VPN
Cisco CyberSecurity
Labels
Hi Cisco community, I have an ASA managed via ASDM. ASA version : 9.1.4(4)24, ASDM : 7.19(1)90 we have recently got our identity certificates signed from a CA, got them installed and when we try to create a trustpoint(with the same name as the new ce...
I have recently configured one of the spoke routers in Azure. The configuration is identical to that of other locations spoke router. Each spoke has three hub routers under a single NHS cluster. The traffic between the on-prem hub and the cloud-spoke...
Hello, I have configured a basic L2L tunnel between two FTD's. Site A is using a dynamic assigned public IP address and Site B a static address.  When trying to send traffic from Site A, the tunnel comes up but I get no response from Site B  and "sho...
I have some questions about how Secure Access licenses are counted. I understand that Secure Access licenses are provided as a per-user subscription.For example, I think they will be counted by the number of employees in a company.On a shared device,...
msyk.oym by Level 1
  • 351 Views
  • 2 replies
1- Problem in switching tcp / udp2- After locking the device (iphone & Ipad) the connection is lost and the reconnect enters the loop mode, especially in DTLS3- OnDemand mode exacerbates this issueThis has nothing to do with updated versions of the o...
Hostera by Level 1
  • 1001 Views
  • 3 replies
Hello,I have a quick question for you guys, as I'm not too sure if you can do this. Basically, we are connecting two offices together and need higher bandwidth between the sites over VPN. The main site has a leased line and the remote site has an SDS...
I have and ASA configured for AlwaysON SSL-VPN Certificate Authentication which is working fine but I want to change to computer based Authentication and the change I made is changed connection profile -> Primary field --> changed from  "UPN" to "CN"...
“In Cisco FMC, under Analysis > Connections > Events, no logs appear for Remote Access VPN (SSL VPN) sessions. All hit counts for users connected via Remote Access VPN show ‘0’. However, when I create a rule for Remote Access VPN under the policy sec...
tanri04 by Level 1
  • 366 Views
  • 1 replies
HI Team,Zscaler cloud and Cisco FTD (7.2.2) are connected via an IPsec connection. Establishing an IPSec tunnel with Phase 1 and Phase 2.We test the communication; data is sent to the tunnel and received by Zscaler as well. Zscaler was unable to view...
