02-20-2013 07:19 PM - edited 03-16-2019 03:51 PM
Could anyone tell me if this unit is supported on the Cisco SRP527W router/modem?
I can register with the SIP provider (info screen in router) but cannot get past "registering" on the phone itself.
(need to use wireless broadband, hence the 527 unit).
02-20-2013 10:11 PM
Cisco does not document or support their Enterprise phones for third party systems, and the matter is not discussed here. You can have better luck on forums like voip-info.org.
02-21-2013 03:57 PM
Paulo,
since when was a CISCO router /nodem a "third party system"???
02-21-2013 04:02 PM
Hi Robet,
Have you upgrade the phone to SIP? By default, Cisco 79XX run SCCP. Did you try registering a SIP softphone?
02-21-2013 04:32 PM
Yes thanks Leo, also used a 525G and have same issue. Assumed as SRP527 is basically an above average gateway, not a CM, that SIP would be the default?
