Fax to email document format
billymobilizer
I got fax to email working on UC500, but the default format for the attached document is .tiff format, is there a way that we can change the attachement file t o.pdf format in CCA ?
6 Replies 6
bkwon
unfortunately, UC500/CUE support TIFF format only and it is the standard of internet fax file format.
paolo bevilacqua
No. For a solution supporting PDF, look for example at:
http://sandlerco.com/XConnector.htm
;-) we are talking about UC500/CUE here right?
My understanding is that it works with any T.37 capable voice gateway.
There are other solutions as well, e.g rightfax/opentext, etc.
Maybe this would be the right product, http://sandlerco.com/t37fsp4cisco.htm
but still, I think Paolo deserves the points for answering the question
I'm about to test it with a customer and my understanding is that T37FSP  bridge doesn't convert to PDF, but the other product does. One should ask Sandler for more info.
