Cisco 3702i Autonomous and 5GHz
Em87
Hi All,
I have a 3702i AP and I cannot get wireless clients to connect to the 5GHz channel no matter what I do. I read a couple postings back in 2014 and 2015 and someone said the autonomous software is for site survey only which means 5GHz cannot be used in site survey. Can someone please confirm that this is still true? I have a fairly recent autonomous ios image (ap3g2-k9w7-xx.153-3.JF) but still cannot get 5GHz to work and was wondering if this is the reason behind it. I've also read another post where was user was able to get the 5GHz to work by changing the channel width to 80 and the channel to 5825. I've tried doing that but does not work for me. Can someone please help?
https://community.cisco.com/t5/wireless-and-mobility/3702i-autonomous-cannot-enable-gt-20mhz-channels/td-p/2995000
Em
3 Accepted Solutions
It should work fine.
Please make these changes and try again:
interface Dot11Radio1
no ip address
encryption mode ciphers aes-ccm
ssid A
antenna gain 0
peakdetect
dfs band 1 2 4 block
dfs band 3 block
stbc
speed basic-6.0 basic-9.0 basic-12.0 basic-18.0 basic-24.0 basic-36.0 basic-48.0 basic-54.0 m0. m1. m2. m3. m4. m5. m6. m7. m8. m9. m10. m11. m12. m13. m14. m15. m16. m17. m18. m19. m20. m21. m22. m23. a1ss9 a2ss8 a3ss9
channel width 80
channel dfs
station-role root
Dont forget to rate helpful posts
config t
channel width 20
-Scott
Just for testing, rename the SSID on the 5 GHz to another name, for example B. That way you can much easier test.
Also try to manually configure the channel to 36, in case your clients aren't DFS capable.
I think that command is:
config t
channel 36
end
Btw. your software is quite old, I suggest you also do an upgrade. There were some security updates since your release.
14 Replies 14
Jurgens L
Level 3
Level 3
Can you send us the configuration of the AP?
You should be able to use the 5GHz with the autonomous image.
Here is my config:
! Last configuration change at 17:14:00 -0700 Wed Apr 21 1993
version 15.3
no service pad
service password-encryption
hostname AP1
logging rate-limit console 9
enable secret 5
no aaa new-model
clock timezone -0800 -8 0
clock summer-time -0700 recurring
no ip source-route
no ip cef
ip domain name .com
ip name-server 8.8.8.8
ip name-server 8.8.4.4
dot11 pause-time 100
dot11 syslog
dot11 ssid A
authentication open
authentication key-management wpa version 2
guest-mode
wpa-psk ascii 7
no ipv6 cef
username administrator privilege 15 password 7
bridge irb
interface Dot11Radio0
no ip address
ssid A
antenna gain 0
stbc
speed basic-1.0 basic-2.0 basic-5.5 basic-11.0 basic-6.0 basic-9.0 basic-12.0 basic-18.0 basic-24.0 basic-36.0 basic-48.0 basic-54.0 m0. m1. m2. m3. m4. m5. m6. m7. m8. m9. m10. m11. m12. m13. m14. m15. m16. m17. m18. m19. m20. m21.
m22. m23.
station-role root
world-mode dot11d country-code US both
bridge-group 1
bridge-group 1 subscriber-loop-control
bridge-group 1 spanning-disabled
bridge-group 1 block-unknown-source
no bridge-group 1 source-learning
no bridge-group 1 unicast-flooding
no ip address
ssid A
antenna gain 0
peakdetect
stbc
channel width 80
channel dfs
station-role root
bridge-group 1
interface GigabitEthernet0
no ip address
duplex auto
speed auto
bridge-group 1
interface BVI1
mac-address 54a2.740d.920c
ip address 192.168.1.254 255.255.255.0
ipv6 address dhcp
ipv6 address autoconfig
ip forward-protocol nd
ip http server
no ip http secure-server
ip http help-path http://www.cisco.com/warp/public/779/smbiz/prodconfig/help/eag
ip ssh version 1
bridge 1 route ip
line con 0
line vty 0 4
login local
length 0
transport input all
sntp server time.nist.gov
end
Thanks!
1. Yes 5 GHz should work fine.
2. At a glance your config looks fine.
Can you provide output from:
sh int dot11Radio 1
sh controllers dot11Radio 1
Are there any event files on the flash? If so what do they show?
Any errors in "show log"?
Here are the Int and controllers output for dot11 radio 1 and the flash dir. There are a lot of event it the log but I don't see any errors. Are there anything I should be looking for in the log? Thank you all for your help!
AP1#show int dot11 1
Dot11Radio1 is up, line protocol is up
Hardware is 802.11AC 5GHz Radio, address is 54a2.7412.28f0 (bia 54a2.7412.28f0 )
MTU 1500 bytes, BW 54000 Kbit/sec, DLY 1000 usec,
Keepalive set (10 sec)
Last input 00:36:11, output 00:00:00, output hang never
Input queue: 0/42878/146/0 (size/max/drops/flushes); Total output drops: 12875 255
Queueing strategy: fifo
Output queue: 0/30 (size/max)
88794406 packets input, 3435114449 bytes, 0 no buffer
Received 453849 broadcasts (0 IP multicasts)
90868672 packets output, 1095420330 bytes, 0 underruns
2007 output errors, 0 collisions, 11 interface resets
0 unknown protocol drops
0 lost carrier, 0 no carrier
AP1#
AP1#sh controllers dot11 1
Radio BR 5GHz, Base Address 54a2.7412.28f0, BBlock version 0.00, Software version 4.18.2
Serial number: FOC1916198P
Unused dynamic SQRAM memory: 0x0001F3A8 (124 KB)
Unused dynamic SDRAM memory: 0x00318C08 (3171 KB)
Spectrum FW version: 1.15.4
Number of supported simultaneous BSSID on Dot11Radio1: 16
Carrier Set: Americas (OFDM) (US) (-A)
Uniform Spreading Required: Yes
Configured Frequency: 5560 MHz Channel 112 80MHz (DFS enabled)
Serving Frequency: 5560 MHz Channel 112 80MHz
Allowed Frequencies: * Dynamic Frequency Selection (DFS) only
5180( 36) 5200( 40) 5220( 44) 5240( 48) *5260( 52) *5280( 56) *5300( 60) *5320( 64) *5500(100) *5520(104)
*5540(108) *5560(112) *5580(116) *5660(132) *5680(136) *5700(140) 5745(149) 5765(153) 5785(157) 5805(161)
5825(165)
Listen Frequencies:
5180( 36) 5200( 40) 5220( 44) 5240( 48) 5260( 52) 5280( 56) 5300( 60) 5320( 64) 5500(100) 5520(104)
5540(108) 5560(112) 5580(116) 5600(120) 5620(124) 5640(128) 5660(132) 5680(136) 5700(140) 5720(144)
5745(149) 5765(153) 5785(157) 5805(161) 5825(165)
DFS Blocked Frequencies: none
Beacon Flags: 0, Interface Flags 20105, Interface Events 0, Mode 9; Beacons are enabled; Probes are enabled
Configured TxPower: 17 dBm (Level Index 1)
Allowed Power Levels: 17 14 11 8 5 2 dBm
Allowed Client Power Levels: 17 14 11 8 5 2 dBm
Antenna: Rx[a b c d ]
Tx[a b c d ofdm all]
External
Gain [Allowed 12, In Use 12] (dBi x 2), In Use 12] (dBi x 2), In Use 12] (dBi x 2), In Use 12] (dBi x 2), Reported 0, Configured 0, In Use 12] (dBi x 2)
Active Rates: basic-6.0 basic-9.0 basic-12.0 basic-18.0 basic-24.0 basic-36.0 basic-48.0 basic-54.0 m0-4 m1-4 m2-4 m3-4 m4-4 m5-4 m6-4 m7-4 m8-4 m9-4 m10-4 m11-4 m12-4 m13-4 m14-4 m15-4 m16-4 m17-4 m18-4 m19-4 m20-4 m21-4 m22-4 m23-4 a0.1-8 a1.1-8 a2.1-8 a3.1-8 a4.1-8 a5.1-8 a6.1-8 a7.1-8 a8.1-8 a9.1-8 a0.2-8 a1.2-8 a2.2-8 a3.2-8 a4.2-8 a5.2-8 a6.2-8 a7.2-8 a8.2-8 a0.3-8 a1.3-8 a2.3-8 a3.3-8 a4.3-8 a5.3-8 a6.3-4 a7.3-8 a8.3-8 a9.3-8
