CLI Command for CW9166 Access Point
madhurimuppalla
Is there any CLI command in CW9166 AP to enable, disable and read the sensor data such as temperature, humidity,
air-quality from the built-in sensors?
Leo Laohoo
@madhurimuppalla wrote:
read the sensor data such as temperature, humidity,air-quality from the built-in sensors?
From the WLC:
test platform software database get ewlc_oper/ap_temp;ap_mac=aaaabbbbcccc
test platform software database get ewlc_oper/ap_air_quality;ap_mac=aaaabbbbcccc
 NOTE:
1.  The sensors can only work when DNA Spaces have "seen" the APs.  Without DNA Spaces, the sensors will be disabled.
2.  The two commands are present in 17.9.X & 17.12.1 but they are absent in 17.6.4.
From the AP, try:
sh thermal-control-summary
 NOTE:
1.  This command should be available without DNA Spaces.
2.  Take note of CSCwh60483 & CSCwk74648.
Leo Laohoo
From the WLC:
 NOTE:
From the AP, try:
 NOTE:
Is there any CLI commands in CW9166 AP to check the status of Monitor Radio, BLE, AP power consumption details and also  sensor data like  humidity, air-quality from build-in sensors?
Most of the information can get from Parent WLC what you looking if the AP register with WLC.
you can refer below thread :
https://community.cisco.com/t5/wireless/cli-command-for-cw9166-access-point/td-p/4951803
BB
Has the 9166 been added to DNA Spaces yet?
