ā12-28-2013 09:33 PM - edited ā03-16-2019 09:01 PM
We have procurred CUCM 9 and its user connect license.
However we wish to install older CUCM version 8.6. Is there a way to downgrade / migrate license of CUCM 9 to 8.6 version?
Andy
ā12-29-2013 08:15 AM
You could try contacting licensing@cisco.com, but I think your only option will be to RMA the licenses and procure desired version.
On a side note what is your reasoning with going with version 8.6?
Chris
ā10-06-2016 02:54 AM
Pls open a case with Cisco licensing @licensing@cisco.com,they will take approval from the Cisco Product Manager, who can still approved to downgrade the license as long as your server is still running on version 9.
and provide them PAK and the License Request from ELM so that they we can issue downgraded license the license for you.
Pls rate the feedback!!
ā12-15-2015 03:13 AM
Hello Andersson,
Could you please give us your feedback on what did you do to install 8.x licenses as you bought 9.x ones ?
We have the same issue here. Our customer is running CUCM 8.x and he is not willing to upgrade to the last version. He just ordered addon licenses, however the addon licenses were ordered as 10.x
And an upgrade is not feasible since older licenses are not under coverage (at least in the moment I'm talking now).
Thank you in advance for your input.
ā12-15-2015 03:49 AM
Try contacting Cisco Global Licensing Team at licensing@cisco.com and check if they can help you with providing the replacement license.
Do not forget to mention your Sales Order (SO) Number and PAK in the email to them along with your other necessary entitlement details.
Deepak
ā12-15-2015 06:00 AM
As stated in my original response to the poster this needs to be addressed with licensing@cisco.com . I have done it few times when customer decided to install newer version from what was delivered. With that being said version 8 is EOS, so not sure if licensing team can still issue licenses for it.