Current Rates: basic-6.0 basic-9.0 basic-12.0 basic-18.0 basic-24.0 basic-36.0 basic-48.0 basic-54.0 m0-4 m1-4 m2-4 m3-4 m4-4 m5-4 m6-4 m7-4 m8-4 m9-4 m10-4 m11-4 m12-4 m13-4 m14-4 m15-4 m16-4 m17-4 m18-4 m19-4 m20-4 m21-4 m22-4 m23-4 a0.1-8 a1.1-8 a2.1-8 a3.1-8 a4.1-8 a5.1-8 a6.1-8 a7.1-8 a8.1-8 a9.1-8 a0.2-8 a1.2-8 a2.2-8 a3.2-8 a4.2-8 a5.2-8 a6.2-8 a7.2-8 a8.2-8 a0.3-8 a1.3-8 a2.3-8 a3.3-8 a4.3-8 a5.3-8 a6.3-4 a7.3-8 a8.3-8 a9.3-8
Allowed Rates: 6.0 9.0 12.0 18.0 24.0 36.0 48.0 54.0
All Rates: 6.0 9.0 12.0 18.0 24.0 36.0 48.0 54.0 m0-4 m1-4 m2-4 m3-4 m4-4 m5-4 m6-4 m7-4 m8-4 m9-4 m10-4 m11-4 m12-4 m13-4 m14-4 m15-4 m16-4 m17-4 m18-4 m19-4 m20-4 m21-4 m22-4 m23-4 a0.1-8 a1.1-8 a2.1-8 a3.1-8 a4.1-8 a5.1-8 a6.1-8 a7.1-8 a8.1-8 a9.1-8 a0.2-8 a1.2-8 a2.2-8 a3.2-8 a4.2-8 a5.2-8 a6.2-8 a7.2-8 a8.2-8 a9.2-8 a0.3-8 a1.3-8 a2.3-8 a3.3-8 a4.3-8 a5.3-8 a6.3-4 a7.3-8 a8.3-8 a9.3-8
Default Rates: basic-6.0 9.0 basic-12.0 18.0 basic-24.0 36.0 48.0 54.0 m0-4 m1-4 m2-4 m3-4 m4-4 m5-4 m6-4 m7-4 m8-4 m9-4 m10-4 m11-4 m12-4 m13-4 m14-4 m15-4 m16-4 m17-4 m18-4 m19-4 m20-4 m21-4 m22-4 m23-4 a0.1-8 a1.1-8 a2.1-8 a3.1-8 a4.1-8 a5.1-8 a6.1-8 a7.1-8 a8.1-8 a9.1-8 a0.2-8 a1.2-8 a2.2-8 a3.2-8 a4.2-8 a5.2-8 a6.2-8 a7.2-8 a8.2-8 a9.2-8 a0.3-8 a1.3-8 a2.3-8 a3.3-8 a4.3-8 a5.3-8 a6.3-4 a7.3-8 a8.3-8 a9.3-8
Best Range Rates: basic-6.0 9.0 12.0 18.0 24.0 36.0 48.0 54.0 m0-4 m1-4 m2-4 m3-4 m4-4 m5-4 m6-4 m7-4 m8-4 m9-4 m10-4 m11-4 m12-4 m13-4 m14-4 m15-4 m16-4 m17-4 m18-4 m19-4 m20-4 m21-4 m22-4 m23-4 a0.1-8 a1.1-8 a2.1-8 a3.1-8 a4.1-8 a5.1-8 a6.1-8 a7.1-8 a8.1-8 a9.1-8 a0.2-8 a1.2-8 a2.2-8 a3.2-8 a4.2-8 a5.2-8 a6.2-8 a7.2-8 a8.2-8 a9.2-8 a0.3-8 a1.3-8 a2.3-8 a3.3-8 a4.3-8 a5.3-8 a6.3-4 a7.3-8 a8.3-8 a9.3-8
Best Throughput Rates: basic-6.0 basic-9.0 basic-12.0 basic-18.0 basic-24.0 basic-36.0 basic-48.0 basic-54.0 m0-4 m1-4 m2-4 m3-4 m4-4 m5-4 m6-4 m7-4 m8-4 m9-4 m10-4 m11-4 m12-4 m13-4 m14-4 m15-4 m16-4 m17-4 m18-4 m19-4 m20-4 m21-4 m22-4 m23-4 a0.1-8 a1.1-8 a2.1-8 a3.1-8 a4.1-8 a5.1-8 a6.1-8 a7.1-8 a8.1-8 a9.1-8 a0.2-8 a1.2-8 a2.2-8 a3.2-8 a4.2-8 a5.2-8 a6.2-8 a7.2-8 a8.2-8 a9.2-8 a0.3-8 a1.3-8 a2.3-8 a3.3-8 a4.3-8 a5.3-8 a6.3-4 a7.3-8 a8.3-8 a9.3-8
Current Voice Rates: basic-6.0 basic-12.0 basic-24.0 [disabled until voice packet-discard enabled]
Default Voice Rates: basic-6.0 basic-12.0 basic-24.0
Active Voice Rates: basic-6.0 basic-9.0 basic-12.0
Managment Rates: basic-6.0
Multicast Rates: basic-6.0 basic-9.0 basic-12.0 basic-18.0 basic-24.0 basic-36.0 basic-48.0 basic-54.0
Multicast Active rate: 54.0
RTS Rates: basic-6.0 basic-9.0 basic-12.0 basic-18.0 basic-24.0 basic-36.0 basic-48.0 basic-54.0
RTS Active rate 54.0
RTS Max rate 54.0
Local Packet Rate Probing is disabled : Packet Size 20
Data Rate Sensitivity (rate, SNR dB, Contention dBm)
( 6.0, 15, -89) ( 9.0, 16, -88) (12.0, 18, -88) (18.0, 19, -86)
(24.0, 20, -85) (36.0, 24, -81) (48.0, 27, -78) (54.0, 31, -77)
CVBF: Enabled in IOS, radio FW bfmr flags 0x0 (enabled)
TX A-MPDU Priority: 0x31 A-MSDU Priority 0x3F
Data padding: disabled ; Size - 0
RIFS 0
Guard-Interval: Any
HT protection: HT (no protection).
Neighbors with non-HT members:
Number of MFP Indices: 10
Driver tx timeout:60
QOS Tag Status: disabled
AuthIEEnabled DS: 0
AuthEnabled reg: 0
RFID Tag Detection: Disabled
Multicast Address filtered:
Packet type filtered:
00 0C rm_scn
Probe limit: active off, filter on, count 0, time 0
Assoc limit: active off, count 0, time 0
GAS Req limit: active off, count 0, time 0
Radio Management (RM) Configuration: Regular 0x9, Mode 1, Disabled
ELM Disabled, Host State:Off Promiscuous Mode dwelling 0 %
MCST RSCs: [0]0x0 [1]0x0 [2]0x0 [3]0x0 [4]0x0 [5]0x0 [6]0x0 [7]0x0 [8]0x0
TKIP **bleep** Stats: STA MIC-L-Errs MIC-R-Errs Replay C-Measure
0000.0000.0000 00000000 00000000 00000000 00000000
AES-CCMP **bleep** Stats: 00000146 replays discarded
Channel Utilization Extensions: Disabled
SMPS Mode: Enabled
QBSS Load: 0xF Tx 0 Rx 0 AP 0
EDCA Turbo Off Thresholds 60 10 4, Policing Stats: Rx downgrades 0, Tx downgrades 0
Classifier Stats tx_on_up6 0, tx_on_up4 0
Configured Local Access Class Parameters
Back : cw-min 4 cw-max 10 fixed-slot 7 admission-control Off txop 0
Best : cw-min 4 cw-max 6 fixed-slot 3 admission-control Off txop 0
Video : cw-min 3 cw-max 4 fixed-slot 1 admission-control Off txop 3008
Voice : cw-min 2 cw-max 3 fixed-slot 1 admission-control Off txop 1504
Configured Local Custom Access Class Parameters
Best : cw-min 1 cw-max 2 fixed-slot 1 admission-control Off txop 0
Configured Cell Access Class Parameters
Best : cw-min 4 cw-max 10 fixed-slot 3 admission-control Off txop 0
Video : cw-min 3 cw-max 4 fixed-slot 2 admission-control Off txop 3008
Voice : cw-min 2 cw-max 3 fixed-slot 2 admission-control Off txop 1504
SIP stats sip_udp_rx_pkt 0, sip_tcp_rx_pkt 0,downlink classified_pkt 0,uplink classified_pkt 0,num_processed_SIP_Calls 0
BA Info: Lost List Count: 0 Head:0
Off Channel Rdy 0 Done 0 0 7
Transmit queues: Limit 27839 Current 0 In-Progress 0 ACQ inserts 175572622 deletes 175572622 reins 6
---- Active ------ In-Progress --------------- Counts --------------
Cnt Quo Bas Max Cl Cnt Quo Bas Sent Discard Fail Retry Multi
Uplink 0 64 0 0 0 0 5 0 0 0 0 0 0
Voice 0 512 0 0 0 0 60 0 69716 0 1319 23605 20824
Video 0 1024 0 0 0 0 400 0 0 0 0 0 0
Best 0 1024 0 0 0 0 400 0 80430026 763 691 79242013885516
MC0 0 0 0 0 0 0 50 0 10328587 20199 0 0 0
Back 0 128 0 0 0 0 35 0 0 0 0 0 0
BSSIDS Index Flags State Next Held Defer NonDefer Clients Tsf Dtim Txq Vlan
28F0 0 00 0 0 0 0 0 0 0 2 0e 8F19B04
Driver TX blocks: Realign - 0
Off Channel Stats: Last Duration 0, Errors: Timeouts 0 Tx 0 Intr 0
---Clients 0 AID VLAN Status:S/I/B/A Age TxQ-R(A) Mode Enc Key Rate Mask Tx Rx BVI Split-ACL Client-ACL WebAuth-ACL L2-ACL
RxPkts KBytes Dup Dec Mic Txc TxPkts KBytes Retry RSSI SNR Fail BAfail
(Client) MaxPri DefUniPri DefMultPri WiredProt
IP Address Pauses Idle RateTx RateDataTx RSC SGT
MVL Req=0, In=0
Video Report: Cnt Rate Retries/Tot
8021x auth in prog 0 allowed 0
AID Hold list
radio vap id mac ssid state
1 0 54:A2:74:12:28:F0 54:A2:74:12:28:F0 54:A2:74:12:28:F0 54:A2:74:12:28:F0 54:A2:74:12:28:F0 54:A2:74:12:28:F0 54:A2:74:12:28:F0 54:A2:74:12:28:F0 54:A2:74:12:28:F0 54:A2:74:12:28:F0 54:A2:74:12:28:F0 54:A2:74:12:28:F0 54:A2:74:12:28:F0 54:A2:74:12:28:F0 54:A2:74:12:28:F0 54:A2:74:12:28:F0 54:A2:74:12:28:F0 A UP
Vlan BSSID Clients PSP Pri/U/M HT Flags/Encr Key0 Key1 Key2 Key3 iGTK SSIDs MFP
0n 28F0 0 0 0 0 0 0 12 214214 1 x128 DIS
vap id ssid Bridging Type
0 A CAPWAP-Tunneled
Packet Tx (in radio) Metrics
Max Stuck time: Normal 0 MC 0 Off Channel 0
Stuck Cnt Normal MC Off Channel
Paks > 30 Secs 0 0 0
Paks > 20 Secs 0 0 0
Paks > 15 Secs 0
Paks > 10 Secs 0 0 0
Paks > 5 Secs 0
Paks > 1 Secs 0 0 0
0 0 flags 3 match 27
Protocol A2B2
Radio MAC SoC ID: 70, Rev: 4
