Cisco Unity Connection User Administration
I am hitting an unusual issue with password resets on Cisco Unity Connection. 8.6
We have a list of folks who perform the routine password resets that are often required of end users.
I am seeing an issue that is intermittant (I love that word), I know all those TAC folks just LOVE it too.  About once in blue moon, we will get a user who needs a password reset, BUT the folks assigned to the" Cisco Knows more about what its customers need than they do", predefined, "Help Desk Administrator" Role, are not able to reset the user's password.  It requires someone who is assigned to a higher Role.
I am hopeful that someone has seen this before and can provide some guidance, if not I will have to call tAc.
TwD
13 Replies 13
Chris Deren
Thomas,
Sorry to hear your frustration.  However "Help Desk Administrator" Role should provide ability to reset passwords, can you explain what is not working?
How are the administrators going about resetting the password? and what is not working? Perhaps I am missing something else here?
Chris
Randomly, users will call in, and the folks that reset the passwords who are assigned to the Help Desk Administrator role, are unable to reset these users.  Once a System Administrator resets the password, the Desk Administrator folks can reset it.  So, again it is random, and rare.  BUT it happens enough, that we see 3 to 7 of these a month.  There is nothing different between the user account that has the issue and other users.  It is not always the same user, and again, when someone with a higher role resets the password, it returns to normal and the Help Desk Administrator folks are again able to reset the password...  It seems more like some kind of Database/Permissions issue for rare accounts that have something causing them to be inaccessible by those assigned to the Desktop Administrator role.
Do you happen to know what error message they are getting?
Sounds like a bug, I have not heard of this one before, did you try searching for it in bug toolkit?
Chris
No error, it is greyed out.  Yes I searched bugs, even pinged someone inside and them search Topic... I am about 85% sure it is a bug, hence the post.  Can't hurt to ask.  right?
Absolutely, sorry I don't have specifics :-( Maybe someone else has seen something similar.
Good luck.
Chris
Rob Huffman
Hi Thomas,
Are the helpdesk admins able to even search for the user? Do they get that far?
Cheers!
Rob
"Always movin' ahead and never lookin' back" - Springsteen
TAC Case Opened.
Got a resolution for us? I'm seeing the same thing now in 8.6.1.20000-109
jshupick
Level 7
Level 7
Yes do we have a resolution? I am also seeing this in 8.6.1.
Please let us know what you did or what Cisco did to fix it.
Thanks, Jeremy
I found that the issue was with users who had the Greeting Administrators role assigned; the Help Desk Admin users weren't able to change the passwords for those with this privilege. I opened a TAC case in which they confirmed that this is expected behavior (for both Help Desk Administrators AND the User Administrators role) and advised me to open an enhancement request, which I didn't do.
From my take on it, the "Greeting Administrators" are seen as administrative accounts, whereas the help desk admin and user admin roles are intended to modify end users. If someone has a better theory, I'm open to it...
I worked around it by adding a new account for one of the admins, and assigning it the System Administrator role; anyone who has this issue contacts him and he knows how to fix it. That's obviously a very scary solution, but it's what we had to do.
arghakamaldey
Did anyone found out a fix other than assigning system admin role ? I am using Unity 12.5.
Steven L
this post is 12 years old......please start a new one for your issue
arghakamaldey
no problem.. help not needed atm.. found out the details in admin guide... user should have two seperate accounts
