08-11-2020 06:29 AM
Hello Experts
I have to install a A9K-MOD200-SE on an XR 9010.
I saw that IOS XR Software version 6.0.1 is the minimum required version.
The customer is running IOS XR Software, Version 5.3.4.
As I must upgrade, can please tell me if i can install just a package ( PIE) or the all vm image.
Many Thanks in advance for your advice.
Zanga
Solved! Go to Solution.
08-11-2020 06:55 AM - edited 08-11-2020 06:58 AM
Hi Zanga,
you will need to upgrade the entire router to meet the minimum version of the MOD200. both the MINI + PIE's
you may even need to upgrade to a higher version than 6.0.1 depending on the MPA being used.
here is the list that has the minimum requirements for both the mod200 and MPA's
here is the recommended version of code based on the hardware you have
you should be able to upgrade past 5.3.4, the only restrictions are trident based cards will not boot as they are not supported
Hi Zanga,
08-11-2020 07:37 AM
08-11-2020 07:47 AM - edited 08-11-2020 07:49 AM
All the cards/RSP listed will boot except A9K-4T-L
this card will not boot at all on code higher than 5.3.4 as its end of life/support
08-12-2020 07:56 AM
08-12-2020 08:35 AM
Hi Zanga,
its easier to install the pies + mini at the same time. as you have RSP440, the last release is 642
https://software.cisco.com/download/home/282423206/type/280805694/release/6.4.2
the upgrade guide is located in the docs.tar on that link ASR9K-px-docs-6.4.2.tar
Thank you
08-13-2020 10:23 AM
Thanks very much for your help.
Zanga
