smeegada1
Start with Beep not working in Record_With_Confirm after 11.6 upgrade.Let me know if you are aware of this issue
4 Comments
janinegraves
Hi - It works on my system with 11.6 and VVB (I have VVB patch ES81 installed).
Not sure if the patch fixed the beep or not, but it works on my system.
smeegada1
Thanks for the response.We are not using VVB so not sure in 11.6 it works only with VVB.
dekwan
I checked with some folks on the team and said that on a 11.6 system without VVB, they are not having any issues.
Thanx,
Denise
wagnerm
On your VXML gateway do you have these commands configured: vxml version 2.0 vxml audioerror
