Multiple SPA525G's phones at remote site with UC500
ckent1111
Beginner
Beginner
Is it possible and supported to have multiple SPA525G phones at a remote site of an SBCS UC500 deployment with only a basic DSL modem/ switch and not a full blown security router (ASA, SR520, etc) at the other end?
Alexander Maroukian
Rising star
Rising star
Yes it is supported as these phones connect individually to the UC and are creating their own VPN tunnels.
You may use up to 10 on UC540 and up to 20 on 560.
HTH,
Alex
*Please rate helpful posts
Alexander Maroukian
Rising star
Rising star
HTH,
Alex
Hi There,
just to add further to what Alexandra has already stated, you should also make sure that your router can support VPN passthrough or at the very list VPN ALG's, this way it should work more smoother
Cheers,
David Trad.
**When you rate a persons post, you are indicating a thank you or that it helped, but at the same time you are also helping to maintain the community spirit - You don't have to rate posts and you wont be looked down upon :) **
Cheers, David Trad. **When you rate a persons post, you are indicating a thank you or that it helped, but at the same time you are also helping to maintain the community spirit - You don't have to rate posts and you wont be looked down upon :) *
Recognize Your Peers
