A9K-RSP880-LT-SE front bezel FAIL light is on with IOX XR 7.3.2
nesttech1
We have upgraded the A9K-RSP880-LT-SE processors with the IOS XR 7.3.2
They seem to boot fine in our ASR-9006-AC-V2 chassis, and we do not see any errors.
Also, all of the FPDs are upgraded to the required current IOS version.
However, the red FAIL light is ON on the front bezel.
Is there anything that we need to check or upgrade, so that this FAIL light is not on?
Garry Peirce
I also had two RSPs showing the same System Scoped Alarm error.
"Error in device/link [10b5:8749 09:05.0]: Pcie uncorrectable surprise down error"
I note the numbers are the exact same and match yours as well.
Reseating the affected RSPs did not resolve the issues.
Replacing one with a spare on hand did clear it.
Through a case with lab confirmation, this has been determined to be an FPD bug, cosmetic and non-service affecting.  I do not have the bug ID yet.
8 Replies 8
tkarnani
Can we check power modules?
"show environment power" it may not have enough power for N+1 power redundancy
thanks
We are testing this router without any line cards and it has 4 x PWR-3KW-AC-V2 units installed, so there is plenty of power.
While booting, we do not see any significant error messages except for redundancy until both RSPs get synced.
Here is the output showing power capacity
sysadmin-vm:0_RSP0# sh environment power
Wed Dec  29 19:31:32.256 UTC+00:00
CHASSIS LEVEL POWER INFO: 0
   Total output power capacity (N + 1)             :    9000W +    3000W
   Total output power required                     :    1180W
   Total power input                               :     948W
   Total power output                              :     478W
Power Shelf 0:
   Power       Supply     ------Input----   ------Output---      Status
   Module      Type        Volts     Amps    Volts     Amps
   0/PT0-PM0   3kW-AC      237.8      1.2     55.7      3.1    OK
   0/PT0-PM1   3kW-AC      237.2      0.8     55.6      1.6    OK
   0/PT0-PM2   3kW-AC      237.0      1.2     55.5      2.7    OK
   0/PT0-PM3   3kW-AC      236.1      0.8     55.5      1.2    OK
Total of Power Shelf 0:        948W/  4.0A       478W/  8.6A
   Location     Card Type            Power       Power       Status
                                     Allocated   Used
                                     Watts       Watts
   0/0                 -                10           -       RESERVED
   0/1                 -                10           -       RESERVED
   0/2                 -                10           -       RESERVED
   0/3                 -                10           -       RESERVED
   0/RSP0       A9K-RSP880-LT-SE       295         168       ON
   0/RSP1       A9K-RSP880-LT-SE       295         174       ON
   0/FT0        ASR-9006-FAN-V2        275           -       ON
   0/FT1        ASR-9006-FAN-V2        275           -       ON
sysadmin-vm:0_RSP0#
great,
what about "show alarms brief" anything alarming there?
thanks
Looks like we may need to do a "forced" FPD upgrade.  Here is the output showing all alarms.
RP/0/RSP0/CPU0:ios#sh alarms brief
Wed Dec 29 20:20:12.209 UTC
Active Alarms for 0/RSP0
No entries.
History Alarms for 0/RSP0
Location        Severity     Group            Set Time                   Description
                                              Clear Time
0/RSP0/CPU0     Major        Software         12/29/2021 18:22:31 UTC    Node Not Ready
                                              12/29/2021 18:25:30 UTC
Suppressed Alarms for 0/RSP0
No entries.
Conditions for 0/RSP0
No entries.
System Scoped Active Alarms
0/RSP0          Major        FPD_Infra        12/29/2021 18:20:25 UTC    IPU-FPGA: Golden FPGA is below minimum version, Perform force fpd upgrade
0/RSP0          Major        FPD_Infra        12/29/2021 18:20:25 UTC    IPU-FSBL: Golden FPGA is below minimum version, Perform force fpd upgrade
0/RSP0          Major        FPD_Infra        12/29/2021 18:20:25 UTC    IPU-Linux: Golden FPGA is below minimum version, Perform force fpd upgrade
0/RSP1          Major        FPD_Infra        12/29/2021 18:20:27 UTC    IPU-FPGA: Golden FPGA is below minimum version, Perform force fpd upgrade
0/RSP1          Major        FPD_Infra        12/29/2021 18:20:27 UTC    IPU-FSBL: Golden FPGA is below minimum version, Perform force fpd upgrade
0/RSP1          Major        FPD_Infra        12/29/2021 18:20:27 UTC    IPU-Linux: Golden FPGA is below minimum version, Perform force fpd upgrade
0/RSP0          Major        Cpu              12/29/2021 18:21:39 UTC    Error in device/link [10b5:8749 09:05.0]: Pcie uncorrectable surprise down error
System Scoped History Alarms
                                              Clear Time
0/RSP0/CPU0     Critical     Software         12/28/2021 23:39:37 UTC    Redundancy Partner Not Present
                                              12/28/2021 23:46:04 UTC
0/RSP0/CPU0     Major        Software         12/28/2021 23:46:04 UTC    Node Not Ready
                                              12/28/2021 23:47:53 UTC
0/PT0-PM2       Major        Environ          12/29/2021 18:27:52 UTC    Power Module Output Disabled (PM_OUTPUT_EN_PIN_HI).
0/PT0-PM2       Major        Environ          12/29/2021 18:28:53 UTC    Power Module Output Disabled (PM_OUTPUT_EN_PIN_HI).
0/PT0-PM3       Major        Environ          12/29/2021 18:29:03 UTC    Power Module Output Disabled (PM_OUTPUT_EN_PIN_HI).
Active Alarms (brief) for EDT
RP/0/RSP0/CPU0:ios#
We have done the forced FPD upgrades for these
After doing the upgrade the front bezel lights went off, but reappeared again after we did a system reboot
The following alarms are still present:
0/RSP1          Major        Cpu              12/30/2021 05:17:59 UTC    Error in device/link [10b5:8749 09:05.0]: Pcie uncorrectable surprise down error
0/RSP0          Major        Cpu              12/30/2021 05:18:02 UTC    Error in device/link [10b5:8749 09:05.0]: Pcie uncorrectable surprise down error
Do you have any recommendation about getting rid of these "  Pcie uncorrectable surprise down error "        ??
Thank you.
I've no answer but just chiming in that after upgrading two 9906s to 7.3.2, I have RSPs showing the same System Scoped Alarm error.
I note the numbers are the exact same on two different disparate routers and match yours as well.
There appears no functional/traffic issue for us, just the flagged alarm.
I've opened a case and will see where it leads.
Garry Peirce
We have noticed that this alarm below is intermittent
Sometimes the system boots just fine without this alarm and then after the system is powered down and re-booted, this alarm appears again.
This does not seem to affect the operation of the system.
Hopefully, this cosmetic bug will be resolved in some future release.
