Hi to All!Sorry for my English first! :-)I'm using SPA504G phones with IP-PBX ZyXEL X8004. One-touch buttons is configured as described in manuals: fnc=sd+cp+blf; sub=UserID@$PROXYHere is my problem: when I want to transfer incoming call to other ext...
Hi!I want to delete an orphaned voicemail box from my UC560 in the CLI but not having luck finding the commands. How can I accomplish that? And also how to list the voicemail boxes?
Hi,you can use english or italian, thanks. I have a very easy configuration: adsl > router > SPA122 > phone.My problem is I don't receive call in but always I can phone out.I changed ADSL also, but no results, never.I used solution of this thread:htt...
Hi Howard,Hope you are keeping well, and again I am relieved to see you still supporting this forum.In need of your assistance again, sorry. :-(I was off on holiday recently and I my SPA3102 set to forward PSTN calls to VOIP whilst I was away.When I ...
Dear all!We have a Cisco Linksys Sipura SPA 8000 voip port ip telefone gateway. The voip phone are working fine with it, but i have to connect some old analog phones to the systems. I asking for advice if i am buying the correct signal converted (dig...
My SPA122 reboots when a call to it is received. I get the dial tone, can call out but when I call the number from my mobile, it instantly reboots the ATA.Can anybody suggest how to fix this?
Hello, I tried to configure an NTP server on my SPA112 device to sync the time, but it keeps displaying wrong time. When I configure the NTP server (pool.ntp.org), the time is synced well immediately, but when the device re-registers itself to my voi...
Hello, I am trying to configure a CISCO SPA504G for the first time. I am trying to configure the line keys. In order to see if I could remove them, I disabled Line Key 2/3+4 under the phone tab, I then tried re adding them with $USER under the short ...
Upon the advice here, I just received a used UC520-8U. (I'm having constant problems with a SPA9000/SPA400 with 10 SPA504g phones. So I asked here if the UC500 is reasonable. I bought used on Ebay because a new one is too expensive.)When I powered...
I require some help setting up VOIP with Optus ISP & a Cisco IP Phone SPA504G.
The phone is connected to power. The phone is connected via ethernet cable from "SW" port to ethernet port in modem supplied by ISP, Optus.
The phone does not have a d...
Hello, I want to forward calls received from PSTN (condo buzzer system) to SIP. I used to own an older Linksys SPA adapter which has recently died and I can no longer access its settings, nor find the link to the page I used to set things up. Can som...
Hello,I registered a SPA122 on a SV8100 NEC pbx; the device is correctly registered and can make outgoing calls but it can't receive any calls...The caller receives the busy tone when calls SPA phone number.If I register a CISCO IP...
can someone help me configure my SPA112 so that the caller's light is displayed on my phone.
I have alerady updated my firmware
thanks for the answers
I have several SPA112 units which I have reset and have attempted of access for configuration with no response from the units. The units are receiving a DHCP address as confirm by the router as well as the keypad access which tells the IP address re...
