07-22-2024 11:26 PM
We have created a VRF for a customer on a Cisco ASR 9912 router. All connections are of 10G speeds, but we need this VRF to have a maximum bandwidth of 1G only.
Is there any way to limit the VRF bandwidth to 1G without changing the interfaces speeds?
Solved! Go to Solution.
07-23-2024 12:05 AM
you can use Rate limit or QoS config if that is possible ?
07-23-2024 12:05 AM
07-23-2024 12:49 AM
Are the proposed solutions scalable, so that we can apply them to multiple customers if needed?