Data Offsets: 82 76, 0 - 218265, 2 - 470962, 4 - 40174, 6 - 144555849, 8 - 190058, 10 - 470945, 12 - 45390, 14 - 470588, 16 - 143076, 18 - 470715, 20 - 43415, 22 - 472063, 24 - 293256, 26 - 471747, 28 - 42765, 30 - 471167, 32 - 223353, 34 - 471490, 36 - 44256, 38 - 470600, 40 - 134165, 42 - 470892, 44 - 43145, 46 - 471146, 48 - 303890, 50 - 472772, 52 - 43536, 54 - 472544, 56 - 224089, 58 - 470885, 60 - 44819, 62 - 469859, 64 - 217133, 66 - 471178, 68 - 42322, 70 - 472838, 72 - 136883, 74 - 471731, 76 - 43161, 78 - 470371, 80 - 128273, 82 - 471112, 84 - 45045, 86 - 472118, 88 - 211365, 90 - 470744, 92 - 43182, 94 - 471067, 96 - 218282, 98 - 471214, 100 - 46405, 102 - 470715, 104 - 299069, 106 - 471952, 108 - 45187, 110 - 471771, 112 - 462333, 114 - 472095, 116 - 41577, 118 - 472308, 120 - 139985, 122 - 470912, 124 - 41140, 126 - 471585
3F31AFF8 00000005 00000006
00000000 00040000 002B0000 00000000 FFFFFFFF
00000000 003FE000 00000000 FFFFFFFF 298397233 116
Tx rdy 1F31BD44 (1F31B3AC - 1F31D15C) Cnt 109180007
1F31B3AC: 3E319006 102 3E710586 FF82 3E4AF686 102 3E4EA986 102 3E507886 102 3E584086 102 3E396D06 102 3E579406 102
1F31B3EC: 3E345686 102 3E6A7606 102 3E6A6086 102 3E6B9886 102 3E582006 102 3E3EB986 102 3E50D986 102 3E39AD86 102
1F31B42C: 3E319006 102 3E4AF686 102 3E4EA986 102 3E507886 102 3E584086 102 3E396D06 102 3E579406 102 3E345686 102
1F31B46C: 3E6A7606 102 3E6A6086 102 3E6B9886 102 3E582006 102 3E3EB986 102 3E50D986 102 3E39AD86 102 3E319006 102
1F31B4AC: 3E4AF686 102 3E4EA986 102 3E507886 102 3E584086 102 3E396D06 102 3E579406 102 3E345686 102 3E6A7606 102
1F31B4EC: 3E6A6086 102 3E6B9886 102 3E582006 102 3E3EB986 102 3E50D986 102 3E39AD86 102 3E319006 102 380198E8 FF82
1F31B52C: 3E4AF686 102 3E4EA986 102 3E507886 102 3E584086 102 3E396D06 102 3E579406 102 3E345686 102 3E6A7606 102
1F31B56C: 3E6A6086 102 3E6B9886 102 3E582006 102 3E3EB986 102 3E50D986 102 3E39AD86 102 3E319006 102 3E4AF686 102
1F31B5AC: 3E4EA986 102 3E507886 102 3E584086 102 3E396D06 102 3E579406 102 3E345686 102 3E6A7606 102 3E6A6086 102
1F31B5EC: 3E6B9886 102 3E582006 102 3E3EB986 102 3E50D986 102 3E39AD86 102 3E319006 102 3E4AF686 102 3E4EA986 102
1F31B62C: 3E507886 102 3E584086 102 3E396D06 102 3E579406 102 3E345686 102 3E6A7606 102 3E6A6086 102 3E6B9886 102
1F31B66C: 3E582006 102 3E3EB986 102 3E50D986 102 3E39AD86 102 3E319006 102 3E4AF686 102 3E4EA986 102 3E507886 102
1F31B6AC: 3E584086 102 3E396D06 102 3E579406 102 3E345686 102 3E6A7606 102 3E6A6086 102 3E6B9886 102 3E582006 102
1F31B6EC: 3E3EB986 102 3E50D986 102 3E39AD86 102 3E319006 102 3E4AF686 102 3E4EA986 102 3E507886 102 3E584086 102
1F31B72C: 3E396D06 102 3E579406 102 3E345686 102 3E6A7606 102 3E6A6086 102 3E6B9886 102 3E582006 102 3E3EB986 102
1F31B76C: 3E50D986 102 3E39AD86 102 3E319006 102 3E4AF686 102 3E4EA986 102 3E507886 102 3E584086 102 3E396D06 102
1F31B7AC: 3E579406 102 3E345686 102 3E6A7606 102 3E6A6086 102 3E6B9886 102 3E582006 102 3E3EB986 102 3E50D986 102
1F31B7EC: 3E39AD86 102 3E319006 102 3E4AF686 102 3E4EA986 102 3E507886 102 3E584086 102 3E396D06 102 3E579406 102
1F31B82C: 3E345686 102 3E6A7606 102 3E6A6086 102 3E6B9886 102 3E582006 102 3E3EB986 102 3E50D986 102 3E39AD86 102
1F31B86C: 3E319006 102 3E7ABC06 FF82 3E4AF686 102 3E4EA986 102 3E507886 102 3E584086 102 3E396D06 102 3E579406 102
1F31B8AC: 3E345686 102 3E6A7606 102 3E6A6086 102 3E6B9886 102 3E582006 102 3E3EB986 102 3E50D986 102 3E39AD86 102
1F31B8EC: 3E319006 102 3E4AF686 102 3E4EA986 102 3E507886 102 3E584086 102 3E396D06 102 3E579406 102 3E345686 102
1F31B92C: 3E6A7606 102 3E6A6086 102 3E6B9886 102 3E582006 102 3E3EB986 102 3E50D986 102 3E39AD86 102 3E319006 102
1F31B96C: 3E48F1DA FF82 3E4AF686 102 3E4EA986 102 3E507886 102 3E584086 102 3E396D06 102 3E579406 102 3E345686 102
1F31B9AC: 3E6A7606 102 3E6A6086 102 3E6B9886 102 3E582006 102 3E3EB986 102 3E50D986 102 3E39AD86 102 3E319006 102
1F31B9EC: 3E4AF686 102 3E4EA986 102 3E507886 102 3E584086 102 3E396D06 102 3E579406 102 3E345686 102 3E6A7606 102
1F31BA2C: 3E6A6086 102 3E6B9886 102 3E582006 102 3E3EB986 102 3E50D986 102 3E39AD86 102 3E319006 102 3E7C4A86 FF82
1F31BA6C: 3E3BC806 FF82 3E4AF686 102 3E4EA986 102 3E507886 102 3E584086 102 3E396D06 102 3E579406 102 3E345686 102
1F31BAAC: 3E6A7606 102 3E6A6086 102 3E6B9886 102 3E582006 102 3E3EB986 102 3E50D986 102 3E39AD86 102 3E319006 102
1F31BAEC: 3E4AF686 102 3E4EA986 102 3E507886 102 3E584086 102 3E396D06 102 3E579406 102 3E345686 102 3E6A7606 102
1F31BB2C: 3E6A6086 102 3E6B9886 102 3E582006 102 3E3EB986 102 3E50D986 102 3E39AD86 102 3E319006 102 3E4AF686 102
1F31BB6C: 3E4EA986 102 3E507886 102 3E584086 102 3E396D06 102 3E579406 102 3E345686 102 3E6A7606 102 3E6A6086 102
1F31BBAC: 3E6B9886 102 3E582006 102 3E3EB986 102 3E50D986 102 3E39AD86 102 3E319006 102 3E4AF686 102 3E4EA986 102
1F31BBEC: 3E507886 102 3E584086 102 3E396D06 102 3E579406 102 3E345686 102 3E6A7606 102 3E6A6086 102 3E6B9886 102
1F31BC2C: 3E582006 102 3E3EB986 102 3E50D986 102 3E39AD86 102 3E319006 102 3E4AF686 102 3E4EA986 102 3E507886 102
1F31BC6C: 3E584086 102 3E396D06 102 3E579406 102 3E345686 102 3E6A7606 102 3E6A6086 102 3E6B9886 102 3E582006 102
1F31BCAC: 3E3EB986 102 3E50D986 102 3E39AD86 102 3E319006 102 3E4EA986 102 3E507886 102 3E584086 102 3E396D06 102
1F31BCEC: 3E579406 102 3E345686 102 3E6A7606 102 3E6A6086 102 3E6B9886 102 3E582006 102 3E3EB986 102 3E50D986 102
1F31BD2C: 3E39AD86 102 3E319006 102 38016938 1F1 0 102 3E3F3B06 102 3E69BEF6 FF82 3E317A86 102 3E317A86 102
1F31BD6C: 3E317A86 102 3E43DB06 102 3E43DB06 102 3E43DB06 102 3E43DB06 102 3E4B5786 102 3E4B5786 102 3E4B5786 102
1F31BDAC: 3E4B5786 102 3E402786 102 3E402786 102 3E402786 102 3E6AAB86 102 3E6AAB86 102 3E6AAB86 102 3E6AAB86 102
1F31BDEC: 3E347706 102 3E38AB86 102 3E475886 102 3E347706 102 3E347706 102 3E38AB86 102 3E475886 102 3E50CF06 102
1F31BE2C: 3E734A86 102 3E4CDB06 102 3E38AB86 102 3E38AB86 102 3E475886 102 3E50CF06 102 3E734A86 102 3E4CDB06 102
1F31BE6C: 3E475886 102 3E475886 102 3E50CF06 102 3E734A86 102 3E4CDB06 102 3E50CF06 102 3E50CF06 102 3E734A86 102
1F31BEAC: 3E4CDB06 102 3E734A86 102 3E734A86 102 3E4CDB06 102 3E4CDB06 102 3E4CDB06 102 3E67FA86 102 3E67FA86 102
1F31BEEC: 3E67FA86 102 3E783606 102 3E783606 102 3E783606 102 3E783606 102 3E49DE86 102 3E49DE86 102 3E49DE86 102
1F31BF2C: 3E49DE86 102 3E7BF486 102 3E7BF486 102 3E7BF486 102 3E316506 102 3E681006 102 3E316506 102 3E316506 102
1F31BF6C: 3E681006 102 3E681006 102 3E681006 102 3E681006 102 3E439A86 102 3E439A86 102 3E439A86 102 3E439A86 102
1F31BFAC: 3E46AC86 102 3E46AC86 102 3E46AC86 102 3E46AC86 102 3E706E86 102 3E3C5E86 102 3E706E86 102 3E706E86 102
1F31BFEC: 3E706E86 102 3E706E86 102 3E3C5E86 102 3E4AF686 102 3E4EA986 102 3E507886 102 3E584086 102 3E396D06 102
