CCM6 Publisher ans Subscriber
a.rayen83
Hi, i installed two CCM, a publisher and ans suscriber, the suscriber has taken the configuration (Data Base) from the Publisher correctly, but now, i have some Phones registred, i disconnect the publisher CCM to test if the scuscriber will be active, but nothing, i think that i missed a step. Please can i have the procedure to have the Publisher Active and yhe suscriber Standby. Thanks a lot
15 Replies 15
Rajesh Revuru
Level 4
Level 4
Check the callmanager group under Device pool configurations. You should have subscriber as first preference and publisher as second preference.
i creat a CM Group, but in a Available Cisco Unified Communications Managers, i don't find the second CM (the Suscriber), i can find only the Publisher, but i'm sur that i added the CM Suscriber (the server and the CM). i think that i must find it in the available CM to make it to the same group with the Publisher.
Go to both Server and CallManager on the System tab of the CCMAdmin webpage, make sure to have both servers if not, added it and then go back to the CCMGroup
you need to start the CCM services before trying this, they're not started by default.
If they're not running the server will not show up in the CCM group.
check you have enough ccm node licenses before that, if not then you won't be able to start the services
java
if this helps, please rate
java
in the system>server, i added the two servers, i don't have pblm with that, but i don't know what service i must activate. Thanks.
callmanager service
java
java
hi, thank u for this help, i tried to activate the service but i have this message "All the allocated licenses to this node are consumed", i don't know if i need any licenses in the suscriber, i have all the licenses on the Publisher. Thanks
hi, it looks like you may just have one server licensed to run the CallManager service. If you go to System>Licensing>License Unit Report it should tell you on there how many Server Units are actually licensed.
licenses are managed by the license node, usually the PUB and they replicate to other servers. YOU DO NEED A NODE LICENSE PER SERVER WHERE CCM WILL RUN. you can have only TFTP, maybe only IPVMS on the server, but if you plan to activate CCM you need a node license, that's why i told you to check you had enough licenses before trying to activate it
java
java
Thanks a lot,my problem is the license, i can't activate the CCM service. i will check with my manager.
Check the box the subscriber server came in. If its a MCS server purchased for CM6, then the server license is probably on a piece of paper that came with the server. Just register the PAK and apply the new license file to the publisher.
just remember that you need to issue ALL licenses using the MAC address from the license node (probably your PUB).
do not ask a license for a node using the MAC from the SUB as it won't work, same for DLUs and anything else
java
java
I am having a similar issue, except I have licenses added with the PUB MAC address, I have the UC SUB with CallManager services STARTED, but it STILL does NOT show up under the Unified CM Group?
Here is a snippet of the current License files:
INCREMENT SW_FEATURE cisco 6.0 permanent uncounted \
VENDOR_STRING=1001E0BCBBA2E1.0 \
HOSTID=001e0bcbba2e \
INCREMENT CCM_NODE cisco 5.0 permanent uncounted \
VENDOR_STRING=1001E0BCCA6301.0 \
As you can see, each is tied to the UC PUB MAC address, but, what is strange is that I cross-referenced it to a similar license from a previous install and this is what THAT license shows:
INCREMENT PHONE_UNIT cisco 5.0 permanent uncounted \
VENDOR_STRING=2001A646F5ACD1.0 \
HOSTID=001a646f5acd \
NOTICE="200806010532381072 \
" SIGN="18E8 C631 1F9E 3E66 E252 63C6 510D 087E \
F29D 4153 CA0D B56A D088 6273 F589 01EC 74DD 52B6 C730 0E7C \
F709 58E2 B9BB CA2E 8BAF B3CF DDEF 9CF4 4369 861C"
NOTICE="200806010532381073 \
" SIGN="1313 DB80 D56E 5279 D9DC 011A 09B6 D338 \
D238 8F44 94EA 5444 04F1 F281 77DB 0834 2695 953E D270 BC7E \
EB28 1361 BE4C 2FA7 0D69 530E D1F3 7162 04CE 64DC"
Notice the "Vendor String Count shows as "2" when my other license files above only show a "1" each.........
Is this license file possibly invalid or was generate wrong?
please help?
Hi Robert,
You are most correct! You only have a license for one "node". Send an email to;
licensing@cisco.com
With all your pertinant Corporate info to start the proper licensing process. They should be able to email you the proper license in short order.
Here is an Example of Permanent CCM_Node licenses
# Optional usage agreement, legal language, tracking information
# Some other comments
VENDOR_STRING=3000BCD4EE59D1.0
ileVersion> \
HOSTID=000bcd4ee59d \
NOTICE="200508261405391621 \
" SIGN="19B3 4C6C 25AC 6D22 4D75 DE6A 656B 08C5 \
30E4 16DB 771B 1393 9DC1 DBC4 C5AA 15CC 6E6C B7B8 895A DCBA \
B40F C551 2625 1C97 F20D 9977 6CFF 3603 081E 6FF2"
The preceding license file includes the following information:
•No expiration date for this license exists as indicated by the keyword permanent.
•This license file provides three licenses for the version 5.0 of the feature CCM_NODES.
•The Cisco specific fieldLicFileID, identifies this license file.
•You can add multiple increment lines for same feature in a license file to increase the license count. None of the INCREMENT lines should be identical and each of them should be signed independently.
http://www.cisco.com/en/US/docs/voice_ip_comm/cucm/admin/5_0_1/ccmcfg/b02licfu.html
Hope this helps!
Rob
