Bookmark
Subscribe
6856
Cisco CUBE to Call Manager Sip Trunk
Matt Bauman
Running into an issue sending an inbound SIP PSTN call from the CUBE to the Call Manager, have setup per provider docs but the call is failing with a  SIP/2.0 404 Not Found, not sure if it cannot find the SIP trunk to Call Manager or if its a config issue....   See config and results below:
version 15.1
no service pad
service tcp-keepalives-in
service tcp-keepalives-out
service timestamps debug datetime msec localtime show-timezone year
service timestamps log datetime msec localtime show-timezone year
service password-encryption
boot-start-marker
boot system flash c3900e-universalk9-mz.SPA.151-3.T.bin
boot-end-marker
logging buffered 16777216
aaa new-model
aaa authentication login default group tacacs+ local-case enable none
aaa authentication login CONSOLE none
aaa authorization console
aaa authorization exec default group tacacs+ local
aaa authorization exec CONSOLE none
aaa authorization commands 15 default group tacacs+ local
aaa authorization commands 15 CONSOLE none
aaa accounting exec default
action-type start-stop
group tacacs+
aaa accounting commands 1 default
group tacacs+
aaa accounting commands 15 default
group tacacs+
aaa session-id common
clock timezone CST -6 0
clock summer-time CST recurring
no ipv6 cef
ip source-route
ip cef
ip multicast-routing
ip domain name ad.twtelecom.com
ip host srvuccm2pub1.ad.twtelecom.com 10.47.61.10
ip host srvuccm2sub1.ad.twtelecom.com 10.47.61.11
ip host srvuccm2sub2.ad.twtelecom.com 10.47.61.12
ip host srvuccm2sub3.ad.twtelecom.com 10.1.61.14
ip host srvuccm2sub4.ad.twtelecom.com 10.1.61.15
ip host srvucsvc1.ad.twtelecom.com 10.1.62.10
ip host _sip._udp.cmg-dlfw.srvuccm2.uc.twtelecom.com srv 10 50 5060 srvuccm2sub1.ad.twtelecom.com
ip host _sip._udp.cmg-dlfw.srvuccm2.uc.twtelecom.com srv 10 50 5060 srvuccm2sub2.ad.twtelecom.com
ip host _sip._udp.cmg-dlfw.srvuccm2.uc.twtelecom.com srv 10 50 5060 srvuccm2sub3.ad.twtelecom.com
ip host _sip._udp.cmg-dnvr.srvuccm2.uc.twtelecom.com srv 10 50 5060 srvuccm2sub4.ad.twtelecom.com
ip host _sip._udp.cmg-dnvr.srvuccm2.uc.twtelecom.com srv 10 50 5060 srvuccm2sub3.ad.twtelecom.com
ip host _sip._udp.cmg-dnvr.srvuccm2.uc.twtelecom.com srv 10 50 5060 srvuccm2sub2.ad.twtelecom.com
ip name-server 10.1.33.50
ip name-server 10.47.31.10
voice-card 0
no voice hunt unassigned-number
no voice hunt invalid-number
voice call send-alert
voice rtp send-recv
voice service voip
ip address trusted list
  ipv4 10.47.61.10
  ipv4 10.47.61.11
  ipv4 10.47.61.12
  ipv4 10.1.61.14
  ipv4 10.1.61.15
allow-connections sip to sip
fax protocol pass-through g711ulaw
modem passthrough nse codec g711ulaw
sip
  early-offer forced
  midcall-signaling passthru
  sip-profiles 101
voice class sip-profiles 101
request INVITE sip-header Allow-Header remove
response 200 sip-header Allow-Header remove
response 180 sip-header Allow-Header remove
response 183 sip-header Allow-Header remove
voice translation-rule 1000
rule 1 /469484\(5...\)$/ /85\1/
voice translation-profile InboundPSTNCalls
translate called 1000
license udi pid C3900-SPE250/K9 sn FOC17307TDF
hw-module pvdm 0/0
redundancy
ip ssh version 2
interface Loopback192