1F31C02C: 3E3C5E86 102 3E3C5E86 102 3E3C5E86 102 3E3C5E86 102 3E3C5E86 102 3E3C5E86 102 3E3C5E86 102 3E3C5E86 102
1F31C06C: 3E3C5E86 102 3E3C5E86 102 3E3C5E86 102 3E3C5E86 102 3E3C5E86 102 3E3C5E86 102 3E3C5E86 102 3E3C5E86 102
1F31C0AC: 3E3C5E86 102 3E4AF686 102 3E4EA986 102 3E507886 102 3E584086 102 3E396D06 102 3E579406 102 3E3C5E86 102
1F31C0EC: 3E4AF686 102 3E4EA986 102 3E507886 102 3E584086 102 3E396D06 102 3E579406 102 3E3C5E86 102 3E4AF686 102
1F31C12C: 3E4EA986 102 3E507886 102 3E584086 102 3E396D06 102 3E579406 102 3E345686 102 3E6A7606 102 3E6A6086 102
1F31C16C: 3E3C5E86 102 3E4AF686 102 3E4EA986 102 3E507886 102 3E584086 102 3E396D06 102 3E579406 102 3E345686 102
1F31C1AC: 3E6A7606 102 3E6A6086 102 3E6B9886 102 3E582006 102 3E3C5E86 102 3E4AF686 102 3E4EA986 102 3E507886 102
1F31C1EC: 3E584086 102 3E396D06 102 3E579406 102 3E345686 102 3E6A7606 102 3E6A6086 102 3E6B9886 102 3E582006 102
1F31C22C: 3E3C5E86 102 3E4AF686 102 3E4EA986 102 3E507886 102 3E584086 102 3E396D06 102 3E579406 102 3E345686 102
1F31C26C: 3E6A7606 102 3E6A6086 102 3E6B9886 102 3E582006 102 3E3EB986 102 3E50D986 102 3E39AD86 102 3E3C5E86 102
1F31C2AC: 3E4AF686 102 3E4EA986 102 3E507886 102 3E584086 102 3E396D06 102 3E579406 102 3E345686 102 3E6A7606 102
1F31C2EC: 3E6A6086 102 3E6B9886 102 3E582006 102 3E3EB986 102 3E50D986 102 3E39AD86 102 3E319006 102 3E4AF686 102
1F31C32C: 3E4AF686 102 3E4AF686 102 3E4AF686 102 3E4AF686 102 3E4AF686 102 3E4AF686 102 3E4AF686 102 3E4AF686 102
1F31C36C: 3E4AF686 102 3E4AF686 102 3E4AF686 102 3E4AF686 102 3E4AF686 102 3E4EA986 102 3E507886 102 3E584086 102
1F31C3AC: 3E396D06 102 3E579406 102 3E345686 102 3E6A7606 102 3E6A6086 102 3E6B9886 102 3E582006 102 3E3EB986 102
1F31C3EC: 3E50D986 102 3E39AD86 102 3E319006 102 3E4AF686 102 3E4EA986 102 3E507886 102 3E584086 102 3E396D06 102
1F31C42C: 3E579406 102 3E345686 102 3E6A7606 102 3E6A6086 102 3E6B9886 102 3E582006 102 3E3EB986 102 3E50D986 102
1F31C46C: 3E39AD86 102 3E319006 102 3E4AF686 102 3E4EA986 102 3E507886 102 3E584086 102 3E396D06 102 3E579406 102
1F31C4AC: 3E345686 102 3E6A7606 102 3E6A6086 102 3E6B9886 102 3E582006 102 3E3EB986 102 3E50D986 102 3E39AD86 102
1F31C4EC: 3E319006 102 3E67BA06 FF82 3E6BE406 FF82 3E4AF686 102 3E4EA986 102 3E507886 102 3E584086 102 3E396D06 102
1F31C52C: 3E579406 102 3E345686 102 3E6A7606 102 3E6A6086 102 3E6B9886 102 3E582006 102 3E3EB986 102 3E50D986 102
1F31C56C: 3E39AD86 102 3E319006 102 3E4AF686 102 3E4EA986 102 3E507886 102 3E584086 102 3E396D06 102 3E579406 102
1F31C5AC: 3E345686 102 3E6A7606 102 3E6A6086 102 3E6B9886 102 3E582006 102 3E3EB986 102 3E50D986 102 3E39AD86 102
1F31C5EC: 3E319006 102 3E4AF686 102 3E4EA986 102 3E507886 102 3E584086 102 3E396D06 102 3E579406 102 3E345686 102
1F31C62C: 3E6A7606 102 3E6A6086 102 3E6B9886 102 3E582006 102 3E3EB986 102 3E50D986 102 3E39AD86 102 3E319006 102
1F31C66C: 3E4AF686 102 3E4EA986 102 3E507886 102 3E584086 102 3E396D06 102 3E579406 102 3E345686 102 3E6A7606 102
1F31C6AC: 3E6A6086 102 3E6B9886 102 3E582006 102 3E3EB986 102 3E50D986 102 3E39AD86 102 3E319006 102 3E4AF686 102
1F31C6EC: 3E4EA986 102 3E507886 102 3E584086 102 3E396D06 102 3E579406 102 3E345686 102 3E6A7606 102 3E6A6086 102
1F31C72C: 3E6B9886 102 3E582006 102 3E3EB986 102 3E50D986 102 3E39AD86 102 3E319006 102 3E4AF686 102 3E4EA986 102
1F31C76C: 3E507886 102 3E584086 102 3E396D06 102 3E579406 102 3E345686 102 3E6A7606 102 3E6A6086 102 3E6B9886 102
1F31C7AC: 3E582006 102 3E3EB986 102 3E50D986 102 3E39AD86 102 3E319006 102 3E3D7686 FF82 3E4AF686 102 3E4EA986 102
1F31C7EC: 3E507886 102 3E584086 102 3E396D06 102 3E579406 102 3E345686 102 3E6A7606 102 3E6A6086 102 3E6B9886 102
1F31C82C: 3E582006 102 3E3EB986 102 3E50D986 102 3E39AD86 102 3E319006 102 3E4AF686 102 3E4EA986 102 3E507886 102
1F31C86C: 3E584086 102 3E396D06 102 3E579406 102 3E345686 102 3E6A7606 102 3E6A6086 102 3E6B9886 102 3E582006 102
1F31C8AC: 3E3EB986 102 3E50D986 102 3E39AD86 102 3E319006 102 3E4AF686 102 3E4EA986 102 3E507886 102 3E584086 102
1F31C8EC: 3E396D06 102 3E579406 102 3E345686 102 3E6A7606 102 3E6A6086 102 3E6B9886 102 3E582006 102 3E3EB986 102
1F31C92C: 3E50D986 102 3E39AD86 102 3E319006 102 38019E88 FF82 3E4AF686 102 3E4EA986 102 3E507886 102 3E584086 102
1F31C96C: 3E396D06 102 3E579406 102 3E345686 102 3E6A7606 102 3E6A6086 102 3E6B9886 102 3E582006 102 3E3EB986 102
1F31C9AC: 3E50D986 102 3E39AD86 102 3E319006 102 3E6C9006 FF82 3E467686 FF82 3E4AF686 102 3E4EA986 102 3E507886 102
1F31C9EC: 3E584086 102 3E396D06 102 3E579406 102 3E345686 102 3E6A7606 102 3E6A6086 102 3E6B9886 102 3E582006 102
1F31CA2C: 3E3EB986 102 3E50D986 102 3E39AD86 102 3E319006 102 3E4AF686 102 3E4EA986 102 3E507886 102 3E584086 102
1F31CA6C: 3E396D06 102 3E579406 102 3E345686 102 3E6A7606 102 3E6A6086 102 3E6B9886 102 3E582006 102 3E3EB986 102
1F31CAAC: 3E50D986 102 3E39AD86 102 3E319006 102 3E4AF686 102 3E4EA986 102 3E507886 102 3E584086 102 3E396D06 102
1F31CAEC: 3E579406 102 3E345686 102 3E6A7606 102 3E6A6086 102 3E6B9886 102 3E582006 102 3E3EB986 102 3E50D986 102
1F31CB2C: 3E39AD86 102 3E319006 102 3E333ED2 FF82 3E4AF686 102 3E4EA986 102 3E507886 102 3E584086 102 3E396D06 102
1F31CB6C: 3E579406 102 3E345686 102 3E6A7606 102 3E6A6086 102 3E6B9886 102 3E582006 102 3E3EB986 102 3E50D986 102
1F31CBAC: 3E39AD86 102 3E319006 102 3E4AF686 102 3E4EA986 102 3E507886 102 3E584086 102 3E396D06 102 3E579406 102
1F31CBEC: 3E345686 102 3E6A7606 102 3E6A6086 102 3E6B9886 102 3E582006 102 3E3EB986 102 3E50D986 102 3E39AD86 102
1F31CC2C: 3E319006 102 3E4AF686 102 3E4EA986 102 3E507886 102 3E584086 102 3E396D06 102 3E579406 102 3E345686 102
1F31CC6C: 3E6A7606 102 3E6A6086 102 3E6B9886 102 3E582006 102 3E3EB986 102 3E50D986 102 3E39AD86 102 3E319006 102
1F31CCAC: 3E503806 FF82 3E4AF686 102 3E4EA986 102 3E507886 102 3E584086 102 3E396D06 102 3E579406 102 3E345686 102
1F31CCEC: 3E6A7606 102 3E6A6086 102 3E6B9886 102 3E582006 102 3E3EB986 102 3E50D986 102 3E39AD86 102 3E319006 102
1F31CD2C: 3E4AF686 102 3E4EA986 102 3E507886 102 3E584086 102 3E396D06 102 3E579406 102 3E345686 102 3E6A7606 102
1F31CD6C: 3E6A6086 102 3E6B9886 102 3E582006 102 3E3EB986 102 3E50D986 102 3E39AD86 102 3E319006 102 3E4AF686 102
1F31CDAC: 3E4EA986 102 3E507886 102 3E584086 102 3E396D06 102 3E579406 102 3E345686 102 3E6A7606 102 3E6A6086 102
1F31CDEC: 3E6B9886 102 3E582006 102 3E3EB986 102 3E50D986 102 3E39AD86 102 3E319006 102 3E4AF686 102 3E4EA986 102
1F31CE2C: 3E507886 102 3E584086 102 3E396D06 102 3E579406 102 3E345686 102 3E6A7606 102 3E6A6086 102 3E6B9886 102
1F31CE6C: 3E582006 102 3E3EB986 102 3E50D986 102 3E39AD86 102 3E319006 102 3E4AF686 102 3E4EA986 102 3E507886 102
1F31CEAC: 3E584086 102 3E396D06 102 3E579406 102 3E345686 102 3E6A7606 102 3E6A6086 102 3E6B9886 102 3E582006 102
1F31CEEC: 3E3EB986 102 3E50D986 102 3E39AD86 102 3E319006 102 3E4AF686 102 3E4EA986 102 3E507886 102 3E584086 102
