9166I-ROW not joing 9800 (Country Code -IN )
Sanju_13
Hi all,
I am from india.I am facing issue in AP 9166I-ROW-6E model ap not joining to C9800 WLC (Country Code - IN)
I want to know that is this AP  supported in India ?
If not should i change the WLC country code to US. it is fine with Cisco regulatory ?
Hi @Sanju_13
  If we check at https://www.wi-fi.org/countries-enabling-wi-fi-in-6-ghz-wi-fi-6e India is not a "Countries Enabling Wi-Fi in 6 GHz" yet.
  If you enable Country Code on the WLC for another Country it  must work but you be aware that this can cause you problem with local regulation in case you interfere with some proprietary system.
7 Replies 7
Leo Laohoo
What firmware is the WLC on?
Cupertino 17.9.3
Console into the AP and reboot.
Post the entire boot-up process.
Hi @Sanju_13
Hi Flavio,
Thanks for info ..
Rich R
The place to check is https://www.cisco.com/c/dam/assets/prod/wireless/wireless-compliance-tool/index.html
The AP is supported in India - but that does not mean you will be able to use 6GHz though.
For that you need to check the config guide for the release you're using:
https://www.cisco.com/c/en/us/td/docs/wireless/controller/9800/17-9/config-guide/b_wl_17_9_cg/regulatory_domain_reduction.html#Cisco_Concept.dita_6519730d-d802-4a7f-b6a9-4ca15f109ec7
As you can see - India is not listed there (and isn't there in 17.11 or 17.12 either). So ...
YES, but no 6GHz radio allowed.
No that would be illegal and definitely not sanctioned by Cisco - in fact it would be unsupported.
You need to work out why it's not working and fix that.  Like Leo already said:
Attach the output here as a text file.
bottom line is the AP should link and support 2g and 5g functions.
