Call Manager 8.5 disable beep for second call
Saima Harris
I have an issue with Call Manager 8.5, when users are on one call and a second call comes in , they hear it ringing/beeping in their call.
Can someone please let me know if there is any global parameter to dsable that option.
Thanks in advance
Saima
7 Replies 7
clileikis
Level 7
Level 7
You can disable this per phone/line under Device > Phone > Line
HTH,
Chris
There is no global setting. The setting Chris was suggesting is per-DN, per-Device and is called Ring Setting (Phone Active).
Please remember to rate helpful responses and identify helpful or correct answers.
I think the parameter : ring setting On busy station in service parameters should work for you
regards
Nice catch Youssef! (+5)
Thanks everyone for your replies .
I'll try that option and let you know
Just a quick question , if I changed that Service parameter "ring setting On busy station" , is it going to reset the phones or it wouldn't be service affecting .
It won't affect service.
Please remember to rate all useful posts.
Response Signature