1F31CF2C: 3E396D06 102 3E579406 102 3E345686 102 3E6A7606 102 3E6A6086 102 3E6B9886 102 3E582006 102 3E3EB986 102
1F31CF6C: 3E50D986 102 3E39AD86 102 3E319006 102 3E4AF686 102 3E4EA986 102 3E507886 102 3E584086 102 3E396D06 102
1F31CFAC: 3E579406 102 3E345686 102 3E6A7606 102 3E6A6086 102 3E6B9886 102 3E582006 102 3E3EB986 102 3E50D986 102
1F31CFEC: 3E39AD86 102 3E319006 102 3E4AF686 102 3E4EA986 102 3E507886 102 3E584086 102 3E396D06 102 3E579406 102
1F31D02C: 3E345686 102 3E6A7606 102 3E6A6086 102 3E6B9886 102 3E582006 102 3E3EB986 102 3E50D986 102 3E39AD86 102
1F31D06C: 3E319006 102 3E4AF686 102 3E4EA986 102 3E507886 102 3E584086 102 3E396D06 102 3E579406 102 3E345686 102
1F31D0AC: 3E6A7606 102 3E6A6086 102 3E6B9886 102 3E582006 102 3E3EB986 102 3E50D986 102 3E39AD86 102 3E319006 102
1F31D0EC: 3E4AF686 102 3E4EA986 102 3E507886 102 3E584086 102 3E396D06 102 3E579406 102 3E345686 102 3E6A7606 102
1F31D12C: 3E6A6086 102 3E6B9886 102 3E582006 102 3E3EB986 102 3E50D986 102 3E39AD86 102
HOST IRQ Recovered Count:0
Off Channel rdy 1F31E034 (1F31E034 - 1F31E0D4)
1F31E034: 0 0 0 0 0 0 0 0
1F31E0B4: 0 0
Off Channel done 1F31E0D4 (1F31E0D4 - 1F31E174)
1F31E0D4: 0 0 0 0 0 0 0 0
1F31E154: 0 0
Tx done 1F31D15C, current 1F31D628 Cnt 109180007 TS 9BE79CAA 0 0 Ptr 0 0
1F31D15C: 0 0 0 0 0 0 0 0
1F31D17C: 0 0 0 0 0 0 0 0
1F31D19C: 0 0 0 0 0 0 0 0
1F31D1BC: 0 0 0 0 0 0 0 0
1F31D1DC: 0 0 0 0 0 0 0 0
1F31D1FC: 0 0 0 0 0 0 0 0
1F31D21C: 0 0 0 0 0 0 0 0
1F31D23C: 0 0 0 0 0 0 0 0
1F31D25C: 0 0 0 0 0 0 0 0
1F31D27C: 0 0 0 0 0 0 0 0
1F31D29C: 0 0 0 0 0 0 0 0
1F31D2BC: 0 0 0 0 0 0 0 0
1F31D2DC: 0 0 0 0 0 0 0 0
1F31D2FC: 0 0 0 0 0 0 0 0
1F31D31C: 0 0 0 0 0 0 0 0
1F31D33C: 0 0 0 0 0 0 0 0
1F31D35C: 0 0 0 0 0 0 0 0
1F31D37C: 0 0 0 0 0 0 0 0
1F31D39C: 0 0 0 0 0 0 0 0
1F31D3BC: 0 0 0 0 0 0 0 0
1F31D3DC: 0 0 0 0 0 0 0 0
1F31D3FC: 0 0 0 0 0 0 0 0
1F31D41C: 0 0 0 0 0 0 0 0
1F31D43C: 0 0 0 0 0 0 0 0
1F31D45C: 0 0 0 0 0 0 0 0
1F31D47C: 0 0 0 0 0 0 0 0
1F31D49C: 0 0 0 0 0 0 0 0
1F31D4BC: 0 0 0 0 0 0 0 0
1F31D4DC: 0 0 0 0 0 0 0 0
1F31D4FC: 0 0 0 0 0 0 0 0
1F31D51C: 0 0 0 0 0 0 0 0
1F31D53C: 0 0 0 0 0 0 0 0
1F31D55C: 0 0 0 0 0 0 0 0
1F31D57C: 0 0 0 0 0 0 0 0
1F31D59C: 0 0 0 0 0 0 0 0
1F31D5BC: 0 0 0 0 0 0 0 0
1F31D5DC: 0 0 0 0 0 0 0 0
1F31D5FC: 0 0 0 0 0 0 0 0
1F31D61C: 0 0 0 0 0 0 0 0
1F31D63C: 0 0 0 0 0 0 0 0
1F31D65C: 0 0 0 0 0 0 0 0
1F31D67C: 0 0 0 0 0 0 0 0
1F31D69C: 0 0 0 0 0 0 0 0
1F31D6BC: 0 0 0 0 0 0 0 0
1F31D6DC: 0 0 0 0 0 0 0 0
1F31D6FC: 0 0 0 0 0 0 0 0
1F31D71C: 0 0 0 0 0 0 0 0
1F31D73C: 0 0 0 0 0 0 0 0
1F31D75C: 0 0 0 0 0 0 0 0
1F31D77C: 0 0 0 0 0 0 0 0
1F31D79C: 0 0 0 0 0 0 0 0
1F31D7BC: 0 0 0 0 0 0 0 0
1F31D7DC: 0 0 0 0 0 0 0 0
1F31D7FC: 0 0 0 0 0 0 0 0
1F31D81C: 0 0 0 0 0 0 0 0
1F31D83C: 0 0 0 0 0 0 0 0
1F31D85C: 0 0 0 0 0 0 0 0
1F31D87C: 0 0 0 0 0 0 0 0
1F31D89C: 0 0 0 0 0 0 0 0
1F31D8BC: 0 0 0 0 0 0 0 0
1F31D8DC: 0 0 0 0 0 0 0 0
1F31D8FC: 0 0 0 0 0 0 0 0
1F31D91C: 0 0 0 0 0 0 0 0
1F31D93C: 0 0 0 0 0 0 0 0
1F31D95C: 0 0 0 0 0 0 0 0
1F31D97C: 0 0 0 0 0 0 0 0
1F31D99C: 0 0 0 0 0 0 0 0
1F31D9BC: 0 0 0 0 0 0 0 0
1F31D9DC: 0 0 0 0 0 0 0 0
1F31D9FC: 0 0 0 0 0 0 0 0
1F31DA1C: 0 0 0 0 0 0 0 0
1F31DA3C: 0 0 0 0 0 0 0 0
1F31DA5C: 0 0 0 0 0 0 0 0
1F31DA7C: 0 0 0 0 0 0 0 0
1F31DA9C: 0 0 0 0 0 0 0 0
1F31DABC: 0 0 0 0 0 0 0 0
1F31DADC: 0 0 0 0 0 0 0 0
1F31DAFC: 0 0 0 0 0 0 0 0
1F31DB1C: 0 0 0 0 0 0 0 0
1F31DB3C: 0 0 0 0 0 0 0 0
1F31DB5C: 0 0 0 0 0 0 0 0
1F31DB7C: 0 0 0 0 0 0 0 0
1F31DB9C: 0 0 0 0 0 0 0 0
1F31DBBC: 0 0 0 0 0 0 0 0
1F31DBDC: 0 0 0 0 0 0 0 0
1F31DBFC: 0 0 0 0 0 0 0 0
1F31DC1C: 0 0 0 0 0 0 0 0
1F31DC3C: 0 0 0 0 0 0 0 0
1F31DC5C: 0 0 0 0 0 0 0 0
1F31DC7C: 0 0 0 0 0 0 0 0
1F31DC9C: 0 0 0 0 0 0 0 0
1F31DCBC: 0 0 0 0 0 0 0 0
1F31DCDC: 0 0 0 0 0 0 0 0
1F31DCFC: 0 0 0 0 0 0 0 0
1F31DD1C: 0 0 0 0 0 0 0 0
1F31DD3C: 0 0 0 0 0 0 0 0
1F31DD5C: 0 0 0 0 0 0 0 0
1F31DD7C: 0 0 0 0 0 0 0 0
1F31DD9C: 0 0 0 0 0 0 0 0
1F31DDBC: 0 0 0 0 0 0 0 0
1F31DDDC: 0 0 0 0 0 0 0 0
1F31DDFC: 0 0 0 0 0 0 0 0
1F31DE1C: 0 0 0 0 0 0 0 0
1F31DE3C: 0 0 0 0 0 0 0 0
1F31DE5C: 0 0 0 0 0 0 0 0
1F31DE7C: 0 0 0 0 0 0 0 0
1F31DE9C: 0 0 0 0 0 0 0 0
1F31DEBC: 0 0 0 0 0 0 0 0
1F31DEDC: 0 0 0 0 0 0 0 0
1F31DEFC: 0 0 0 0 0 0 0 0
1F31DF1C: 0 0 0 0 0 0 0 0
1F31DF3C: 0 0 0 0 0 0 0 0
1F31DF5C: 0 0 0 0 0 0 0 0
1F31DF7C: 0 0 0 0 0 0 0 0
1F31DF9C: 0 0 0 0 0 0 0 0
1F31DFBC: 0 0 0 0 0 0 0 0
1F31DFDC: 0 0 0 0 0 0 0 0
1F31DFFC: 0 0 0 0 0 0 0 0
1F31E01C: 0 0 0 0 0 0
Rcv rdy 1F31E174, current 1F31E520
1F31E174: 1E783518 1E4EB36C 1E428164 1E3915E4 1E3FBADC 1E69BDB8 1E54CC70 1E461478
1F31E194: 1E36C5C8 1E7481B8 1E781F90 1E4C4DC8 1E455D74 1E38EAD4 1E6E07D0 1E4572FC
1F31E1B4: 1E3C1D04 1E4189C8 1E392B6C 1E76A6C4 1E560F68 1E734984 1E54F780 1E53EA5C
1F31E1D4: 1E715A4C 1E6D0570 1E6D5B90 1E56FC40 1E443AC8 1E6AAA90 1E6B0B74 1E6819DC
1F31E1F4: 1E34CBCC 1E39C224 1E7057EC 1E3495F8 1E4EE940 1E788074 1E3CD408 1E7CD550
1F31E214: 1E4A7418 1E4A5E90 1E7313B0 1E381384 1E6C99C8 1E689048 1E4DB10C 1E35A31C
1F31E234: 1E3D09DC 1E580964 1E3475AC 1E71042C 1E356284 1E31CF70 1E3C9E34 1E57A880
1F31E254: 1E77A924 1E465510 1E50D878 1E6B9768 1E6F75D8 1E737494 1E31999C 1E70D91C
1F31E274: 1E4FA044 1E3F4470 1E6F4AC8 1E3521EC 1E351728 1E714F88 1E55D994 1E3DB61C
1F31E294: 1E3664E4 1E39CCE8 1E785564 1E54ECBC 1E44D180 1E480E74 1E459E0C 1E7814CC
1F31E2B4: 1E3BA698 1E491B98 1E6AB554 1E451CDC 1E7A9ABC 1E58C068 1E32DC94 1E3808C0
1F31E2D4: 1E3FFB74 1E6C6EB8 1E4276A0 1E4E2778 1E4C6350 1E71E640 1E3A4354 1E48F088
1F31E2F4: 1E7226D8 1E41948C 1E77688C 1E7308EC 1E56B0E4 1E558374 1E73EB00 1E49A78C
1F31E314: 1E708DC0 1E5184B8 1E733EC0 1E383E94 1E4D5AEC 1E76C710 1E32C70C 1E4AA9EC
1F31E334: 1E3C6860 1E410898 1E4DE6E0 1E3E625C 1E6C0310 1E76B188 1E35CE2C 1E345560
1F31E354: 1E33FF40 1E72FE28 1E51395C 1E3B2568 1E3BC6E4 1E402684 1E3FC5A0 1E793778
1F31E374: 1E527190 1E530848 1E6FCBF8 1E519A40 1E3BB15C 1E50CDB4 1E74C250 1E6A7F80
1F31E394: 1E3EADB8 1E320544 1E425654 1E48C578 1E50B82C 1E37C828 1E368530 1E750DAC
1F31E3B4: 1E3E5798 1E507794 1E45F42C 1E420034 1E680F18 1E514420 1E6E5DF0 1E6D6654
1F31E3D4: 1E4BF7A8 1E68B094 1E555864 1E3D7584 1E594C5C 1E70C394 1E32B184 1E7645E0
1F31E3F4: 1E798D98 1E741610 1E5792F8 1E7CAA40 1E3CF454 1E525144 1E56DBF4 1E4A89A0
1F31E414: 1E37A7DC 1E46AB30 1E6D9C28 1E556328 1E55E458 1E3E77E4 1E6A74BC 1E7BC82C
1F31E434: 1E7B5C84 1E473724 1E3A6E64 1E4B8C00 1E343FD8 1E7119B4 1E35EE78 1E3557C0
1F31E454: 1E56453C 1E4D9B84 1E508258 1E697D20 1E6D7BDC 1E359858 1E39818C 1E7A7A70
1F31E474: 1E4859D0 1E4B562C 1E3BBC20 1E575260 1E4FD618 1E3DD668 1E50620C 1E4296EC
1F31E494: 1E524680 1E3CB3BC 1E69FE50 1E746C30 1E712478 1E72319C 1E5205E8 1E484F0C
1F31E4B4: 1E590BC4 1E417440 1E352CB0 1E688584 1E497C7C 1E430294 1E4B0AD0 1E4322E0
1F31E4D4: 1E336888 1E713A00 1E709884 1E7ABB08 1E749740 1E7A0404 1E43994C 1E37B2A0
