ASR9K install add fails when 0/RSP1/CPU0 is in bringdown state
heleon
Hello Experts
I have attempted to install the sp4 (asr9k-px-5.3.3.sp4.tar)for IOS XR 5.3.3 in AR9006
However the install fails with a message about the state of 0/RSP1/CPU0.
Can I install the SP4 in spite of the status of 0/RSP1/CPU0?
Thanks in advance for your help below is the console log.
Thank you in advance for your help.
RP/0/RSP0/CPU0:ASR9006-2(admin)# install add disk0:asr9k-px-5.3.3.sp4.tar
Wed Feb 22 01:02:09.476 UTC
Install operation 20 '(admin) install add /disk0:asr9k-px-5.3.3.sp4.tar'
started by user 'root' via CLI at 01:02:09 UTC Wed Feb 22 2017.
RP/0/RSP0/CPU0:Feb 22 01:02:09.887 : instdir[254]: %INSTALL-INSTMGR-3-INSTALL_OPERATION_USER_ERROR : User error occurred during install operation 20. See 'show install log 20 detail' for more infError:    Cannot proceed with the add operation because the following node is
ormation.
Error:    not ready
Error:        0/RSP1/CPU0
Error:    Suggested steps to resolve this:
Error:     - repeat the operation once '(admin) show platform' shows the
Error:       specified node is in IOS-XR RUN state.
Install operation 20 failed at 01:02:09 UTC Wed Feb 22 2017.
Best regards
Hector Leon
12 Replies 12
smilstea
You won't be able to install with the router in this state.
Sam
smailmilak
Enthusiast
Enthusiast
Hi Hector,
your priority should be RSP1 for now. Use these commands and give us the output.
1. admin show install log 20 detail
2. admin show platform sum loc 0/RSP1/CPU0
3. show redundancy
4. show environment leds location 0/RSP1/CPU0
Hi!
Thanks for your interest!
Below is the output for the commands
I will be paying attention to your comments.
Thanks in advance!
Best regards
Hector Leon
1. show install log 20 detail
RP/0/RSP0/CPU0:ASR9006-2#sh install log 20 detail
Wed Feb 22 17:47:42.075 UTC
Install operation 20 started by user 'root' via CLI at 01:02:09 UTC Wed Feb 22
2017.
Install logs:
    Error:    is not ready
    Error:        0/RSP1/CPU0
RP/0/RSP0/CPU0:ASR9006-2#RP/0/RSP0/CPU0:Feb 22 17:47:45.514 : devc-conaux[59]: %MGBL-ST16550-3-ISR_MSR_ERR : Too many console line state change interrupts
2.admin show platform sum loc 0/RSP1/CPU0
RP/0/RSP0/CPU0:ASR9006-2#admin show platform sum loc 0/RSP1/CPU0
Wed Feb 22 17:48:51.625 UTC
     Platform Node : 0/RSP1/CPU0 (slot 1)
               PID : A9K-RSP440-SE
         Card Type : ASR9K Fabric, Controller, 12G memory
            VID/SN : V01 / FOC160785Q6
        Oper State : BRINGDOWN
        Last Reset : N/A
                   : N/A
     Configuration : Power is enabled
                     Bootup enabled.
                     Monitoring enabled
        Rommon Ver : N/A
        IOS SW Ver : 5.3.3
        Main Power : Power state Enabled. Estimate power 350 Watts of power required.
