UCCE 9.0 Web Setup error: Authorization error: There is a problem accessing Instance OU information in the Active Directory domain. Contact your System Administrator.
I'm trying to setup UCCE 9.0 for educational purpose following different documentation (documentation is very poor). These are the step followed:
1. UCCE has been installed on Server A
2. Domain controller has been created on Server B and user "ccenter" was created as a administrator user.
3. Server A was added to domain created. Server name is CCENTERE@UCCE.com
4. Domain Manager was setup (Attached image).
5. I got access to Web setup but when I tried to add a instance the following error was received: Authorization error: There is a problem accessing Instance OU information in the Active Directory domain. Contact your System Administrator. (Attached image).
The "ccenter" has been added to all Directory Domain server, including Cisco_ICM (Attached image).
Any advice would be appreciated.
__________________________________________________
Please remember to rate useful posts clicking on the stars below.
LinkedIn Profile: do.linkedin.com/in/leosalcie
Hi Leo,
Am also facing the same error , I  have re-installed   with domain  login credentials and  working fine.
 What is the login credentials using for Application software installation. If your using local login you will get the above error.
For best solution you have to  re-install with Domain login credentials.
Ram.S
24 Replies 24
Chintan Gajjar
Level 8
Level 8
You are probably missing some role in Domain.
try assigning all available role and see if it works.
Hi Chintan,
Thanks for the response. I assigned all available role to the user "ccenter" but it didn't work , same error is received (please see attached image).
Any idea?
Thanks in advance for your help.
Leo,
Go into Active Directory Users and Computers and go to the OU that contains Cisco_ICM - once there, expand all the way down to the OU who's name is the same as your instance name. Within that OU, you should see the following security groups that you should add your domain user to:
<facility>_<instance>_Config
<facility>_<instance>_Service
<facility>_<instance>_Setup
<facility>_<instance>_Webview
For safe measure, you can also go up one OU, the facility OU, and add yourself to the following security groups:
<facility>_Config
<facility>_Setup
<facility>_Webview
Hi Omar,
The user is already added to the security groups mentioned. Please see the attached picture to confirm.
Any idea?
Is the domain user a domain admin?
Yes, it is. Please see the attached picture.
...Forum Bug...Don't know why I'm not able to repond to the last message replyed.
Yes. I ran Domain Manager use same user (ccenter) and removed everthing (All OU Cisco_ICM were removed), then added everything back and assigned the user on all Security Group. After ran Web Setup using same user was received same error "Authorization error: There is a error accesing instance OU...
Any idea?
its weird, using the same user you are able to create OU, but not able to access that OU. try restring DC services, and see if it works.
regards
Chintan
It didn't work, same error is received...I'm almost frustrated with UCCE...
Any idea?
Hi Leo,
What version of Windows Server are you using ( 2003/2008 ?) and what is the domain functionality level ?
Sumit
I'm running Windows Server 2008 R2.
Domain/Forest Functionality Level is Windows Server 2008 R2.
Thanks for your response. Any idea?
even i am feeling the same heat :-), ok lets give one more try.
can you attach websetup logs. you may find them at below location
C:\icm\log\Websetup
and at here:
C:\Temp
regards
Chintan
Log files attached to this message.
Thanks for your help.
create same user "ccenter" on local computer(UCCE machine) as well and give all admin rights and then try to check if it works?
regards
Chintan