1F31E4F4: 1E6C8F04 1E6B1638 1E3726AC 1E6AE064 1E3270EC 1E69C87C 1E407CA4 1E77939C
1F31E514: 1E4AB4B0 1E4AD4FC 1E37DDB0 1E77FF44 1E69D340 1E3C7DE8 1E4FB5CC 1E500128
1F31E534: 1E4E6810 1E3F4F34 0 1E333D78 1E4777BC 1E77DEF8 1E453D28 1E57479C
1F31E554: 1E35C368 1E598CF4 1E710EF0 1E3B051C 1E3A3890 1E4133A8 1E3E2C88 1E7982D4
Rcv done 1F31E574, current 1F31E940
1F31E574: 0 0 0 0 0 0 0 0
1F31E594: 0 0 0 0 0 0 0 0
1F31E5B4: 0 0 0 0 0 0 0 0
1F31E5D4: 0 0 0 0 0 0 0 0
1F31E5F4: 0 0 0 0 0 0 0 0
1F31E614: 0 0 0 0 0 0 0 0
1F31E634: 0 0 0 0 0 0 0 0
1F31E654: 0 0 0 0 0 0 0 0
1F31E674: 0 0 0 0 0 0 0 0
1F31E694: 0 0 0 0 0 0 0 0
1F31E6B4: 0 0 0 0 0 0 0 0
1F31E6D4: 0 0 0 0 0 0 0 0
1F31E6F4: 0 0 0 0 0 0 0 0
1F31E714: 0 0 0 0 0 0 0 0
1F31E734: 0 0 0 0 0 0 0 0
1F31E754: 0 0 0 0 0 0 0 0
1F31E774: 0 0 0 0 0 0 0 0
1F31E794: 0 0 0 0 0 0 0 0
1F31E7B4: 0 0 0 0 0 0 0 0
1F31E7D4: 0 0 0 0 0 0 0 0
1F31E7F4: 0 0 0 0 0 0 0 0
1F31E814: 0 0 0 0 0 0 0 0
1F31E834: 0 0 0 0 0 0 0 0
1F31E854: 0 0 0 0 0 0 0 0
1F31E874: 0 0 0 0 0 0 0 0
1F31E894: 0 0 0 0 0 0 0 0
1F31E8B4: 0 0 0 0 0 0 0 0
1F31E8D4: 0 0 0 0 0 0 0 0
1F31E8F4: 0 0 0 0 0 0 0 0
1F31E914: 0 0 0 0 0 0 0 0
1F31E934: 0 0 0 0 0 0 0 0
1F31E954: 0 0 0 0 0 0 0 0
Off Channel scheduler statistics: (mSec)
Priority avg_wait_time avg_serve_time timeout_count flush_count request_count
0 0 0 0 0 0
1 0 0 0 0 0
2 0 0 0 0 0
3 0 0 0 0 0
4 0 0 0 0 0
off chan inprog = 0
offchannel flush inprog:No
Last 4 Radio Req stats
ReqId RdyTs DoneTs
A 9BF2A587 9BF2A59A
A 9BFA46BF 9BFA46D2
A 9C01E7D9 9C01E7EC
A 9BEB046E 9BEB0480
Current Ts:9C0330A1
TXSM Jammer information:
State: 0
Flags: 00000000
Beacons seen: 0
Time since: 0
Jammer Radio resets: 0
TXSM Beacon information:
Monitoring State: 1
Flags: 00000000
Beacons seen: 84147424
Time since: 4294967294
Max Time w/o beacons: 61
Beacon stopped count: 0
Counts > 120 0
Counts > 90 0
Counts > 60 4
Counts > 30 3
Counts > 15 0
Counts > 10 0
Counts > 5 0
TXSM Current Beacon Outage:
Beacon Monitor Flags OP Mode Flags Reason
0x00000000 0x00000000
TXSM Beacon Outage Stats:
Outage(Seconds) Beacon Monitor Flags OP Mode Flags Reason
> 120
> 90
> 60 0x80002003 0x00000000 Beacons are off, Capwap down, DFS enabled,
> 30 0x80002003 0x00000000 Beacons are off, Capwap down, DFS enabled,
> 15
> 10
> 5
Last Cmd Received Time:9C1467FE
Last stats update: 8790121
Current Time:8790120
Last Tx Ev:00000000
Last Off chnl Ev:00000000
Last Off chnl intr ret:00000000
Radio PCI resets:0
RX Ring Errors - Pak:0 Order:0 Max:0
Radio commands - total:36902289 delayed:0 elapsed:0 timeouts:0 time high 00000000 low 00000000 usecs 00000000
Log buf magic 0(FA1A1AFA) 1(00000000) Active(0) 1F31EDCC Last(1) 1F31F2C0
Before H2a TS:9C287A00
Last cmd host 31 fw 31 HTS 9C287A01 FWWD 7FC3FD60 PP 0 MAGIC FA1A1AFA
FW Stats Pak 0 Mac S/D 0/0
EU Submit/Done Stats
Q0 0/0
Q1 0/0
Q2 0/0
Q3 0/0
Q4 0/0
Q5 0/0
Q6 0/0
Q7 0/0
CMD(04) - TS HOST 00000000 FW D6C2A9E8 seq 6
CMD(06) - TS HOST 00000000 FW 000456A8 seq 6
CMD(07) - TS HOST 00000000 FW D6C2AA29 seq 6
CMD(08) - TS HOST 00000000 FW 7F9BECB4 seq 6
CMD(09) - TS HOST 00000000 FW 7F9BEC3D seq 6
CMD(0A) - TS HOST 00000000 FW DA576CBF seq 6
CMD(0B) - TS HOST 00000000 FW DA57C9C0 seq 6
CMD(0C) - TS HOST 00000000 FW D6C2B42A seq 6
CMD(0D) - TS HOST 00000000 FW 6F28BF7C seq 6
CMD(0F) - TS HOST 00000000 FW 6DA6061A seq 6
CMD(10) - TS HOST 00000000 FW D6C2A87F seq 6
CMD(12) - TS HOST 00000000 FW D6C2A68D seq 6
CMD(14) - TS HOST 00000000 FW 00045B6E seq 6
CMD(15) - TS HOST 00000000 FW D6C3794B seq 6
CMD(16) - TS HOST 9C23A921 FW 7FBA7003 seq 6
CMD(17) - TS HOST 00000000 FW 7FAB2EBA seq 6
CMD(1E) - TS HOST 00000000 FW 00045D78 seq 6
CMD(20) - TS HOST 00000000 FW 5DC929F9 seq 6
CMD(22) - TS HOST 00000000 FW 00059F1C seq 6
CMD(27) - TS HOST 00000000 FW DA57C85A seq 6
CMD(2B) - TS HOST 00000000 FW 6E02836D seq 6
CMD(30) - TS HOST 00000000 FW D6C2B705 seq 6
CMD(31) - TS HOST 00000000 FW 7FC6E1F2 seq 6
CMD(35) - TS HOST 00000000 FW D6C2B725 seq 6
CMD(39) - TS HOST 00000000 FW 00045AD2 seq 6
Well aligned packets transmitted: 21102
Misaligned packet transmitted: 109158905
### Tx Power: Dot11 Config
Serving Channel 112 (Type 6)
Active Level Index 1 (Unitless)
Active Level 17 dBm (OFDM 17 dBm)
IEEE MIB format TRUE
Metric unit dBm
HD Active 127
Low Power Mode Set High (Active: Set High)
Cookie max 17
Client Power Max 32767, Active Max 17 (Asymmetric)
Regulatory Limit 24
Modulation Index 4
Antenna Selection External, Rx: 4 active in [ABCD] Tx: 4 active in [ABCD]
Antenna Gain Reported:Configured:InUse = [0:0:12] (2 x dBi)
Allowed Power Levels Total 6 levels in TPO [17/14/11/8/5/2] Per-ant [11/8/5/2/-1/-4]
HAL Per antenna Tx Power (in dBm)
CCK :
OFDM : LBF : HT20-7 : HT20-15 : HT20-23 : HT40-7 :
HT40-15 : HT40-23 : N-HT40 Dup : HT20 BF-7 : HT20 BF-15 : HT20 BF-23 :
HT40 BF-7 : HT40 BF-15 : HT40 BF-23 : HT20 STBC-7 : HT40 STBC-7 :
VHT20-1s : VHT20-2s : VHT20-3s :
VHT40-1s : VHT40-2s : VHT40-3s :
VHT80-1s : VHT80-2s : VHT80-3s :
N-HT80DUP :
VHT20BF-1s : VHT20BF-2s : VHT20BF-3s :
VHT40BF-1s : VHT40BF-2s : VHT40BF-3s :
VHT80BF-1s : VHT80BF-2s : VHT80BF-3s :
VHT20ST : VHT40ST : VHT80ST :
0 0 0 0 :
1616161616161613 : 9 9 9 9 9 9 9 9 : 1616161616161613 : 1616161616161613 : 1515151515151513 : 1515151515151515 :
1515151515151514 : 1515151515151513 : 1515151515151515 : 9 9 9 9 9 9 9 9 : 1212121212121212 : 1414141414141413 :
9 9 9 9 9 9 9 9 : 1212121212121212 : 1414141414141413 : 1616161616161615 : 1515151515151515 : 161616161616161313-99 : 161616161616161313-99 : 15151515151515131211 :
15151515151515151313 : 15151515151515141312 : 15151515151515131211 :
13131313131313131313 : 13131313131313131312 : 131313131313-99131211 :
1313131313131313 :
9 9 9 9 9 9 9 9 9-99 : 121212121212121212-99 : 14141414141414131211 :
9 9 9 9 9 9 9 9 9 9 : 12121212121212121212 : 14141414141414131211 :
6 6 6 6 6 6 6 6 6 6 : 12121212121212121212 : 131313131313-99131211 :
161616161616161313-99 : 15151515151515141312 : 13131313131313131312 :
Dynamic Antenna Activation: Number of active antennas
0 0 0 0 :
2 2 2 2 2 2 2 3 : 4 4 4 4 4 4 4 4 : 2 2 2 2 2 2 2 3 : 3 3 3 3 3 3 3 4 : 4 4 4 4 4 4 4 4 : 3 3 3 3 3 3 3 3 :
4 4 4 4 4 4 4 4 : 4 4 4 4 4 4 4 4 : 3 3 3 3 3 3 3 3 : 4 4 4 4 4 4 4 4 : 4 4 4 4 4 4 4 4 : 4 4 4 4 4 4 4 4 :
4 4 4 4 4 4 4 4 : 4 4 4 4 4 4 4 4 : 4 4 4 4 4 4 4 4 : 3 3 3 3 3 3 3 3 : 4 4 4 4 4 4 4 4 : 2 2 2 2 2 2 2 3 3 1 : 3 3 3 3 3 3 3 4 4 1 : 4 4 4 4 4 4 4 4 4 4 :
3 3 3 3 3 3 3 3 4 4 : 4 4 4 4 4 4 4 4 4 4 : 4 4 4 4 4 4 4 4 4 4 :
4 4 4 4 4 4 4 4 4 4 : 4 4 4 4 4 4 4 4 4 4 : 4 4 4 4 4 4 1 4 4 4 :
4 4 4 4 4 4 4 4 :
4 4 4 4 4 4 4 4 4 4 : 4 4 4 4 4 4 4 4 4 4 : 4 4 4 4 4 4 4 4 4 4 :
3 3 3 3 3 3 3 4 4 1 : 4 4 4 4 4 4 4 4 4 4 : 4 4 4 4 4 4 4 4 4 4 :
Max per-path TxPower at modulation (at operation condition)
6.0 to 48.0 , 16 dBm
54.0 to 54.0 , 13 dBm
6.0bf to 54.0bf, 9 dBm
m0-2 to m6-2 , 16 dBm
m7-2 to m7-2 , 13 dBm
