BNG support for A9K-2X100GE-SE with A9K-RSP880-SE and 32-bit IOS XR
nesttech1
We are trying to confirm if BNG is supported on the A9K-2X100GE-SE module running with A9K-RSP880-SE and IOS XR 6.6.3
This link to CISCO site is listing all other older modules with 32-bit IOS support, but not A9K-2X100GE-SE
See Table 2 in this link:
https://www.cisco.com/c/en/us/td/docs/routers/asr9000/software/asr9k-r6-4/bng/configuration/guide/b-bng-cg-asr9000-64x/b-bng-cg-asr9000-64x_chapter_010.html#concept_AFA13EF2B8CF4DE6B4DC5CE0AC4FBBBC
Thank you for any feedback on this issue.
tkarnani
The guide is correct. i checked internally on other cases that were opened for customers. BNG was not qualified for this card. this card is also end of sale.
https://www.cisco.com/c/en/us/products/collateral/routers/asr-9000-series-aggregation-services-routers/eos-eol-notice-c51-738854.html
there will not be any new features added for support
tkarnani
nesttech1
Thank you for your reply.
We will try the newer A9K-4X100GE-SE module instead
