Showing results forĀ
Search instead forĀ
Did you mean:Ā
3rd party SIP phones supported in Cisco CUCM v9.0 onwards
gawankar_sanket
Dear Experts,
Is there list/ documents enlists all supported 3rd party SIP based phones (software as well as hardware) which are supported in Cisco CUCM v9 and above?
Sanket G.
11 Replies 11
Rajan
Hi Sanket,
You can register any 3rd party sip phone as long as it is RFC 3261 complaint:
https://www.cisco.com/c/en/us/td/docs/voice_ip_comm/cucm/admin/11_0_1/sysConfig/CUCM_BK_C733E983_00_cucm-system-configuration-guide/Configure___Third_Party_SIP_Phones.pdf
Rajan
Pls rate all helpful posts by clicking the star below
Thanks Rajan, but is there any list of 3rd party SIP phones which are supported with CUCM ?
I have already tested polycom softphone, Grandstream phone. Looking for any other phones model which will work well with CUCM.
Sanket G
Not really sure if such a list exists for the newer versions of CUCM , apparently there used to be a program called (CTDP) to enable 3rd party vendors to test and verify the interoperability of their end points with CallManager and CallManager Express during the callmanager 5.0 days, looks like it was scrapped later on for phones.
https://www.google.co.in/url?sa=t&rct=j&q=&esrc=s&source=web&cd=1&cad=rja&uact=8&ved=0ahUKEwiDr_ebharZAhWHX5QKHTLABvAQFggmMAA&url=https%3A%2F%2Fwww.cisco.com%2Fcomm%2Fapplications%2FIPCApps%2FDocs%2FSIPTHIRDPARTYENDPOINTFAQ3_20_06.doc&usg=AOvVaw1V4ci...
It would be better if you can select a non cisco model and check with them to see how well the device works with CUCM from a feature perspective.
Please rate if you find this helpful.
Aeby
Aeby
Hi, how did you handle licensing? How many licenses did you consume for this integration?
Jaime Valencia
tekVizion is the only one I know who does that
java
if this helps, please rate
Thanks Jaime.
So for  I could find below phones tested with CUCM.
1. 3sx-softphones
2. IPCelerate,
3. IP blue,
4. Grandstream
5. Revolabs
6. Tekvizion
7. Polycom softphone
you will find lack of customizability in terms of softbuttons and services is gonna be your biggest problem running any of these on cucm
Please remember to rate useful posts, by clicking on the stars below.
Polycom Trio 8800 works with CUCM 11.5.
I used this to get mine up and running in no time.
https://support.polycom.com/global/documents/support/setup_maintenance/products/voice/dg_soundstation_ip_conference_phones_with_cucm.pdf
I have already tested polycom softphone, Grandstream phone. Looking for any other phones model which https://xender.pro/ https://discord.software/ https://omegle.onl/
Can any of these use extension mobility?
I donā€™t think so as that is a Cisco proprietary function.
Response Signature
