Wireless - Small Business
Stay connected on-the-go with our Wireless solutions, designed for small businesses to boost productivity.
Don't miss this Cisco Catalyst 8000 offer
ラベル
フォーラム投稿
Hello!   This sticky-post will serve as a sign-post for incoming community members. Below you will find links to pages that you may find helpful.    Virtual Assistant- Discover support content and options for your gearSupport page index - Contains a ...
CoreyP319 投稿者 Cisco Employee
  • 3156 閲覧回数
  • 1 返信
  • 5 いいね!
There are 5 Access Points WAP150 connected to PoE switch Cisco SG 350-10P and SG-110-24, there is ISP Internet Router giving speed around 70mbps over fiber, the case that the speed on data ports giving around 70mbps speed but on wireless access point...
Ok, so I have a set up of eight WAP 371 in single point setup, and four different wireless networks configured in each radio (4 in 2.4GHZ and 4 in 5GHZ). Problem is that after a few hours of work devices stop connecting to the AP's. If the radio is d...
luchonat1 投稿者 Level 1
  • 1483 閲覧回数
  • 2 返信
  • 0 いいね!
Hi Everyone,  Please Suggest us suitable WIFI Extender to Use with Aironet 1850 Series.  This is for Big Palace where we have multiple WIFI Access point which has Same WIFI Signal. For Few Rooms we Have less WIFI Coverage so Planning to add WIFI Exte...
Hi,   I have some trouble to cluster three WAP371 APs.    All three are up-to-date with the firmware 1.3.0.6. But when check the PID VID, one Access Point has a different one: Two are WAP371-E-K9 V03 and one is WAP371-E-K9 V02. I can cluster the two ...
ErenK 投稿者 Level 1
  • 1688 閲覧回数
  • 3 返信
  • 0 いいね!
Our network is mainly cisco devices with the exception of the Firewall The structure basically a MDF, IDF2 and IDF3. IDF2 and IDF3 connect to MDF by fiber independently. IDF2 has two switch (1x SG200-26P and 1x SF300-48P), three WAP581 connect to thi...
I just purchased 4 WAP571 APs to use as a cluster, 3 of them are working great, when the 4th is joined to the cluster any client that connects to it is unable to get a IP address from the DHCP server.  If I reconfigure this AP to not be part of the c...
dlcole0708 投稿者 Level 1
  • 1536 閲覧回数
  • 5 返信
  • 0 いいね!
Hi,I hope someone can help I've been struggling to find an answer to this.We Bought 3x WAP551's recently but are having nothing but hassle with them. Half our devices won't connect or show low/weak signal even when only sat a few meters away. Other d...
parvalux1 投稿者 Level 1
  • 6322 閲覧回数
  • 10 返信
  • 0 いいね!
The website for the WAP125 lists the latest release as 1.0.0.7Hitting the link for All Releases shows 1.0.0.7 as the latest release. However if you expand the 1.0 release section you see 1.0.1.5 listed from 30-Jul-2018 which is newer than 1.0.0.7 05-...
I just upgraded 7 WAP571s to the new firmware from 1.0.2.6. While it works, I did notice some problems. I list them below. 1) Administration   a) Time      i) Set for UTC-06:00 USA (Central)     ii) Current Time display shows 5 hours ahead (current U...
comprev 投稿者 Level 1
  • 1608 閲覧回数
  • 3 返信
  • 0 いいね!
I have setup  Cisco Aironet 1815i with Cisco wireless app for provisioning then I can connect to SSID normally, But can't access to mobility express, I try to connect with ssh with DHCP IP of AP  (I don't know why this IP difference with IP Managemen...
wannachai.sa 投稿者 Level 1
  • 1229 閲覧回数
  • 1 返信
  • 0 いいね!