ip address 10.47.69.15 255.255.255.255
interface GigabitEthernet0/0
description port 1
ip address 10.47.69.2 255.255.255.252
ip pim sparse-mode
ip ospf network point-to-point
duplex auto
speed auto
interface GigabitEthernet0/1
description port 2
ip address 10.47.69.6 255.255.255.252
ip pim sparse-mode
duplex auto
speed auto
interface GigabitEthernet0/2
no ip address
shutdown
duplex auto
speed auto
interface GigabitEthernet0/3
description FVX Interface
ip address 10.0.29.194 255.255.255.252
duplex full
speed 1000
router ospf 4323
auto-cost reference-bandwidth 20000
area 10.47.69.0 stub
network 10.47.69.0 0.0.0.255 area 10.47.69.0
ip forward-protocol nd
no ip http server
ip http access-class 23
ip http authentication local
no ip http secure-server
ip http timeout-policy idle 60 life 86400 requests 10000
ip route 0.0.0.0 0.0.0.0 10.47.69.0
logging trap debugging
logging origin-id hostname
logging facility local0
logging source-interface GigabitEthernet0/0
logging 10.1.62.20
nls resp-timeout 1
cpd cr-id 1
control-plane
mgcp profile default
dspfarm profile 20 mtp
description MTP-dlfwdc3vg01ES
codec g711ulaw
codec pass-through
maximum sessions software 10000
associate application SCCP
dial-peer voice 104 voip
description PBX calls to extension
huntstop
destination-pattern 8.....
session target dns:cmg-dlfw.srvuccm2.uc.twtelecom.com
dtmf-relay rtp-nte
codec g711ulaw
ip qos dscp cs3 signaling
dial-peer voice 103 voip
description Inbound PSTN calls
translation-profile incoming InboundPSTNCalls
session protocol sipv2
incoming called-number .
dtmf-relay rtp-nte
codec g711ulaw
dial-peer voice 101 voip
description PSTN Long Distance
huntstop
destination-pattern 1..........
session target ipv4:10.0.29.193
dtmf-relay rtp-nte
codec g711ulaw
dial-peer voice 102 voip
description PSTN International
huntstop
destination-pattern 011.T
dtmf-relay rtp-nte
codec g711ulaw
dial-peer voice 100 voip
description PSTN local number
huntstop
destination-pattern ..........
dtmf-relay rtp-nte
codec g711ulaw
gatekeeper
shutdown
Oct 30 2013 15:53:24.995 CST: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
INVITE sip:4694845402@10.0.29.194:5060 SIP/2.0
Via: SIP/2.0/UDP 10.0.29.193:5060;branch=z9hG4bK-d8754z-FRBRTXJGEB0010004e9fb863c2142-1---d8754z-;rport
Max-Forwards: 70
Contact: <sip:6366257074@10.0.29.193:5060>
To: <sip:4694845402@10.0.29.194:5060>
From: "TW TELECOM INC "<sip:6366257074@10.0.29.193:5060>;tag=FRBRTXJGEB0010004e9fb863c2143
Call-ID: 66dda242.c21d000a.527171c4.f1c87
CSeq: 1 INVITE
Session-Expires: 1800;refresher=uac
Min-SE: 1800
Content-Type: application/sdp
Supported: timer
Remote-Party-ID: "TW TELECOM INC "<sip:6366257074@10.0.29.193:5060>;privacy=off
Content-Length: 185
v=0
o=fvx 763 1 IN IP4 tekvizion.com
s=FortisWave
c=IN IP4 10.0.29.193
t=0 0
m=audio 39412 RTP/AVP 0 101
a=rtpmap:0 PCMU/8000
a=rtpmap:101 telephone-event/8000
a=fmtp:101 0-15
Oct 30 2013 15:53:24.995 CST: //-1/xxxxxxxxxxxx/DPM/dpMatchPeersCore:
   Calling Number=4694845402, Called Number=4694845402, Peer Info Type=DIALPEER_INFO_SPEECH
   Match Rule=DP_MATCH_DEST; Called Number=4694845402
   Result=Success(0) after DP_MATCH_DEST
Oct 30 2013 15:53:24.995 CST: //-1/xxxxxxxxxxxx/DPM/dpMatchSafModulePlugin:
   dialstring=4694845402, saf_enabled=1, saf_dndb_lookup=1, dp_result=0
Oct 30 2013 15:53:24.997 CST: //-1/xxxxxxxxxxxx/DPM/dpMatchPeersMoreArg:
   Result=SUCCESS(0)
   List of Matched Outgoing Dial-peer(s):
     1: Dial-peer Tag=100
Oct 30 2013 15:53:24.997 CST: //-1/xxxxxxxxxxxx/DPM/dpAssociateIncomingPeerCore:
   Calling Number=6366257074, Called Number=, Voice-Interface=0x0,
   Timeout=TRUE, Peer Encap Type=ENCAP_VOIP, Peer Search Type=PEER_TYPE_VOICE,
   Result=Success(0) after DP_MATCH_ORIGINATE; Incoming Dial-peer=100
Oct 30 2013 15:53:24.997 CST: //-1/xxxxxxxxxxxx/DPM/dpMatchSafModulePlugin:
   dialstring=NULL, saf_enabled=0, saf_dndb_lookup=0, dp_result=0
Oct 30 2013 15:53:24.997 CST: //-1/2771296280A0/DPM/dpAssociateIncomingPeerCore:
   Calling Number=6366257074, Called Number=4694845402, Voice-Interface=0x0,
   Result=Success(0) after DP_MATCH_INCOMING_DNIS; Incoming Dial-peer=103
Oct 30 2013 15:53:24.997 CST: //-1/2771296280A0/DPM/dpMatchSafModulePlugin:
Oct 30 2013 15:53:24.997 CST: //-1/xxxxxxxxxxxx/DPM/dpMatchPeersCore:
   Calling Number=, Called Number=4694845402, Peer Info Type=DIALPEER_INFO_SPEECH
   dialstring=4694845402, saf_enabled=0, saf_dndb_lookup=1, dp_result=0
   Result=SUCCESS(0)
Oct 30 2013 15:53:24.997 CST: //83/2771296280A0/SIP/Msg/ccsipDisplayMsg:
Sent:
SIP/2.0 100 Trying
Date: Wed, 30 Oct 2013 20:53:24 GMT
CSeq: 1 INVITE
Allow-Events: telephone-event
Server: Cisco-SIPGateway/IOS-12.x
Content-Length: 0
Oct 30 2013 15:53:24.997 CST: //-1/2771296280A0/DPM/dpMatchPeersCore:
   Calling Number=, Called Number=855402, Peer Info Type=DIALPEER_INFO_SPEECH
   Match Rule=DP_MATCH_DEST; Called Number=855402
   dialstring=855402, saf_enabled=0, saf_dndb_lookup=1, dp_result=0
Oct 30 2013 15:53:24.997 CST: //-1/2771296280A0/DPM/dpMatchPeersMoreArg:
   Result=SUCCESS(0)
     1: Dial-peer Tag=104
   Result=SUCCESS(0)
   Calling Number=855402, Called Number=855402, Peer Info Type=DIALPEER_INFO_SPEECH
   Result=SUCCESS(0)
   Calling Number=855402, Called Number=, Voice-Interface=0x0,
   Result=Success(0) after DP_MATCH_ORIGINATE; Incoming Dial-peer=104
   Result=SUCCESS(0)
Oct 30 2013 15:53:24.999 CST: //-1/2771296280A0/DPM/dpMatchPeersCore:
Oct 30 2013 15:53:24.999 CST: //-1/2771296280A0/DPM/dpMatchSafModulePlugin:
   dialstring=855402, saf_enabled=1, saf_dndb_lookup=1, dp_result=0
Oct 30 2013 15:53:24.999 CST: //-1/2771296280A0/DPM/dpMatchPeersMoreArg:
   Result=SUCCESS(0)
Oct 30 2013 15:53:24.999 CST: //83/2771296280A0/SIP/Msg/ccsipDisplayMsg:
Sent:
To: <sip:4694845402@10.0.29.194:5060>;tag=392ED2-1D58
CSeq: 1 INVITE
Reason: Q.850;cause=3
Content-Length: 0
Oct 30 2013 15:53:24.999 CST: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
dlfw-dc3-vg01ES#ACK sip:4694845402@10.0.29.194:5060 SIP/2.0
Max-Forwards: 70
CSeq: 1 ACK
Content-Length: 0
Matt,
Youare getting this error "
Warning: 399 srvuccm2sub2 "Unable to find a device handler for the request received on port 57131 from 10.47.69.6" because the ip address of the sip trunk in CUCM either doesnt match this (IP:10.47.69.6) or the server you are sending the call to (cmg-dlfw.srvuccm2.uc.twtelecom.com) is not in the cucmgroup of the sip trunk..
