Call Identification
Jean Lofrano
Hey team,
I have a environment working properly between 2 UCS with CUCM 8.6.
In the same voice network I have a integration with analog central, so I have problems in the call identification when the call comes from a analog phone.
So, The managers would like to import a list into the CUCM with the most importants numbers and names to indentify at the moment of call between the systems.
I´ve been thinking to create a XML file with that kind of list. is it possible?
thanks.
5 Replies 5
Anas Abueideh
Level 9
Level 9
what is the type of integration between analog PBX and your voice network, FXO or E1 ?
if it is FXO, add command "caller-id enable" under the voice port config. it might help.
Anas
please don't forget to rate the helpful posts
Jonathan Schulenberg
I believe what Jean is asking for is how to populate the Caller ID Name for frequent known numbers when it wasn't sent by the calling PBX in the first place. If this is the case CUCM cannot do this by itself. Paolo has a TCL script that can do this (I believe he sells these though) at the ingress gateway.
Please remember to rate helpful responses and identify helpful or correct answers.
Jonathan,
You are absolutely correct.
I will see the Paolo´s Solution.
thanks man!
Thanks man,
But I´ve been looking for a standard configuration.
att.
