Cisco AP 2802I won't join WCL 2504
adnanimarwane1
Hi All,
Cisco AP 2802I-I-K9, AP Running Image 8.2.141.0, Couldn't joint with WLC-2504 software version 8.2.141.0.But AP 2602I,1702I and 3602I can register with WLC and working fine.  getting below error from the AP2802I
[*04/20/2017 08:02:34.7021] Discovery Request sent to 255.255.255.255 with discovery type set to CAPWAP_DISCOVERY_TYPE_UNKNOWN(0)
[*04/20/2017 08:02:34.7024] Discovery Response from 10.97.41.67
[*04/20/2017 08:02:35.0001] Discovery Response from 10.97.41.67
[*04/20/2017 08:02:35.0000] CAPWAP State: DTLS Setup
[*04/20/2017 08:02:36.6481] CAPWAP State: Join
[*04/20/2017 08:02:36.6491] Sending Join request to 10.97.41.67 through port 5256
[*04/20/2017 08:02:41.3344] Join Response from 10.97.41.67
[*04/20/2017 08:02:41.3345] CAPWAP State: Image Data
[*04/20/2017 08:02:41.3346] CAPWAP State: Configure
[*04/20/2017 08:02:41.3590] DTLS: packet too old or a replay distance=0, this_seq_num=1, last_seq_num=1
[*04/20/2017 08:03:26.9426] GOING BACK TO DISCOVER MODE
[*04/20/2017 08:03:26.9429] CAPWAP State: DTLS Teardown
[*04/20/2017 08:03:31.6948] CAPWAP State: Discovery
[*04/20/2017 08:03:31.6959] Discovery Request sent to 10.97.41.67 with discovery type set to CAPWAP_DISCOVERY_TYPE_STATIC_CONFIG(1)
[*04/20/2017 08:03:41.7124] Discovery Request sent to 10.97.41.67 with discovery type set to CAPWAP_DISCOVERY_TYPE_STATIC_CONFIG(1)
[*04/20/2017 08:03:41.7143] Discovery Request sent to 255.255.255.255 with discovery type set to CAPWAP_DISCOVERY_TYPE_UNKNOWN(0)
[*04/20/2017 08:03:41.7145] Discovery Response from 10.97.41.67
[*04/20/2017 08:03:42.0002] Discovery Response from 10.97.41.67
[*04/20/2017 08:03:42.0000] CAPWAP State: DTLS Setup
[*04/20/2017 08:03:43.6641] CAPWAP State: Join
[*04/20/2017 08:03:43.6651] Sending Join request to 10.97.41.67 through port 5256
[*04/20/2017 08:03:48.3266] Join Response from 10.97.41.67
[*04/20/2017 08:03:48.3267] CAPWAP State: Image Data
[*04/20/2017 08:03:48.3267] CAPWAP State: Configure
[*04/20/2017 08:03:48.3486] DTLS: packet too old or a replay distance=0, this_seq_num=1, last_seq_num=1
[*04/20/2017 08:04:33.9369] GOING BACK TO DISCOVER MODE
[*04/20/2017 08:04:33.9372] CAPWAP State: DTLS Teardown
[*04/20/2017 08:04:38.6892] CAPWAP State: Discovery
[*04/20/2017 08:04:38.6903] Discovery Request sent to 10.97.41.67 with discovery type set to CAPWAP_DISCOVERY_TYPE_STATIC_CONFIG(1)
[*04/20/2017 08:04:48.7026] Discovery Request sent to 10.97.41.67 with discovery type set to CAPWAP_DISCOVERY_TYPE_STATIC_CONFIG(1)
[*04/20/2017 08:04:48.7036] Discovery Request sent to 255.255.255.255 with discovery type set to CAPWAP_DISCOVERY_TYPE_UNKNOWN(0)
[*04/20/2017 08:04:48.7039] Discovery Response from 10.97.41.67
[*04/20/2017 08:04:48.0001] Discovery Response from 10.97.41.67
[*04/20/2017 08:04:48.0000] CAPWAP State: DTLS Setup
[*04/20/2017 08:04:49.6474] CAPWAP State: Join
[*04/20/2017 08:04:49.6484] Sending Join request to 10.97.41.67 through port 5256
[*04/20/2017 08:04:54.3316] Join Response from 10.97.41.67
[*04/20/2017 08:04:54.3317] CAPWAP State: Image Data
[*04/20/2017 08:04:54.3317] CAPWAP State: Configure
[*04/20/2017 08:04:54.3558] DTLS: packet too old or a replay distance=0, this_seq_num=1, last_seq_num=1
[*04/20/2017 08:05:39.9426] GOING BACK TO DISCOVER MODE
[*04/20/2017 08:05:39.9429] CAPWAP State: DTLS Teardown
[*04/20/2017 08:05:44.6949] CAPWAP State: Discovery
[*04/20/2017 08:05:44.6960] Discovery Request sent to 10.97.41.67 with discovery type set to CAPWAP_DISCOVERY_TYPE_STATIC_CONFIG(1)
[*04/20/2017 08:05:54.7087] Discovery Request sent to 10.97.41.67 with discovery type set to CAPWAP_DISCOVERY_TYPE_STATIC_CONFIG(1)