            Faults : N/A
RP/0/RSP0/CPU0:ASR9006-2#RP/0/RSP0/CPU0:Feb 22 17:48:55.239 : devc-conaux[59]: %MGBL-ST16550-3-ISR_MSR_ERR : Too many console line state change interrupts
 3 .show redundancy
RP/0/RSP0/CPU0:ASR9006-2#show redundancy
Wed Feb 22 17:49:26.547 UTC
Redundancy information for node 0/RSP0/CPU0:
Node 0/RSP0/CPU0 is in ACTIVE role
Node 0/RSP0/CPU0 has no valid partner
Group            Primary         Backup          Status
dsc              0/RSP0/CPU0     N/A             Not Ready
dlrsc            0/RSP0/CPU0     N/A             Not Ready
central-services 0/RSP0/CPU0     N/A             Not Ready
v4-routing       0/RSP0/CPU0     N/A             Not Ready
netmgmt          0/RSP0/CPU0     N/A             Not Ready
mcast-routing    0/RSP0/CPU0     N/A             Not Ready
mcast-routing    0/RSP0/CPU0     N/A             Not NSR-Ready
v6-routing       0/RSP0/CPU0     N/A             Not Ready
Process Group Details
Current primary rmf state: Not Ready
  <jid>       <node>       <name>      <group> Reason for backup not ready
    398  0/RSP0/CPU0      rmf_svr          dsc No location for backup set
        Not ready set Sat Feb  4 21:42:44 2017: 2 weeks, 3 days, 20 hours, 6 minutes ago
    398  0/RSP0/CPU0      rmf_svr        dlrsc No location for backup set
        Not ready set Sat Feb  4 21:42:45 2017: 2 weeks, 3 days, 20 hours, 6 minutes ago
    398  0/RSP0/CPU0      rmf_svr central-services No location for backup set
        Not ready set Sat Feb  4 21:43:41 2017: 2 weeks, 3 days, 20 hours, 5 minutes ago
    398  0/RSP0/CPU0      rmf_svr   v4-routing No location for backup set
    398  0/RSP0/CPU0      rmf_svr      netmgmt No location for backup set
    398  0/RSP0/CPU0      rmf_svr mcast-routing No location for backup set
    398  0/RSP0/CPU0      rmf_svr   v6-routing No location for backup set
Current primary rmf state for NSR: Not Ready
  <jid>       <node>       <name>      <group> Reason for backup not NSR-ready
   1169  0/RSP0/CPU0         igmp mcast-routing Standby process not converged
       Not ready set Sat Feb  4 21:43:46 2017: 2 weeks, 3 days, 20 hours, 5 minutes ago
   1174  0/RSP0/CPU0          mld mcast-routing Standby process not converged
Reload and boot info
A9K-RSP440-SE reloaded Sat Feb  4 21:41:44 2017: 2 weeks, 3 days, 20 hours, 7 minutes ago
Active node booted Sat Feb  4 21:41:44 2017: 2 weeks, 3 days, 20 hours, 7 minutes ago
Active node reload "Cause: User Initiated reload"
RP/0/RSP0/CPU0:ASR9006-2#RP/0/RSP0/CPU0:Feb 22 17:49:30.336 : devc-conaux[59]: %MGBL-ST16550-3-ISR_MSR_ERR : Too many console line state change interrupts
RP/0/RSP0/CPU0:ASR9006-2#show environment leds location 0/RSP1/CPU0
Wed Feb 22 17:50:05.661 UTC
R/S/I   Modules LED             Status
0/RSP1/*
        host    Critical-Alarm  Off
        host    Major-Alarm     Off
        host    Minor-Alarm     Off
        host    ACO             Off
        host    Fail            Off
Sorry for not noticing that the discussion has "bringdown" in the title.
Give us the output of show logging.
You have a serious issue with RSP1. You could try to re-insert it or maybe
do admin conf ter hw-module power disable location 0/RSP1/CPU0
commit
and then enable power again.
Copy the logs when you do this and paste it here.
It is possible that you need to replace the RSP module.
Hi!
Thank you for your comments we attempted power disable and IOS XR indicates :
Stop is not supported on this node.
Reloading the card indicates failure and then bringdown.
We will re-seat the line card.
RP/0/RSP0/CPU0:ASR9006-2(admin)#hw-module location 0/RSP1/CPU0 stop
Wed Feb 22 19:41:47.963 UTC
WARNING: This will take the requested node out of service.
