ā06-10-2013 11:56 AM - edited ā03-16-2019 05:47 PM
ā06-10-2013 09:59 PM
Hi Nick,
Can u check whether u have configured E1 port correctly like isdn switch-type ,pri-group 0 time-slots and CRC4?
If yes, then, u can also check whether your E1 card is functioning properly or not by shorting TX and Rx pairs on RJ -45 [ pin1 with pin 4 and 2 with pin 5] , check E1 is coming UP on router or not.
regds,
aman
ā06-11-2013 07:51 AM
ā06-10-2013 11:57 AM
that can cause this problem?
ā06-10-2013 12:05 PM
Circuit failure, complain to telco.
ā06-10-2013 12:26 PM
ā06-11-2013 08:02 AM
nick@fms.com.mx wrote:
What do you not understand? Your E1 circuit is not working. Telco must fix it.
ā06-10-2013 01:36 PM
check whether it is administratively down or not with sh e1 x/x/x
you will find many details in that cmd
Hi Nick,
regds,
aman
ā06-11-2013 07:39 AM
This is my configuration!!
I'm using a UC560
but I can not make it show UP.
and use the command shut/no shut, and does not work.
E1 0/3/0 is down.
Applique type is Channelized E1 - balanced
Description: Tel Line 1-10 Digital Line
Transmitter is sending remote alarm.
Receiver is getting AIS.
alarm-trigger is not set
Version info Firmware: 20100222, FPGA: 13, spm_count = 0
Framing is NO-CRC4, Line Code is HDB3, Clock Source is Internal.
Data in current interval (143 seconds elapsed):
0 Line Code Violations, 0 Path Code Violations
0 Slip Secs, 0 Fr Loss Secs, 0 Line Err Secs, 0 Degraded Mins
0 Errored Secs, 0 Bursty Err Secs, 0 Severely Err Secs, 143 Unavail Secs
Total Data (last 24 hours)
21 Line Code Violations, 0 Path Code Violations,
0 Slip Secs, 0 Fr Loss Secs, 0 Line Err Secs, 0 Degraded Mins,
0 Errored Secs, 0 Bursty Err Secs, 0 Severely Err Secs, 86400 Unavail Secs
Hi Nick,
Did u try changing Framing to CRC-4 and check?
regds,
aman
ā06-11-2013 07:54 AM
yes, I tried, and does not work.
also change the clock.
ā06-11-2013 07:59 AM
Your controller shows that you are receving AIS from your telco.
AIS stands for Alarm Info Signal and as they indicated it is the carrier sending you an alert that a facility alarm is being generated. Contact your provider as Paolo suggested..This will save you time..Please refer to similar thread below
https://supportforums.cisco.com/thread/288531
https://supportforums.cisco.com/thread/2114347
Please rate all useful posts
"opportunity is a haughty goddess who waste no time with those who are unprepared"
ā06-11-2013 08:16 AM
Hi Nick,
In addition to what Mr. AOK kas said, u can do physical loop of the Circuit [Pairs coming from Telco Side] and get the E1 checked at Telco end.
regds,
aman