m8-2 to m14-2 , 16 dBm
m15-2 to m15-2 , 13 dBm
m16-2 to m22-2 , 15 dBm
m23-2 to m23-2 , 13 dBm
m0-4 to m14-4 , 15 dBm
m15-4 to m15-4 , 14 dBm
m16-4 to m22-4 , 15 dBm
m23-4 to m23-4 , 13 dBm
6.0d to 54.0d , 15 dBm
m0b2 to m7b2 , 9 dBm
m8b2 to m15b2 , 12 dBm
m16b2 to m22b2 , 14 dBm
m23b2 to m23b2 , 13 dBm
m0b4 to m7b4 , 9 dBm
m8b4 to m15b4 , 12 dBm
m16b4 to m22b4 , 14 dBm
m23b4 to m23b4 , 13 dBm
m0t2 to m6t2 , 16 dBm
m7t2 to m7t4 , 15 dBm
a0.1-2 to a6.1-2, 16 dBm
a7.1-2 to a8.1-2, 13 dBm
a9.1-2 to a9.1-2, -99 dBm
a0.2-2 to a6.2-2, 16 dBm
a7.2-2 to a8.2-2, 13 dBm
a9.2-2 to a9.2-2, -99 dBm
a0.3-2 to a6.3-2, 15 dBm
a7.3-2 to a7.3-2, 13 dBm
a8.3-2 to a8.3-2, 12 dBm
a9.3-2 to a9.3-2, 11 dBm
a0.1-4 to a7.1-4, 15 dBm
a8.1-4 to a9.1-4, 13 dBm
a0.2-4 to a6.2-4, 15 dBm
a7.2-4 to a7.2-4, 14 dBm
a8.2-4 to a8.2-4, 13 dBm
a9.2-4 to a9.2-4, 12 dBm
a0.3-4 to a6.3-4, 15 dBm
a7.3-4 to a7.3-4, 13 dBm
a8.3-4 to a8.3-4, 12 dBm
a9.3-4 to a9.3-4, 11 dBm
a0.1-8 to a8.2-8, 13 dBm
a9.2-8 to a9.2-8, 12 dBm
a0.3-8 to a5.3-8, 13 dBm
a6.3-8 to a6.3-8, -99 dBm
a7.3-8 to a7.3-8, 13 dBm
a8.3-8 to a8.3-8, 12 dBm
a9.3-8 to a9.3-8, 11 dBm
6.0d to 54.0d , 13 dBm
a0.1b2 to a8.1b2, 9 dBm
a9.1b2 to a9.1b2, -99 dBm
a0.2b2 to a8.2b2, 12 dBm
a9.2b2 to a9.2b2, -99 dBm
a0.3b2 to a6.3b2, 14 dBm
a7.3b2 to a7.3b2, 13 dBm
a8.3b2 to a8.3b2, 12 dBm
a9.3b2 to a9.3b2, 11 dBm
a0.1b4 to a9.1b4, 9 dBm
a0.2b4 to a9.2b4, 12 dBm
a0.3b4 to a6.3b4, 14 dBm
a7.3b4 to a7.3b4, 13 dBm
a8.3b4 to a8.3b4, 12 dBm
a9.3b4 to a9.3b4, 11 dBm
a0.1b8 to a9.1b8, 6 dBm
a0.2b8 to a9.2b8, 12 dBm
a0.3b8 to a5.3b8, 13 dBm
a6.3b8 to a6.3b8, -99 dBm
a7.3b8 to a7.3b8, 13 dBm
a8.3b8 to a8.3b8, 12 dBm
a9.3b8 to a9.3b8, 11 dBm
a0.1t2 to a6.1t2, 16 dBm
a7.1t2 to a8.1t2, 13 dBm
a9.1t2 to a9.1t2, -99 dBm
a0.1t4 to a6.1t4, 15 dBm
a7.1t4 to a7.1t4, 14 dBm
a8.1t4 to a8.1t4, 13 dBm
a9.1t4 to a9.1t4, 12 dBm
a0.1t8 to a8.1t8, 13 dBm
a9.1t8 to a9.1t8, 12 dBm
DOT11 Statistics (Cumulative Total/Last 5 Seconds):
RECEIVER TRANSMITTER
Host Rx K Bytes: 1301032 / 19 Host Tx K Bytes: 180386 / 0
Unicasts Rx: 39839941 / 0 Unicasts Tx: 98146562 / 0
Unicasts to host: 39839941 / 0 Unicasts by host: 79794885 / 0
Broadcasts Rx: 17138399 / 49 Broadcasts Tx: 88602295 / 48
Beacons Rx: 16424718 / 49 Beacons Tx: 84147424 / 48
Broadcasts to host:17138399 / 49 Broadcasts by host: 4454871 / 0
Multicasts Rx: 0 / 0 Multicasts Tx: 6578573 / 0
Multicasts to host: 0 / 0 Multicasts by host: 6578573 / 0
Mgmt Packets Rx: 743404 / 0 Mgmt Packets Tx: 228662 / 0
RTS received: 0 / 0 RTS transmitted: 22713541 / 0
Duplicate frames: 0 / 0 CTS not received: 5826953 / 0
CRC errors: 40835400 / 10 Unicast Fragments Tx:109180007 / 0
WEP errors: 8 / 0 Retries: 14140246 / 0
Buffer full: 0 / 0 Packets one retry: 4041466 / 0
Host buffer full: 0 / 0 Packets > 1 retry: 3906340 / 0
Header CRC errors: 0 / 0 Protocol defers: 0 / 0
Invalid header: 0 / 0 Energy detect defers: 0 / 0
Length invalid: 0 / 0 Jammer detected: 0 / 0
Incomplete fragments: 0 / 0 Packets aged: 0 / 0
Rx Concats: 0 / 0 Tx Concats: 0 / 0
R2H Buffer full: 0 / 0
Tx Watchdog stats:
Tx SW Watchdog 0 / 0
Tx HW Watchdog 0 / 0
RATE 6.0
Rx Packets: 17041688 / 49 Tx Packets: 52523 / 0
Rx Bytes: 1571008198 / 17297 Tx Bytes: 17891847 / 0
RTS Retries: 0 / 0 Data Retries: 182213 / 0
RATE 9.0
Rx Packets: 3 / 0 Tx Packets: 11 / 0
Rx Bytes: 618 / 0 Tx Bytes: 8327 / 0
RTS Retries: 0 / 0 Data Retries: 0 / 0
RATE 12.0
Rx Packets: 13133 / 0 Tx Packets: 64 / 0
Rx Bytes: 3212 / 0 Tx Bytes: 31587 / 0
RTS Retries: 0 / 0 Data Retries: 116 / 0
RATE 18.0
Rx Packets: 19731 / 0 Tx Packets: 48 / 0
Rx Bytes: 2433 / 0 Tx Bytes: 30127 / 0
RTS Retries: 0 / 0 Data Retries: 12 / 0
RATE 24.0
Rx Packets: 166064 / 0 Tx Packets: 79 / 0
Rx Bytes: 737798 / 0 Tx Bytes: 56531 / 0
RTS Retries: 0 / 0 Data Retries: 20 / 0
RATE 36.0
Rx Packets: 96472 / 0 Tx Packets: 141 / 0
Rx Bytes: 4818 / 0 Tx Bytes: 73190 / 0
RTS Retries: 0 / 0 Data Retries: 85 / 0
RATE 48.0
Rx Packets: 208211 / 0 Tx Packets: 38 / 0
Rx Bytes: 11987 / 0 Tx Bytes: 18473 / 0
RTS Retries: 0 / 0 Data Retries: 13 / 0
RATE 54.0
Rx Packets: 1200297 / 0 Tx Packets: 29 / 0
Rx Bytes: 2543103 / 0 Tx Bytes: 18945 / 0
RTS Retries: 0 / 0 Data Retries: 8 / 0
RATE m0-2
Rx Packets: 1742 / 0 Tx Packets: 1022 / 0
Rx Bytes: 252090 / 0 Tx Bytes: 870697 / 0
RTS Retries: 0 / 0 Data Retries: 3595 / 0
RATE m1-2
Rx Packets: 612 / 0 Tx Packets: 159 / 0
Rx Bytes: 122250 / 0 Tx Bytes: 96442 / 0
RTS Retries: 0 / 0 Data Retries: 15 / 0
RATE m2-2
Rx Packets: 518 / 0 Tx Packets: 173 / 0
Rx Bytes: 88976 / 0 Tx Bytes: 90012 / 0
RTS Retries: 0 / 0 Data Retries: 21 / 0
RATE m3-2
Rx Packets: 283285 / 0 Tx Packets: 1466 / 0
Rx Bytes: 33959298 / 0 Tx Bytes: 1165095 / 0
RTS Retries: 0 / 0 Data Retries: 3751 / 0
RATE m4-2
Rx Packets: 6308 / 0 Tx Packets: 1964 / 0
Rx Bytes: 1050804 / 0 Tx Bytes: 1524043 / 0
RTS Retries: 0 / 0 Data Retries: 592 / 0
RATE m5-2
Rx Packets: 3374 / 0 Tx Packets: 4200 / 0
Rx Bytes: 332726 / 0 Tx Bytes: 4192825 / 0
RTS Retries: 0 / 0 Data Retries: 4928 / 0
RATE m6-2
Rx Packets: 2420 / 0 Tx Packets: 25251 / 0
Rx Bytes: 294554 / 0 Tx Bytes: 31075065 / 0
RTS Retries: 0 / 0 Data Retries: 2991 / 0
RATE m7-2
Rx Packets: 57477 / 0 Tx Packets: 66535 / 0
Rx Bytes: 8748091 / 0 Tx Bytes: 78929299 / 0
RTS Retries: 0 / 0 Data Retries: 5845 / 0
RATE m9-2
Rx Packets: 9 / 0 Tx Packets: 9 / 0
Rx Bytes: 1411 / 0 Tx Bytes: 2793 / 0
RATE m10-2
Rx Packets: 8 / 0 Tx Packets: 13 / 0
Rx Bytes: 1334 / 0 Tx Bytes: 5060 / 0
RATE m11-2
Rx Packets: 10 / 0 Tx Packets: 10 / 0
Rx Bytes: 1115 / 0 Tx Bytes: 4511 / 0
RATE m12-2
Rx Packets: 92 / 0 Tx Packets: 581 / 0
Rx Bytes: 8122 / 0 Tx Bytes: 320410 / 0
RTS Retries: 0 / 0 Data Retries: 1148 / 0
RATE m13-2
Rx Packets: 109 / 0 Tx Packets: 130 / 0
Rx Bytes: 10791 / 0 Tx Bytes: 90710 / 0
RTS Retries: 0 / 0 Data Retries: 2 / 0
RATE m14-2
Rx Packets: 752 / 0 Tx Packets: 2139 / 0
Rx Bytes: 148620 / 0 Tx Bytes: 2146129 / 0
RTS Retries: 0 / 0 Data Retries: 166 / 0
RATE m15-2
Rx Packets: 61376 / 0 Tx Packets: 77625 / 0
Rx Bytes: 14174648 / 0 Tx Bytes: 65150742 / 0
RTS Retries: 0 / 0 Data Retries: 5271 / 0
RATE a0.1-2
Rx Packets: 55967 / 0 Tx Packets: 144777 / 0
Rx Bytes: 9355715 / 0 Tx Bytes: 131856497 / 0
RTS Retries: 0 / 0 Data Retries: 708412 / 0
RATE a1.1-2
Rx Packets: 132688 / 0 Tx Packets: 71922 / 0
Rx Bytes: 27761304 / 0 Tx Bytes: 86913113 / 0
RTS Retries: 0 / 0 Data Retries: 6018 / 0
RATE a2.1-2
Rx Packets: 269097 / 0 Tx Packets: 41562 / 0
Rx Bytes: 93648067 / 0 Tx Bytes: 34728149 / 0
RTS Retries: 0 / 0 Data Retries: 16445 / 0
RATE a3.1-2
Rx Packets: 140169 / 0 Tx Packets: 180966 / 0
Rx Bytes: 52400805 / 0 Tx Bytes: 161832086 / 0
RTS Retries: 0 / 0 Data Retries: 471356 / 0
RATE a4.1-2
Rx Packets: 1011094 / 0 Tx Packets: 126122 / 0
Rx Bytes: 278029705 / 0 Tx Bytes: 101214270 / 0
RTS Retries: 0 / 0 Data Retries: 18042 / 0
