Cisco AP1852 AIR-PWR-C
ryosaeba86
Hi all,
my question does not concern the configuration of the device but I need technical information regarding the power supply connector that have be inserted into the AP to power it.
Basically I need to know what kind of connector it is.
is it possible to find this information?
If the information is not in any of the data sheets, there is no way we would know also.  So we are in the same boat.
A bit of searching, this is the only thing I could find.
-Scott
8 Replies 8
balaji.bandi
here is the installation guide show you DC connector :
https://www.cisco.com/c/en/us/td/docs/wireless/access_point/1850/hardware/guide/ap1850hwguide.html#pgfId-68800
You can see the product :
https://www.amazon.co.uk/CISCO-SYSTEMS-AIR-PWR-C-Cisco-Accessories/dp/B00OYZJICI
Hope you looking external Power source, if you using PoE ,Ethernet can do that work, if you have PoE switch
is this what you looking ?
BB
I appreciate your reply.
I need only this connector information.
As I can powered the APs only through an AC / DC already present.
you can use power supply SKU AIR-PWR-C=. this supports 1850 series. connector type called coaxial connector.
https://www.cisco.com/c/en/us/products/collateral/wireless/aironet-1850-series-access-points/datasheet-c78-734256.html#Productspecifications
also you can use power injector so you can connect injector to power source and up AP from that via PoE.
AIR-PWRINJ5= is compatible.
Good luck
KB
Maybe I did not explain it clear enough.
I know this is the model (it's written in the title).
I am only looking for the coaxial connector .. but to buy it I need the technical specifications.
-Scott
are you looking for only connector ? I do not believe you get seperate connector ? may be check local market.
BB
Yes, only the connector. I know that i can't get it as spare part. But for the purchase it on local market I need the technical specifications.
Either you google the connectors you may get near by (never had this requirement before) ot take the picture and show local market can help you.
BB
