10-18-2013 01:25 PM - edited 03-15-2019 05:55 AM
My co-worker and I are editing our existing Call Center Script. This is our first attempt at UCCX scripting. They need to break the script off into 2 branches, the existing one for English and a copy of the menu for a Spanish version. We were trying to include an option 2 for Spanish. We did not want to make the user press 1 for English but can if required. English is supposed to drop through to the next/existing menu. The 2 for Spanish is just doing nothing. It is acting as if we pressed nothing even though we have a Input identified as Language_Choice and a Filter of 2 for the key press caller input.
We are running out of time and could use some direction. Thanks for any help, Jackie
Solved! Go to Solution.
10-18-2013 06:22 PM
Hi Jackie,
I have attached the sample script for your reference .
Hop this will work for you .:)
Ravi
10-18-2013 02:37 PM
Post your script.
Chris
10-21-2013 02:31 PM
Thank you, Chris -
My co-worker figured it out this morning. We were giving Spanish a digit to press (2), but English we were trying to just allow to drop through. It turned out that when we put English on a digit (1) and the user had to press the digit, it went to the right menu. This has turned out to be fun and interesting. Thanks for the response. Jackie
10-18-2013 06:22 PM
10-19-2013 06:55 AM
Thanks, Ravi!! And lol, my hubby and I have all of Ravi Shankar's albums on vinyl LP. We love him. I suspect your parents did too ! I am giving your script a look right now. Appreciate the help!
10-21-2013 09:22 AM
Jackie,
So what is not happening when you press 2? It is set to go to the same CSQ, if that is not working then did you refreshed the application after updating the script?
Chris
