Guest Portal issue
ittechk4u1
Level 4
Level 4
Hello Experts,
I am facing an issue with guest portal(Customized) which is on cisco WLC..
Virtual interface IP: 1.1.1.1
DNS host name: guest.xyz.com
Issue: Portal pops up on mobile or laptop and then disappears after 5 seconds.
What could be the reason ?
Thanks in advance
2 Accepted Solutions
did you installed SSL cert properly ?
did you change the virtual IP address to 192.0.2.1 ?
Dont forget to rate helpful posts
I can only see the issue here with cert!!
Ok can you upload a new wildcard certificate and test again ?
Dont forget to arte helpful posts
13 Replies 13
Mark Elsen
 - Check the portals-connected webserver-logs , specially error-logging.
 M.
-- Let everything happen to you
       Beauty and terror
      Just keep going
       No feeling is final
Reiner Maria Rilke (1899)
Portal is on WLC itself.
I tried to to debug on wlc but there are no logs!!
 - As I recall the mentioned virtual ip is discouraged these days :
                https://en.wikipedia.org/wiki/1.1.1.1
 M.
       Beauty and terror
      Just keep going
       No feeling is final
frost_michael
Change 1.1.1.1 to 192.0.2.1 but I dont think that's the issue -  check your pre-auth ACLs to make sure they block connectivity - the device web connectivity test may be able to reach their self-check server IP and close the portal down because it thinks they have internet access.
There is no pre auth. I am using portal on WLC itself and user auth on cisco ise.
ittechk4u1
Level 4
Level 4
Update: I changed the virtual IP address to 192.0.2.1  and still issue persist..
Any solution ?
any ideas ?
yes I installed SSL certificate one year ago and it was working till 3 weeks ago!!
yes I also changed the virtual ip address to 192.0.2.1 but still problem is there.
What else I can do to resolve the issue ?
Ok I will try to upload a new certificate and get back to you.
Thank you!
Hi Sandeep,
I updated the new wildcard certificate on WLC and now problem resolved.
I got to know that old certificate was invoked due to some reasons.
Thanks for your help.
Glad to help.
Thanks for rating
