block incoming call in callmanager
ciscoceci
We have a big issue with a incoming number, we receive 300 calls every day from the same number and it is a fax. Could someone explain me how a i can block this number???
regards
11 Replies 11
Gordon Ross
Level 9
Level 9
https://supportforums.cisco.com/docs/DOC-18367
GTG
Please rate all helpful posts.
Great doc Gordon!!
Hi Gordon,
I have configured your solution but doesn´t work, after configured the call come in the system. I have some doubts about your article. Could you answereed me??
6)      Create a Translation Pattern ! in the ‘Filter_List’ Partition. Set the Calling Search Space to route non-blocked calls to their destination.
The ! in the ‘Filter_List’ Partition is used to route any calling party number that is not specifically defined as a blocked number . The Calling Search Space routes the call back to the phone’s partition for normal call routing
Which CSS must assign to this Translation....???
regards
you can block easily from the voice router . can you get into the router? if yes pls do that :
create # conf t
voice translation-rule 1
rule 1 reject / the xxx number/
voice translation-profile reject
translate calling 1
now go to the defalt dial-peer and:
dial-peer voice 1 pots
call-blok translation-profile incoming reject
incoming called-number .
direct-inward-dial
port 0/0/0:15
try that it will work fine .
Hi Sharon
Yes, i can get into
thanks
Hi Sharon,
Do your config works in MGCP registered T1/E1???
thanks
I am working in H323 registered  E1
Rob Huffman
Hi Ceci,
Just to add a note to the great tips from Gordon and Sharon (+5 each )
With MGCP, you will have to block using CUCM as this cannot be done
at the gateway level. Here is one other reference;
https://supportforums.cisco.com/docs/DOC-19628
Cheers!
Rob
"And if I should fall behind
Wait for me" - Springsteen
Thanks Rob,
I have followed your reponse but the calls follow come in to the call-mamanger, do you know how i can see where is the issue???
regards
Finally the VG is h323 or mgcp
cc
Please rate all useful posts Regards Chrysostomos ""The Most Successful People Are Those Who Are Good At Plan B""
Hi.
Finally the block is working follow the gordon DOC
thanks
