ASR9K - PIM Snooping
Pedro Morais
Hello all,
I would like to know if ASR9K supports PIM snooping (couldn't find any reference in documentation). If not, will it be supported?
Thanks!
Pedro
Vadim Zhovtanyuk
Hi Pedro,
PIM snooping is not supported on ASR9K yet, but it is in roadmap.
Unfortunately, can not give you the exact releas in which the feature will be supported yet.
wbr
/vadim
Vadim Zhovtanyuk
Hi Pedro,
wbr
/vadim
Is there any workaround?  it's very useful for EVPN and VPLS when you have PIM routers run on top of the EVPN.