Once you have corrected this, reset the trunk and test again
Please rate all useful posts
"opportunity is a haughty goddess who waste no time with those who are unprepared"
21 Replies 21
Chris Deren
Make sure you have the correct CSS assigned to the sip trunk, and that the dialed number is routable in CUCM.
HTH,
Chris
Ayodeji Okanlawon
From the logs it is clear that your call is not been routed over the sip trunk from cucm.  The outbound leg of the call to cucm us matcching dial-peer 104. This is a h323 dial-peer not a sip dial-peer...
Secondly you do not have sip to h323 and h323 to sip connections enabled in your config.
I am not sure if this is a mistake or not..If you already have a sip trunk configured to the gateway then you need to change the protocol on dial-peer 104 to have "session protocol sipv2" As Chris suggested ensure you also have the correct CSS on the sip trunk
huntstop
dtmf-relay rtp-nte
codec g711ulaw
Thanks for the response guys, I appreciate the info, after stairing at the configs for endless hours you don't notice everything!   I have added the session protocol sipv2 to my dial peers (should have been in there but obviously missed it).
Looks like I am now getting in the right direction, I have checked my CSS's and all is good there but the call is still being rejected with a SIP/2.0 503 Service Unavailable, I have gone back through my docs and config and haven't found the magic piece to the puzzle, any other thoughts would be appreciated.  Thanks!
Oct 31 2013 07:58:56.881 CST: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
Via: SIP/2.0/UDP 10.0.29.193:5060;branch=z9hG4bK-d8754z-FRBRTXJGEB0010004ea09033e820f-1---d8754z-;rport
Max-Forwards: 70
Contact: <6366257074>
To: <4694845402>
From: "TW TELECOM INC "<6366257074>;tag=FRBRTXJGEB0010004ea09033e8210
Call-ID: 66dda242.c21d000a.52725410.d5162
CSeq: 1 INVITE
Min-SE: 1800
Supported: timer
Remote-Party-ID: "TW TELECOM INC "<6366257074>;privacy=off
Content-Length: 185
v=0
o=fvx 790 1 IN IP4 tekvizion.com
s=FortisWave
t=0 0
m=audio 27478 RTP/AVP 0 101
a=fmtp:101 0-15
Oct 31 2013 07:58:56.881 CST: //-1/xxxxxxxxxxxx/DPM/dpMatchPeersCore:
Oct 31 2013 07:58:56.881 CST: //-1/xxxxxxxxxxxx/DPM/dpMatchSafModulePlugin:
Oct 31 2013 07:58:56.881 CST: //-1/xxxxxxxxxxxx/DPM/dpMatchPeersMoreArg:
   Result=SUCCESS(0)
     2: Dial-peer Tag=100
Oct 31 2013 07:58:56.881 CST: //-1/xxxxxxxxxxxx/DPM/dpAssociateIncomingPeerCore:
Oct 31 2013 07:58:56.883 CST: //-1/xxxxxxxxxxxx/DPM/dpAssociateIncomingPeerCore:
Oct 31 2013 07:58:56.883 CST: //-1/xxxxxxxxxxxx/DPM/dpMatchSafModulePlugin:
Oct 31 2013 07:58:56.883 CST: //-1/09895C7F851B/DPM/dpAssociateIncomingPeerCore:
Oct 31 2013 07:58:56.883 CST: //-1/09895C7F851B/DPM/dpMatchSafModulePlugin:
Oct 31 2013 07:58:56.883 CST: //-1/xxxxxxxxxxxx/DPM/dpMatchPeersCore:
Oct 31 2013 07:58:56.883 CST: //-1/xxxxxxxxxxxx/DPM/dpMatchPeersMoreArg:
   Result=SUCCESS(0)
