HSRP track interface (ASR9k v4.2.3)
Hi all,
I was trying to configure the track interface command within hsrp, and when I apply the command the priority group decrement immediately.
Before of apply the configuration:
RP/0/RSP0/CPU0:PE1-ASR9010-LAB-MACUL#sh hsrp bvi 600
Thu Sep 12 14:04:07.548 UTC
                       P indicates configured to preempt.
Interface      Grp Pri P State   Active addr     Standby addr   Group addr
BV600            1 110 P Active  local           200.10.10.3    200.10.10.1
Then, I apply track interface:
router hsrp
interface BVI600
  address-family ipv4
   hsrp 1 version 1
    timers 1 3
    preempt
    priority 110
    address 200.10.10.1
    track GigabitEthernet0/3/0/26 20
And priority decrement:
Thu Sep 12 14:05:20.302 UTC
BV600            1  90 P Standby 200.10.10.3     local          200.10.10.1
Why priority decrement if the interface is always up?
Regards.
What is the configuration on GIg0/3/0/26?  Is it definded as l3 or l2 interface?  HSRP can't track an L2 interface.
Bryan
7 Replies 7
Michael Toth
Level 4
Level 4
Is the interface 'GigabitEthernet0/3/0/26' down ?
No. That´s why I am asking why the priority decrement if the interface is always UP.
Look:
RP/0/RSP0/CPU0:PE1-ASR9010-LAB-MACUL#sh inter gi 0/3/0/26
Fri Sep 13 10:41:55.907 UTC
GigabitEthernet0/3/0/26 is up, line protocol is up
Without track command:
Fri Sep 13 10:42:30.411 UTC
After I apply track command:
router hsrp
interface BVI600
  address-family ipv4
   hsrp 1 version 1
    timers 1 3
    preempt
    priority 110
    address 200.10.10.1
Fri Sep 13 10:44:28.498 UTC
Fri Sep 13 10:44:43.139 UTC
Bryan
An option may be to create an object and track the state of that object?
track THISOBJECT
type line-protocol state
 interface GigE0/0/0/10
router hsrp
int bvi 52
address-family ipv4
track object THISOBJECT 20
didnt test it, but it might be a usable workaround available in 4.2.1 onwards.
xander
Hi Alexander,
I tried with track object and it works fine.
Thanks!.
Regards.
Hi Bryan,
The inteface is L2, that is the problem. Thanks!
