Activating Multicast on an ASR9k router
marhifer2003
I need to configure multicast on an ASR9k router  I think I have to download and activate the corresponding .pie file (asr9k-mcast-p-4.1.0) but I do not find this file in cisco.com
The "show install inactive summary" command shows no software packets inactives.
The "show install active summary" shows active only the asr9k-mini-p-4.1.0 packet.
Could anyone upload the file or paste the link  to download the .pie file for activating multicast routing on ASR9K platform?
Thank you in advance.
Vadim Zhovtanyuk
Hi  marhifer2003
You need to download the tar file which contain the multicast pie
http://www.cisco.com/cisco/software/release.html?mdfid=282423206&flowid=2138&softwareid=280805694&release=4.2.0&relind=AVAILABLE&rellifecycle=&reltype=latest
There is no separate multicast pie file on CCO
Then you can untar it find the multicast pie and add/activate it on your router.
vadim
7 Replies 7
Vadim Zhovtanyuk
Hi  marhifer2003
vadim
Vadim, thank you very much for your answer.
I can not download the file.... It seems I have no rights to download this file.... Is there any other way to obtain this file?
Vadim Zhovtanyuk
Hi again,
ths link seems to be on completely right
You may go to the SW center on CCO, choose ASR9000 as the platform and then choose the right release.
http://www.cisco.com/cisco/software/navigator.html
vadim
you can open a TAC case and ask for the assistance with downloading the file.
The other way is to publish the multicast pie for you.
To we need to know your CCO user id.
If you can let me know about your CCO user id I can publish the multicast pie for you on CCO in
publishing seciton.
vadim
marhifer2003
Could anyone publish the mcast.pie file (version 4.1.2) for me, please?
Hi Marcos,
Sorry for delay I'm out of the office now,
I will reply to you in private discussion in few minutes
wbr
/vadim
Thank you Vadim
You have saved my life!!
Sorry for the inconvenience.