     2: Dial-peer Tag=104
Oct 31 2013 07:58:56.883 CST: //-1/09895C7F851B/DPM/dpMatchPeersCore:
Oct 31 2013 07:58:56.883 CST: //-1/09895C7F851B/DPM/dpMatchPeersMoreArg:
   Result=SUCCESS(0)
   Result=SUCCESS(0)
   Result=SUCCESS(0)
   Result=SUCCESS(0)
   Result=SUCCESS(0)
Oct 31 2013 07:58:56.885 CST: //1099/09895C7F851B/SIP/Msg/ccsipDisplayMsg:
Sent:
SIP/2.0 100 Trying
To: <4694845402>
Date: Thu, 31 Oct 2013 12:58:56 GMT
CSeq: 1 INVITE
Content-Length: 0
Oct 31 2013 07:58:56.885 CST: //1100/09895C7F851B/SIP/Msg/ccsipDisplayMsg:
Sent:
INVITE sip:855402@cmg-dlfw.srvuccm2.uc.twtelecom.com:5060 SIP/2.0
Via: SIP/2.0/UDP 10.47.69.6:5060;branch=z9hG4bK19505
Remote-Party-ID: "TW TELECOM INC " <6366257074>;party=calling;screen=no;privacy=off
From: "TW TELECOM INC " <6366257074>;tag=3ACE496-25
To: <>855402@cmg-dlfw.srvuccm2.uc.twtelecom.com>
Call-ID: 989AA93-416311E3-8521C447-74F7E892@10.47.69.2
Supported: 100rel,timer,resource-priority,replaces,sdp-anat
Min-SE:  1800
Cisco-Guid: 0159997055-1097011683-2233189447-1962403986
User-Agent: Cisco-SIPGateway/IOS-12.x
CSeq: 101 INVITE
Timestamp: 1383224336
Expires: 180
Max-Forwards: 69
Content-Disposition: session;handling=required
Content-Length: 314
v=0
o=CiscoSystemsSIP-GW-UserAgent 5687 4483 IN IP4 10.47.69.6
s=SIP Call
c=IN IP4 10.47.69.6
t=0 0
m=audio 16752 RTP/AVP 0 100 101 19
c=IN IP4 10.47.69.6
a=rtpmap:100 X-NSE/8000
a=fmtp:100 192-194
a=fmtp:101 0-15
a=rtpmap:19 CN/8000
a=ptime:20
Oct 31 2013 07:58:56.901 CST: //1100/09895C7F851B/SIP/Msg/ccsipDisplayMsg:
Received:
SIP/2.0 100 Trying
CSeq: 101 INVITE
Allow-Events: presence
Content-Length: 0
Received:
To: <>855402@cmg-dlfw.srvuccm2.uc.twtelecom.com>;tag=1950667188
CSeq: 101 INVITE
Warning: 399 srvuccm2sub3 "Unable to find a device handler for the request received on port 58173 from 10.47.69.6"
Content-Length: 0
Sent:
ACK sip:855402@cmg-dlfw.srvuccm2.uc.twtelecom.com:5060 SIP/2.0
Max-Forwards: 70
CSeq: 101 ACK
Content-Length: 0
Sent:
From: "TW TELECOM INC " <6366257074>;tag=3ACE4A6-534
Min-SE:  1800
CSeq: 101 INVITE
Expires: 180
Max-Forwards: 69
Content-Length: 314
v=0
o=CiscoSystemsSIP-GW-UserAgent 2823 5247 IN IP4 10.47.69.6
s=SIP Call
c=IN IP4 10.47.69.6
t=0 0
m=audio 28974 RTP/AVP 0 100 101 19
c=IN IP4 10.47.69.6
a=fmtp:100 192-194
a=fmtp:101 0-15
a=rtpmap:19 CN/8000
a=ptime:20
Oct 31 2013 07:58:56.903 CST: //1100/09895C7F851B/SIP/Msg/ccsipDisplayMsg:
Received:
SIP/2.0 100 Trying
CSeq: 101 INVITE
Content-Length: 0
Received:
To: <>855402@cmg-dlfw.srvuccm2.uc.twtelecom.com>;tag=1604061688
CSeq: 101 INVITE
Warning: 399 srvuccm2sub1 "Unable to find a device handler for the request received on port 65436 from 10.47.69.6"
Content-Length: 0
Sent:
Max-Forwards: 70
CSeq: 101 ACK
Content-Length: 0
Sent:
From: "TW TELECOM INC " <6366257074>;tag=3ACE4A8-60D
Min-SE:  1800
CSeq: 101 INVITE
Expires: 180
Max-Forwards: 69
Content-Length: 314
v=0