Do you wish to continue? [confirm(y/n)]y
RP/0/RSP0/CPU0:ASR9006-2(admin)#show platform
Wed Feb 22 19:42:01.828 UTC
Node            Type                      State            Config State
0/RSP0/CPU0     A9K-RSP440-SE(Active)     IOS XR RUN       PWR,NSHUT,MON
0/RSP1/CPU0     A9K-RSP440-SE(Standby)    BRINGDOWN        PWR,NSHUT,MON
0/FT0/SP        ASR-9006-FAN              READY
0/FT1/SP        ASR-9006-FAN              READY
0/0/CPU0        A9K-24x10GE-SE            IOS XR RUN       PWR,NSHUT,MON
0/1/CPU0        A9K-MOD160-SE             IOS XR RUN       PWR,NSHUT,MON
0/1/0           A9K-MPA-4X10GE            OK               PWR,NSHUT,MON
0/2/CPU0        A9K-2T20GE-B              IOS XR RUN       PWR,NSHUT,MON
0/3/CPU0        A9K-MOD80-TR              IOS XR RUN       PWR,NSHUT,MON
0/3/1           A9K-MPA-20X1GE            OK               PWR,NSHUT,MON
0/PM0/0/SP      A9K-3KW-AC                FAILED           PWR,NSHUT,MON
0/PM0/1/SP      A9K-3KW-AC                READY            PWR,NSHUT,MON
0/PM0/2/SP      A9K-3KW-AC                READY            PWR,NSHUT,MON
Yeah right, it's not possible to disable power on RSP or RP.
Let us know after you are done with re-insert of RSP1 and give us the logs.
Do you have noticed that power supply in PM0/0 has failed?
Hello Team
I used Cisco power calculator and two Power Supplies with 3000W it should be enough.
Below the logs after re-seat the RSP in bringdown.
Thanks in advance.
RP/0/RSP0/CPU0:Feb 23 19:47:32.932 : shelfmgr[410]: %PLATFORM-SHELFMGR-6-NODE_STATE_CHANGE : 0/RSP1/CPU0 A9K-RSP440-SE state:PRESENT
RP/0/RSP0/CPU0:Feb 23 19:47:33.003 : invmgr[257]: %PLATFORM-INV-6-OIRIN : OIR: Node 0/RSP1/CPU0 Sn: FOC160785Q6 inserted
RP/0/RSP0/CPU0:Feb 23 19:50:02.421 : shelfmgr[410]: %PLATFORM-SHELFMGR-3-FSMTIMEOUT_RESET : Node 0/RSP1/CPU0 is reset due to failed bootup. Node state was: 1 Timeout ID: 10
RP/0/RSP0/CPU0:Feb 23 19:50:02.439 : canb-server[153]: %PLATFORM-CANB_SERVER-7-CBC_PRE_RESET_NOTIFICATION : Node 0/RSP1/CPU0 , Power Cycle (0x05000000)
RP/0/RSP0/CPU0:Feb 23 19:50:02.440 : shelfmgr[410]: %PLATFORM-SHELFMGR-6-NODE_STATE_CHANGE : 0/RSP1/CPU0 A9K-RSP440-SE state:ROMMON
RP/0/RSP0/CPU0:Feb 23 19:52:24.905 : canb-server[153]: %PLATFORM-CANB_SERVER-7-CBC_PRE_RESET_NOTIFICATION : Node 0/RSP1/CPU0 , DB Power Failure (0x0f000000)
RP/0/RSP0/CPU0:Feb 23 19:52:24.905 : canb-server[153]: %PLATFORM-CANB_SERVER-3-ALARM_INDICATION : Raise alarm from CBC in slot 0/RSP1/CPU0, alarm code CBC_ALRM_RSP_DB_PWR_FAILED
RP/0/RSP0/CPU0:Feb 23 19:52:24.906 : shelfmgr[410]: %PLATFORM-SHELFMGR-6-NODE_STATE_CHANGE : 0/RSP1/CPU0 A9K-RSP440-SE state:BRINGDOWN
RP/0/RSP0/CPU0:Feb 23 19:52:24.908 : invmgr[257]: %PLATFORM-INV-6-NODE_STATE_CHANGE : Node: 0/RSP1/CPU0, state: BRINGDOWN
RP/0/RSP0/CPU0:Feb 23 19:52:52.550 : canb-server[153]: %PLATFORM-CANB_SERVER-3-ALARM_CLEARED : Clear alarm from CBC in slot 0/RSP1/CPU0, alarm code CBC_ALRM_RSP_DB_PWR_FAILED
