahmed LAHLOU</Name><Telephone>804</Te...
Hi, I'm planning to purchase a cisco IP phone SPA525G2, but does anyone know is SPA525G2 work with cme 2911?if not, any suggestion with cisco wireless phone other than 7921 thanks
Hi,I've got the 7940g working with the SPA9000 but I have a problem when calling internal extensions.The problem is that when I end the call the phone stops ringing (if no one picks up) after a long time...What can be done?Thanks
We deployed a UC560 without any issues -- everything working beautifully.IOS 15.1CCA 3.2(3)I realized I still had the default passwords for login/etc.I logged into CCA and updated all the passwords, and added an additional admin account.Everything wa...
I have about 50 of cisco spa509g I didn't know where to post this but I need help with background noise on these, could you please help me to reduce noise ThanksRaphael
Buonasera, sto cercando di cambiare iquello che adesso si visualizza sul display visto che è cambiato il nome dell'azienda!Qualcuno sa come si cambia?Grazie in anticipo.Maurizio
Hi, I just have a quick question if anyone knows if it is possible to have the extended function on a line key for an xml application also function as a BLF at the same time. Or are the two extended functions not compatible on the same line key like ...
we have cisco IP-Phones with Asterisk server. What happens is that one or two phones get unregister and give error of registration failed rest work fine . After factory default setting phone gets work. We have GRE tunnels and on some places without G...
The scenario is that all calls come into SPA 303 PHONE. Calls are then blind transferred to the extensions. The users want to distinguish between internal and external calls.does the spa 3403 phone support this feature if does how do you configure ...
I have been trying to push phone configuration out through the use of a TFTP server. While the phones download their config, they also reboot themselves every two minutes. Nothing changes on the phone, but the phones continuously reboot every time th...
I have a customer with software of CME of 7.1 and would like to upgrade to 8.6.2 what steps are needed?
Hi EveryoneLooking for some opinions... I've been an engineer, salesman etc in 100+ user telecoms for about 10 years now. Lots of traditional stuff with 'good' VoIP (large NEC). I looked at Lync (went on a few engineering courses for 2013) but I am n...
Hello all, I am at the middle of a configuration, I would like to integrate CUCM with UCCX on Cisco BE 6000. I don't know how I will go about it, please if you have any resources I can read to make the integration smooth will be appreciated. Thanks S...
Hi Team, Can someone please look at the attached phone log to work out what the issue is here? Your assistance will be greatly appreciated. Telephony setup:-Cisco U320W Vopi Box/Router with SPA504G handsets. Issue Description:-Keep getting random cal...