o=CiscoSystemsSIP-GW-UserAgent 9035 7585 IN IP4 10.47.69.6
s=SIP Call
c=IN IP4 10.47.69.6
t=0 0
m=audio 17168 RTP/AVP 0 100 101 19
c=IN IP4 10.47.69.6
a=fmtp:100 192-194
a=fmtp:101 0-15
a=rtpmap:19 CN/8000
a=ptime:20
Oct 31 2013 07:58:56.905 CST: //1100/09895C7F851B/SIP/Msg/ccsipDisplayMsg:
Received:
SIP/2.0 100 Trying
CSeq: 101 INVITE
Content-Length: 0
Received:
To: <>855402@cmg-dlfw.srvuccm2.uc.twtelecom.com>;tag=551297973
CSeq: 101 INVITE
Content-Length: 0
Oct 31 2013 07:58:56.907 CST: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Sent:
Max-Forwards: 70
CSeq: 101 ACK
Content-Length: 0
Oct 31 2013 07:58:56.907 CST: //1099/09895C7F851B/SIP/Msg/ccsipDisplayMsg:
Sent:
To: <4694845402>;tag=3ACE4AA-2CA
CSeq: 1 INVITE
Content-Length: 0
Received:
Max-Forwards: 70
CSeq: 1 ACK
Content-Length: 0
Matt,
Changing my SIP trunk in Call Manager to 10.47.69.6 did fix it, this is my first trunk experience to an OSPF VG, I added each IP on the CUBE to the sip trunk and we're good to go...
Thanks so much!!
Matt,
Glad I could help. Kindly mark this thread as answered. It helps others identify correct responses.
Hi Ayodeji
Having the same issue.
Jun  5 18:22:30.923: //1251/000000000000/SIP/Msg/ccsipDisplayMsg:
Sent:
OPTIONS sip:ppr1.gcbstrunk.qos.telkomvoip.co.za:5060 SIP/2.0
Via: SIP/2.0/UDP 192.168.217.137:5060;branch=z9hG4bK14D1903
To: <sip:ppr1.gcbstrunk.qos.telkomvoip.co.za>
Date: Thu, 05 Jun 2014 18:22:30 GMT
Call-ID: 30D8CC94-EC1511E3-863BA429-E850C69C@192.168.217.137
User-Agent: Cisco-SIPGateway/IOS-15.2.4.M5
Max-Forwards: 70
CSeq: 101 OPTIONS
Contact: <sip:192.168.217.137:5060>
Content-Length: 0
Jun  5 18:22:30.931: //1251/000000000000/SIP/Msg/ccsipDisplayMsg:
Received:
SIP/2.0 200 OK
To: <sip:ppr1.gcbstrunk.qos.telkomvoip.co.za>;tag=SD4cgdb99-snl_0164050033
CSeq: 101 OPTIONS
Contact: <sip:10.222.5.86:5060;transport=udp;maddr=10.222.5.86>
Supported: sip-stun
Content-Length: 0
Jun  5 18:22:31.299: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
OPTIONS sip:mibcopri.ppr1.gcbstrunk.qos.telkomvoip.co.za SIP/2.0
Via: SIP/2.0/UDP 165.148.65.118:5060;branch=z9hG4bKes5kas0008ogqu0os6r1
Call-ID: 3db3946c9b2ef36756488129dfd10311000gm51@165.148.65.118
To: sip:ping@mibcopri.ppr1.gcbstrunk.qos.telkomvoip.co.za:5060
From: <sip:ping@ppr1.gcbstrunk.qos.telkomvoip.co.za>;tag=c11d0aefb478669eab89a9197df4a3bc000gm51
Max-Forwards: 68
CSeq: 26699 OPTIONS
Route: <sip:192.168.217.137:5060;lr>
Jun  5 18:22:31.299: //1252/31122D05863C/SIP/Msg/ccsipDisplayMsg:
Sent:
SIP/2.0 200 OK
To: sip:ping@mibcopri.ppr1.gcbstrunk.qos.telkomvoip.co.za:5060;tag=29E79980-2664
Date: Thu, 05 Jun 2014 18:22:31 GMT
Server: Cisco-SIPGateway/IOS-15.2.4.M5
CSeq: 26699 OPTIONS
Allow: INVITE, OPTIONS, BYE, CANCEL, ACK, PRACK,  REFER, SUBSCRIBE, NOTIFY, INFO, REGISTER
Accept: application/sdp
Content-Length: 176
v=0
o=CiscoSystemsSIP-GW-UserAgent 2940 3062 IN IP4 192.168.217.137
s=SIP Call
