6921 phones won't support more than 2 calls
Clifford McGlamry
Using CUCM v8.6.  Customer has 6921 phones using SCCP integration.  By default, the lines on these phones come up set to support 2 simoultaneous calls, with the busy trigger set to 1.
Reset this isn CUCM from 2/1 to 4/2.  Phone settings applied and reset.
Phone will still not handle more than 2 calls at a time.
Has anyone else seen this, have a work around, etc.?
5 Replies 5
Chris Deren
Few similar thread, not sure if there is newest firmware file that resolves it though:
https://supportforums.cisco.com/thread/2033372
https://supportforums.cisco.com/thread/2119836
https://supportforums.cisco.com/thread/2045098
HTH,
Chris
Thanks Chris.  It looks like something is developing when you look at the threads over time.  At first they said 1 per line, and the max calls was grayed out.  Then they talked about setting up a second number (same number/different partition).  Now in 8.6.2, the max value isn't grayed out.
I'm going to open a case on this and see what I can find out.
Rob Huffman
Hi Cliff,
Just as an FYI ....like you and Chris nicely noted, this requires CUCM 8.6 & above
but it also requires firmware 9-2-1 or later as well
http://www.cisco.com/en/US/docs/voice_ip_comm/cuipph/6921_6941_6961/firmware/9_2_1/english/release/notes/6921_921.html#wp200162
Cheers!
Rob
"Celebration it's around us, every nations, all around us.
Singin' forever young, singin' songs underneath that sun" - K'naan
TAC is saying it also requires the latest device PAK, or seems to.  I'm loading it now, and will then see if that resolves it.
we try to solve this issue with CM 8.5 istalling device pack cmterm-devicepack8.5.1.16097-1 but after installing another problems came up.
ip phones option are now displayed in english insted of spanish, the time shown is not the correct, we do not know the reason of this changes.
and the issue about the lines remains.
does any of you know how to clear the issue about language and time?? , we like to have al least the same features before device pack was installed.
regards