[*04/20/2017 08:05:54.7120] Discovery Request sent to 255.255.255.255 with discovery type set to CAPWAP_DISCOVERY_TYPE_UNKNOWN(0)
[*04/20/2017 08:05:54.7122] Discovery Response from 10.97.41.67
[*04/20/2017 08:05:55.0001] Discovery Response from 10.97.41.67
[*04/20/2017 08:05:55.0000] CAPWAP State: DTLS Setup
[*04/20/2017 08:05:56.6446] CAPWAP State: Join
[*04/20/2017 08:05:56.6456] Sending Join request to 10.97.41.67 through port 5256
[*04/20/2017 08:06:01.3290] Join Response from 10.97.41.67
[*04/20/2017 08:06:01.3290] CAPWAP State: Image Data
[*04/20/2017 08:06:01.3291] CAPWAP State: Configure
[*04/20/2017 08:06:01.3555] DTLS: packet too old or a replay distance=0, this_seq_num=1, last_seq_num=1
[*04/20/2017 08:06:46.9392] GOING BACK TO DISCOVER MODE
[*04/20/2017 08:06:46.9395] CAPWAP State: DTLS Teardown
[*04/20/2017 08:06:51.6915] CAPWAP State: Discovery
[*04/20/2017 08:06:51.6925] Discovery Request sent to 10.97.41.67 with discovery type set to CAPWAP_DISCOVERY_TYPE_STATIC_CONFIG(1)
[*04/20/2017 08:07:01.7050] Discovery Request sent to 10.97.41.67 with discovery type set to CAPWAP_DISCOVERY_TYPE_STATIC_CONFIG(1)
[*04/20/2017 08:07:01.7061] Discovery Request sent to 255.255.255.255 with discovery type set to CAPWAP_DISCOVERY_TYPE_UNKNOWN(0)
[*04/20/2017 08:07:01.7063] Discovery Response from 10.97.41.67
[*04/20/2017 08:07:02.0001] Discovery Response from 10.97.41.67
[*04/20/2017 08:07:02.0000] CAPWAP State: DTLS Setup
[*04/20/2017 08:07:03.6600] CAPWAP State: Join
[*04/20/2017 08:07:03.6610] Sending Join request to 10.97.41.67 through port 5256
[*04/20/2017 08:07:08.3315] Join Response from 10.97.41.67
[*04/20/2017 08:07:08.3315] CAPWAP State: Image Data
[*04/20/2017 08:07:08.3316] CAPWAP State: Configure
[*04/20/2017 08:07:08.3562] DTLS: packet too old or a replay distance=0, this_seq_num=1, last_seq_num=1
some help would be great.
thanks in advance.
Marouane
It might be an issue with the configured country. On the WLC it's France (or I confuse it with the location BLE), while your AP is an -I model, meaning it's not allowed for France.
See here: http://www.cisco.com/c/dam/assets/prod/wireless/wireless-compliance-tool/index.html
Just search for -i to find all Countries allowed for an -i AP.
It might also be something else entirely, can you output the console log of the AP while it's booting and trying to join the controller?
8 Replies 8
Sandeep Choudhary
Paste the output of these commands:
sh sysinfo from WLC
sh version from AP
I will recommend to upgrade the SW version to the stable version: 8.2.151.0
https://software.cisco.com/download/release.html?mdfid=283848165&flowid=24841&softwareid=280926587&release=8.0.140.0&relind=AVAILABLE&rellifecycle=ED&reltype=latest
Dont forget to rate helpful posts
Hi Sandeep,
i already upgrade the WLC to the version 8.2.151.0, it didn't help and the problem still the same.
please find attached the outputs that you demanded.
thank you.
You have wrong Regularity domain AP"AP 2802I-I-K9". (Its for Egypt)
You are in Europe and It must be AP 2802I-E-K9. (E means Europe)
Please check with your supplier and change it.
Hi patoberli,
thanks for your response, i will check the Regularity domain with our Presales service.
please find attached the output that demanded.
best regards.
MArouane
Thanks. I'm fairly sure it's caused by the wrong regulatory domain of the AP.
the problem was caused by a regulatory domain mismatch as you said.
you have to add the country that supports -I regulatory domain on the WLC configuration.
thanks a lot guys.
Marouane.
Hi Marouane
If you plan to use the -I AP in France, trade it for an -E model, or you might get in conflict with the local authority if you use channels/transmit power that isn't allowed in France.