c=IN IP4 192.168.217.137
t=0 0
m=audio 0 RTP/AVP 18 0 8 9 4 2 15
Jun  5 18:22:33.087: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
INVITE sip:27312741380@mibcopri.ppr1.gcbstrunk.qos.telkomvoip.co.za SIP/2.0
Via: SIP/2.0/UDP 165.148.65.86:5060;branch=z9hG4bK6abifh205ophrloru2q0.1
To: <sip:27312741380@mibcopri.ppr1.gcbstrunk.qos.telkomvoip.co.za:5060>
From: <sip:+27814208738@ppr1.gcbstrunk.qos.telkomvoip.co.za;user=phone>;tag=SD3047501-snl_0113939063_NSN_CLIENT
Call-ID: SD3047501-42b2beb9df3cd82a22be268123ec5c19-ctvvfv3
CSeq: 1235 INVITE
Contact: <sip:+27814208738@165.148.65.86:5060;transport=udp>
Supported: 100rel
Supported: timer
Accept-Language: en;q=0.0
Allow: REGISTER, INVITE, ACK, BYE, CANCEL, NOTIFY, REFER, INFO, UPDATE, PRACK
Min-SE: 1800
Date: Thu, 05 Jun 2014 18:25:12 GMT
Max-Forwards: 54
Content-Length: 459
v=0
o=- 3656872666 1258553348 IN IP4 165.148.65.86
s=-
c=IN IP4 165.148.65.86
t=0 0
m=audio 49466 RTP/AVP 18 4 8 100 13 118 110 96
a=rtpmap:18 G729/8000
a=fmtp:18 annexb=no
a=rtpmap:4 G723/8000
a=fmtp:4 annexa=no
a=rtpmap:8 PCMA/8000
a=rtpmap:100 telephone-event/8000
a=fmtp:100 0-15
a=rtpmap:13 CN/8000
a=rtpmap:118 PCMA/8000
a=gpmd:118 vbd=yes
a=rtpmap:110 PCMU/8000
a=gpmd:110 vbd=yes
a=rtpmap:96 CLEARMODE/8000
a=sendrecv
a=pmft: T38
Jun  5 18:22:33.091: //1253/322300FB863D/SIP/Msg/ccsipDisplayMsg:
Sent:
SIP/2.0 100 Trying
Date: Thu, 05 Jun 2014 18:22:33 GMT
CSeq: 1235 INVITE
Content-Length: 0
Jun  5 18:22:33.095: //1254/322300FB863D/SIP/Msg/ccsipDisplayMsg:
Sent:
INVITE sip:27312741380@192.168.217.132:5060 SIP/2.0
Via: SIP/2.0/UDP 192.168.217.137:5060;branch=z9hG4bK14E938
Remote-Party-ID: <sip:+27814208738@192.168.217.137>;party=calling;screen=no;privacy=off
From: <sip:+27814208738@192.168.217.137>;tag=29E7A084-FB4
To: <sip:27312741380@192.168.217.132>
Call-ID: 3224394B-EC1511E3-8643A429-E850C69C@192.168.217.137
Min-SE:  1800
Cisco-Guid: 0841154811-3960803811-2252186665-3897607836
CSeq: 101 INVITE
Timestamp: 1401992553
Contact: <sip:+27814208738@192.168.217.137:5060>
Expires: 180
Max-Forwards: 53
Content-Length: 316
v=0
o=CiscoSystemsSIP-GW-UserAgent 3539 9190 IN IP4 192.168.217.137
s=SIP Call
t=0 0
m=audio 16670 RTP/AVP 18 8 0 101
a=fmtp:18 annexb=yes
a=fmtp:101 0-16
Jun  5 18:22:33.099: //1254/322300FB863D/SIP/Msg/ccsipDisplayMsg:
Received:
SIP/2.0 100 Trying
CSeq: 101 INVITE
Content-Length: 0
Jun  5 18:22:33.103: //1254/322300FB863D/SIP/Msg/ccsipDisplayMsg:
Received:
To: <sip:27312741380@192.168.217.132>;tag=64~eac86613-3187-4dfa-9f31-34008a83626b-21101107
CSeq: 101 INVITE
Reason: Q.850;cause=1
Content-Length: 0
Jun  5 18:22:33.103: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Sent:
ACK sip:27312741380@192.168.217.132:5060 SIP/2.0
Max-Forwards: 70
CSeq: 101 ACK
Content-Length: 0
Jun  5 18:22:33.103: //1253/322300FB863D/SIP/Msg/ccsipDisplayMsg:
Sent:
Via: SIP/2.0/UDP
To: <sip:27312741380@mibcopri.ppr1.gcbstrunk.qos.telkomvoip.co.za:5060>;tag=29E7A08C-10AE