RATE a5.1-2
Rx Packets: 351472 / 0 Tx Packets: 2809735 / 0
Rx Bytes: 169377915 / 0 Tx Bytes: 3566936881 / 0
RTS Retries: 0 / 0 Data Retries: 1249080 / 0
RATE a6.1-2
Rx Packets: 811656 / 0 Tx Packets: 454800 / 0
Rx Bytes: 410305825 / 0 Tx Bytes: 504232463 / 0
RTS Retries: 0 / 0 Data Retries: 56118 / 0
RATE a7.1-2
Rx Packets: 1237125 / 0 Tx Packets: 563157 / 0
Rx Bytes: 563088805 / 0 Tx Bytes: 612578965 / 0
RTS Retries: 0 / 0 Data Retries: 73192 / 0
RATE a8.1-2
Rx Packets: 1424862 / 0 Tx Packets: 826734 / 0
Rx Bytes: 443322302 / 0 Tx Bytes: 1043636982 / 0
RTS Retries: 0 / 0 Data Retries: 118200 / 0
RATE a9.1-4
Rx Packets: 1898905 / 0 Tx Packets: 1481864 / 0
Rx Bytes: 677308283 / 0 Tx Bytes: 1639982070 / 0
RTS Retries: 0 / 0 Data Retries: 221691 / 0
RATE a0.2-2
Rx Packets: 15517 / 0 Tx Packets: 80573 / 0
Rx Bytes: 3373686 / 0 Tx Bytes: 107939008 / 0
RTS Retries: 0 / 0 Data Retries: 7460 / 0
RATE a1.2-2
Rx Packets: 63128 / 0 Tx Packets: 73562 / 0
Rx Bytes: 14464916 / 0 Tx Bytes: 89327624 / 0
RTS Retries: 0 / 0 Data Retries: 4820 / 0
RATE a2.2-2
Rx Packets: 163267 / 0 Tx Packets: 310830 / 0
Rx Bytes: 35708755 / 0 Tx Bytes: 366629704 / 0
RTS Retries: 0 / 0 Data Retries: 19920 / 0
RATE a3.2-2
Rx Packets: 865546 / 0 Tx Packets: 2516697 / 0
Rx Bytes: 183147272 / 0 Tx Bytes: 3438448182 / 0
RTS Retries: 0 / 0 Data Retries: 97176 / 0
RATE a4.2-2
Rx Packets: 4053658 / 0 Tx Packets: 2697010 / 0
Rx Bytes: 813739302 / 0 Tx Bytes: 3511889045 / 0
RTS Retries: 0 / 0 Data Retries: 1603735 / 0
RATE a5.2-2
Rx Packets: 4975879 / 0 Tx Packets: 12342279 / 0
Rx Bytes: 1096374392 / 0 Tx Bytes: 3000616101 / 0
RTS Retries: 0 / 0 Data Retries: 3048334 / 0
RATE a6.2-2
Rx Packets: 9493293 / 0 Tx Packets: 8322717 / 0
Rx Bytes: 1503334057 / 0 Tx Bytes: 2654867242 / 0
RTS Retries: 0 / 0 Data Retries: 1236333 / 0
RATE a7.2-2
Rx Packets: 7363696 / 0 Tx Packets: 12140409 / 0
Rx Bytes: 980900761 / 0 Tx Bytes: 3261555139 / 0
RTS Retries: 0 / 0 Data Retries: 1509802 / 0
RATE a8.2-2
Rx Packets: 3486087 / 0 Tx Packets: 16869128 / 0
Rx Bytes: 384137277 / 0 Tx Bytes: 1865690070 / 0
RTS Retries: 0 / 0 Data Retries: 2046308 / 0
RATE a4.3-2
Rx Packets: 1 / 0 Tx Packets: 0 / 0
Rx Bytes: 104 / 0 Tx Bytes: 0 / 0
RATE a5.3-2
Rx Packets: 3 / 0 Tx Packets: 2 / 0
Rx Bytes: 196 / 0 Tx Bytes: 108 / 0
RATE a7.3-2
Rx Packets: 2 / 0 Tx Packets: 1 / 0
Rx Bytes: 116 / 0 Tx Bytes: 54 / 0
ATF Radio Configuration:
Mode : Disabled
Multicast throttle drops: 0
Client TX pause count: 39009
Bad receive packet count: 0
Media Direct Band Configuration
Unicast Video Redirect = 0
Client Min Phy Rate = 0
Max Retry Percentage = 0
Dot11 Current Video Transmission Metrics:
Arrivals:0 Q-Drops:0 Tries:0 Agg:0 Success:0 Fail:0
Dot11 5-second Video Transmission Metrics:
Arrivals:0 Tries:0 Agg:0 Success:0 Fail:0
Radio-Q-Peak:0 Video-Q-Peak:0 Video-Q-Drops:0
Delay - Tot Msec:0 10/20/40/40+ Msec:0/0/0/0
Dot11 1-second Video Transmission Metrics:
Q-util:0 max-tx-time:0 p-chan:29 p-video:0 L/r:0
Extended Radio Parameters:
Beacon period (not supported), range (not supported)
Ext Conf flags: 0
Mcast rate 0 Mbps (Disabled)
RX sensitivity -0 dB (Disabled)
CCA threshold -0 dB (Disabled)
Coverage Report Interval - 90
802.11 forwarding statistics:
IDB fastsend:101051394 frame_tx:103726556 frame_rx:39749848 vidb_tx:0
Global mcast TX - total:0 mc2uc:0 drops:0 bad pri:0
IDB mcast TX - filter:0,0,0 igmp_filter:0 from_self:0
MGMT Action - GAS Req Rcvd:0 GAS Req Rx Drop:0
Global DMS - requests:0 uc:0 drop:0
DMS enabled on WLAN(s):
DMS database:
Log Buffer:
Last radio reset code: 35
Radio resets - total:24 retries:0 failed:0
Reset Stats: Start Cnt: 11, Recovery: Cnt 0, Last Ret: 0, Fails: 0, Recvry Status: Stalled NO, In Prog NO
Code/Count: 35/00007 223C2 37/00011 E4F1 48/00001 2 67/00001 0
Code/Count: 68/00004 0
Prefetch: Trigger Active: 0 Recovery Disabled?: 0
Prefetch: Stats updated every 10 seconds. Time since trigger:0
Prefetch: Trigger cnt: 0
Prefetch Limits: Legacy - 500 11ac - 10000 300000
AP1#
Directory of flash:/
2 -rwx 1081 Apr 21 1993 17:14:56 -07:00 private-config
3 -rwx 4 Jun 17 1993 10:01:29 -07:00 FOC1916198P
4 drwx 2496 Dec 31 1969 16:10:00 -08:00 ap3g2-k9w7-mx.153-3.JF
244 -rwx 264 Feb 28 1993 16:00:31 -08:00 env_vars
245 -rwx 1048 Apr 21 1993 17:14:56 -07:00 private-multiple-fs
246 -rwx 168131 Apr 2 1993 07:10:44 -07:00 event.r1
247 -rwx 64 Mar 11 1993 23:26:34 -08:00 sensord_CSPRNG0
248 -rwx 64 Mar 11 1993 23:26:34 -08:00 sensord_CSPRNG1
249 -rwx 87924 Mar 11 1993 23:26:39 -08:00 event.log
250 -rwx 2622 Apr 21 1993 17:14:56 -07:00 config.txt
40900608 bytes total (26945024 bytes free)
no ip address
ssid A
antenna gain 0
peakdetect
dfs band 3 block
stbc
channel width 80
channel dfs
station-role root
Hi Sandeep,
I'm fairly new to this so can you please show me how to make those changes? Should I do it through the command console or the web gui?
Thanks!
Hi Sandeep,
 Thanks!
Ok, I was to configure dfs band 3 block via command line but not sure how to remove channel width 80.
! Last configuration change at 04:19:06 -0700 Tue Jun 22 1993
version 15.3
no service pad
hostname AP1
enable secret 5
no aaa new-model
no ip source-route
no ip cef
ip domain name
dot11 syslog
dot11 ssid A
authentication open
guest-mode
wpa-psk ascii 7
no ipv6 cef
bridge irb
no ip address
ssid A
antenna gain 0
stbc
speed basic-1.0 basic-2.0 basic-5.5 basic-11.0 basic-6.0 basic-9.0 basic-12.0 basic-18.0 basic-24.0 basic-36.0 basic-48.0 basic-54.0 m0. m1. m2. m3. m4. m5. m6. m7. m8. m9. m10. m11. m12. m13. m14. m15. m16. m17. m18. m19. m20. m21. m22. m23.
station-role root
bridge-group 1
no ip address
ssid A
antenna gain 0
peakdetect
dfs band 3 block
stbc
channel width 80
channel dfs
station-role root
bridge-group 1
no ip address
duplex auto
speed auto
bridge-group 1
interface BVI1
ipv6 address dhcp
ip http server
ip ssh version 1
bridge 1 route ip
line con 0
line vty 0 4
login local
length 0
transport input all
config t
channel width 20
-Scott
Hi Scott,
Is it recommended to set channel width to be 20 on 5ghz or should I set it for above 40mhz? Thank you for help!
It depends on your environment. Try 40 then try 20.
-Scott
config t
channel 36
end
You obviously don't have NTP configured so timestamps are meaningless and therefore hard to tell when anything happened but regarding:
"more event.r1" will display the contents of that event log and might give some clue to the problem (eg radio may have crashed and not recovered or encountered a hardware issue).
Hi Everyone,
I've been trying to locate the new software to update my access point. I'm currently using version 153-3.JI3. I think that and a combination of turn on band 3 block might have fixed it for me. Clients are able to connect to the 5ghz network now.
Thank you everyone for your help!
Em
