UC540 compatibility with VWIC3 card?
Hello all,
We have a customer using a UC540W-BRI-K9. They will move their office and upgrade their current 2xBRI lines to 1xE1 in order to have 30 channels.
as you may all know, the VWIC2-1MFT-T1/E1= is now EoL/EoS. Will the new model VWIC3-1MFT-T1/E1= be fully supported and compatible with our
UC540W-BRI-K9? It is running
Software version is a bit old though...
Cisco IOS Software, UC500 Software (UC500-ADVIPSERVICESK9-M), Version 15.1(2)T4, RELEASE SOFTWARE (fc1)
Copyright (c) 1986-2011 by Cisco Systems, Inc.
Compiled Tue 12-Jul-11 22:01 by prod_rel_team
ROM: System Bootstrap, Version 12.4(24r)SB, RELEASE SOFTWARE (fc1)
KFL-UC-01 uptime is 26 weeks, 4 days, 14 hours, 11 minutes
System restarted at 22:33:37 CET Thu Jul 12 2012
System image file is "flash:uc500-advipservicesk9-mz.151-2.T4"
Thanks for your advice.
Kevin Monteiro
Level 7
Level 7
Hi Hiromichi,
As per UC540 platform reference guide, VWIC3-1MFT-T1/E1is not supported.
VWIC2-1MFT-T1/E1 is the only supported card.
http://www.cisco.com/c/en/us/products/collateral/unified-communications/unity-express/C78-557768-00_540_platform_reference_guide_DS_v2a.html
Kindly Rate the post accordinly.
Kevin
Kevin Monteiro
Level 7
Level 7
Hi Hiromichi,
Kevin
Thanks Kevin for your prompt answer. Then we will definitely need to go for the VWIC2.
Kind regards
