01-28-2016 06:57 AM - edited 03-17-2019 05:39 AM
Hi everyone,
I have a doubt regarding CME supported firmware. I'm running CME 8.6 on Cisco Router 2811.
For 7965 and 9971 phones running CME 8.6, Cisco recommend to run Firmware SCCP45.9-1-1SR1S.loads and sip9971.9-1-1SR1.load but phone with hardware revision 12.0 and higher doesn't support firmware earlier than Release 9.3(1)SR1.
Today I downloaded firmware cme-153-2Tv1.rar recomended for CME 10.5 (already know is not supported on 2811) but firmware attached are SCCP45.9-2-1S.loads and sip9971.9-2-2SR1-9.loads, they are earlier than Release 9.3(1)SR1.
Am I missing something? Doesn't CME support new phone hardware or file name is not related with firmware version?
Cisco Unified IP Phone7945G and 7965G |
apps45.9-1-1TH1-16.sbn cnu45.9-1-1TH1-16.sbn cvm45sccp.9-1-1TH1-16.sbn dsp45.9-1-1TH1-16.sbn jar45sccp.9-1-1TH1-16.sbn SCCP45.9-1-1SR1S.loads* term45.default.loads term65.default.loads |
Cisco Unified IP Phone9971 |
dkern9971.100609R2-9-1-1SR1.sebn kern9971.9-1-1SR1.sebn rootfs9971.9-1-1SR1.sebn sboot9971.031610R1-9-1-1SR1.sebn skern9971.022809R2-9-1-1SR1.sebn sip9971.9-1-1SR1.loads* |
SCCP45.9-2-1S.loads |
dkern9971.100609R2-9-2-2SR1-9.sebn |
Phone |
Hardware Version |
Cisco Unified IP Phone 7942G |
15.0 and higher |
Cisco Unified IP Phone 7962G |
15.0 and higher |
Cisco Unified IP Phone 7945G |
13.0 and higher |
Cisco Unified IP Phone 7965G |
13.0 and higher |
Cisco Unified IP Phone 7975G |
12.0 and higher |
Phones manufactured with these hardware versions must run Firmware Release 9.3(1)SR1 or later. The phone firmware does not allow the phone to be downgraded to releases earlier than Release 9.3(1)SR1.
Solved! Go to Solution.
01-28-2016 07:09 AM
Hi Leo,
Hope all is well my friend!
The docs like this one for CME only show the recommended firmware at the time the CME version was released. You would be fine to download and install a newer firmware like 9-3-1sr4 or higher that can support the 7965's with hardware rev 15. These docs are not updated to reflect new firmware versions.
Just use the .zip firmware file from this path;
Cheers!
Rob
01-28-2016 07:09 AM
Hi Leo,
Cheers!
Rob
01-28-2016 11:14 AM
Thanks Rob my friend! As always an excellent answer(+5).
08-09-2018 10:33 AM
Greetings All
01-28-2016 11:31 AM
Hi Leo,
Always a pleasure buddy!
Cheers!
Rob