CSeq: 1235 INVITE
Content-Length: 0
Jun  5 18:22:33.107: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
ACK sip:27312741380@mibcopri.ppr1.gcbstrunk.qos.telkomvoip.co.za SIP/2.0
CSeq: 1235 ACK
Max-Forwards: 54
Content-Length: 0
You are getting 404 not found. You need to check the CSS on your sip trunk in CUCM and ensure that it has access to the pattern you are trying to send the call to 27312741380..
Does this number exist in your cucm? What partition is it in? Does the CSS of the sip trunk has access to this partition?
Hi Ayodeji,
Im sorry to barge into this discussion with a different issue.
I have a similar setup CUCM----CUBE---TRUNK-----SP. Everything works fine but my problem is that whenever i make a call from my cisco endpoints (mostly cisco 7942G ), I immediately hear a ringback even without ringing on the called party. Although this is not a problem but it gives false information to my users. Ive tried disabling early offer on 180 but no luck.
In summary, what i want to achieve is get ringback, disconnect messages from the called device and not some virtual ringing.
Thanks in advance
Its difficult to say where the ring back is coming from without looking at logs etc.
By default, Cisco Unified Communications Manager  will signal the calling phone to play local ringback if SDP is not  received in the 180 or 183 response. If SDP is included in the 180 or  183 response, instead of playing ringback locally, Cisco Unified  Communications Manager will connect media, and the calling phone will  play whatever the called device is sending (such as ringback or busy  signal)
Hi Deji,
Thanks for the response, dont know how i missed the alert in my email.
Can you tell me which log i should post? I have this service tested satisfactorily, the only thing holding it from being rolled out to my users is the ringback issue.
Thanks in advance.
Ideally a "debug ccsip messages" should be good enough. Just include the calling and called number
Hi Deji,
Find attached ccsip debug messages.
In general, ringing is controlled via two Informational Responses in SIP: the 180
Ringing and the 183 Session Progress.
The main difference between them, is the 180 Ringing message instructs the UA to create the dial-tone locally, whereas the 183 Session Progress contains an SDP, which allows for regional ring-back and carrier announcements as well.
In the logs, you sent your provider is sending both session progress and ringing, which is a little odd...normally after 183 session progress we move to 200 OK. However there is a ringing after 183 session progress.
I suggest you contact your provider and let them know that this is not acceptable. You can do an inbound test, ie call from outside to an ip phone on cucm and you shouldnt see this behaviour. The logs should show only either 183 session progress or 180 ringing.
