CME 8.6 Calls via FXO giving busy
Ahmed Adeyemi
Level 4
Level 4
I configured a CME router and i am trying to place an outbound call but whenever i do, i keep getting a busy tone. While watching the FXO port that i am using, see the port keep coming on like its being used to attempt to place an outbound call. I ran a debug Voice cacti inout and debug ccsip messages and i do see transactions occurring when i am not placing an outbound call.
I was able to get this working yesterday by just swapping the FXO port that i was using but it is unreal if i keep swapping ports daily. The FXO card i am using is VIC2-4FXO. I have ran this same setup on 4 different 2821/2851's and i am getting the same issue.
Below are the logs i have. The log contains voip ccapi inout and ccsip messages.
Also i have my config below. The Skinny phones registers just fine. i am yet to try the SIP phones
2 Accepted Solutions
Nadeem Ahmed
Hey Bodbol,
Can you please provide some information what is the exact call-flow , when looking into the debugs which you have collected looks like dial-peer issue where we are getting cause value 1 however, can you please re-collect following debugs and confirm the call.
Please mention the calling and called party number
debug voip ccapi inout
debug vpm signal
debug voip vtsp default
debug voip vtsp session
Debug ccsip message (If there is SIP phone involve)
Br, Nadeem Please rate all useful post.
Connection plar is used for incoming call and should mention internal ext number there so if someone call fxo number then call can connect on that ext, but you said issue is in outbound calls.
Suresh
6 Replies 6
Suresh Hudda
You have dialed 6576670058, and its not matching with destination patterns of any of pots dial peer. So adjust the destination pattern at one of the pots dial peer.
Suresh
Thanks for responding. that number was actually the number to my FXO port which i did have as my connection plar in my FXO config
Suresh
Correct, connection Plar is used to receive the inbound call. I was just trying several options to see why exactly its been breaking and i still don't get it. On the other note. i just blew out the config and re-configured it and now its fully working.
The irony is that the majority if not all the configuration stayed the same with the exception that instead of me uploading the config, i just went in and manually configured it all again.
I appreciate everyone's input and suggestions.
Can you please make another test call with suggested debugs , kindly mention the callling and called party number
Nadeem Ahmed
Hey Bodbol,
debug vpm signal