RP/0/RSP0/CPU0:Feb 23 19:54:54.962 : shelfmgr[410]: %PLATFORM-SHELFMGR-3-FSMTIMEOUT_RESET : Node 0/RSP1/CPU0 is reset due to failed bootup. Node state was: 7 Timeout ID: 10
RP/0/RSP0/CPU0:Feb 23 19:54:54.991 : canb-server[153]: %PLATFORM-CANB_SERVER-7-CBC_PRE_RESET_NOTIFICATION : Node 0/RSP1/CPU0 , Power Cycle (0x05000000)
RP/0/RSP0/CPU0:Feb 23 19:57:19.101 : canb-server[153]: %PLATFORM-CANB_SERVER-7-CBC_PRE_RESET_NOTIFICATION : Node 0/RSP1/CPU0 , DB Power Failure (0x0f000000)
RP/0/RSP0/CPU0:Feb 23 19:57:19.101 : canb-server[153]: %PLATFORM-CANB_SERVER-3-ALARM_INDICATION : Raise alarm from CBC in slot 0/RSP1/CPU0, alarm code CBC_ALRM_RSP_DB_PWR_FAILED
RP/0/RSP0/CPU0:Feb 23 19:57:58.731 : canb-server[153]: %PLATFORM-CANB_SERVER-3-ALARM_CLEARED : Clear alarm from CBC in slot 0/RSP1/CPU0, alarm code CBC_ALRM_RSP_DB_PWR_FAILED
RP/0/RSP0/CPU0:Feb 23 20:27:20.854 : canb-server[153]: %PLATFORM-CANB_SERVER-7-CBC_PRE_RESET_NOTIFICATION : Node 0/RSP1/CPU0 , WDOG SReset (0x06000000)
RP/0/RSP0/CPU0:Feb 23 20:27:36.895 : canb-server[153]: %PLATFORM-CANB_SERVER-7-CBC_PRE_RESET_NOTIFICATION : Node 0/RSP1/CPU0 , WDOG HReset (0x07000000)
RP/0/RSP0/CPU0:Feb 23 20:27:37.891 : canb-server[153]: %PLATFORM-CANB_SERVER-7-CBC_PRE_RESET_NOTIFICATION : Node 0/RSP1/CPU0 , WDOG Power Cycle (0x08000000)
RP/0/RSP0/CPU0:Feb 23 20:30:07.367 : canb-server[153]: %PLATFORM-CANB_SERVER-7-CBC_PRE_RESET_NOTIFICATION : Node 0/RSP1/CPU0 , DB Power Failure (0x0f000000)
RP/0/RSP0/CPU0:Feb 23 20:30:07.367 : canb-server[153]: %PLATFORM-CANB_SERVER-3-ALARM_INDICATION : Raise alarm from CBC in slot 0/RSP1/CPU0, alarm code CBC_ALRM_RSP_DB_PWR_FAILED
RP/0/RSP0/CPU0:Feb 23 20:30:33.007 : canb-server[153]: %PLATFORM-CANB_SERVER-3-ALARM_CLEARED : Clear alarm from CBC in slot 0/RSP1/CPU0, alarm code CBC_ALRM_RSP_DB_PWR_FAILED
RP/0/RSP0/CPU0:Feb 23 21:02:51.636 : canb-server[153]: %PLATFORM-CANB_SERVER-3-ALARM_INDICATION : Raise alarm from CBC in slot 0/RSP1/CPU0, alarm code CBC_ALRM_RSP_DB_PWR_FAILED
 RP/0/RSP0/CPU0:Feb 23 21:03:07.270 : canb-server[153]: %PLATFORM-CANB_SERVER-3-ALARM_CLEARED : Clear alarm from CBC in slot 0/RSP1/CPU0, alarm code CBC_ALRM_RSP_DB_PWR_FAILED
heleon
We will replace the RSP1
Best regards
It's clearly a case for Cisco TAC.
Please check also the failed power supply.
And btw. I see that you want to activate SP4 for 5.3.3.
Our recommendation is to activate 5.3.4 and SP1 for this version (if it's available)!!!
You can do it now, just remove RSP1 from the chassis and the activation process should be ok.
Thank You!
We removed the RSP1 and installed the PIE and SP.
Also we requested the replace and we will  install the new RSP1 as soon as possible.
Thank you again for your valuable help and comments.
Best regards
Can we do "hw-module location 0/rsp1/CPU0 reload" instead of remove and re-insert the standby RSP?
Thank you
Yes you can reload the RSP via that command, the thing you can't do is power disable a RSP.
Sam
Recognize Your Peers
