CME SIP dial-peer to POTS dial-peer preference failover?
NicP270591
Hi guys,
I have a CME router with both SIP dial peers (preference 1) and FXO PSTN dial-peers for failover (preference 2). When SIP is unreachable, you go to dial a call, it hangs on "Ring out" for a minute or so and then returns busy tone/unknown number error. There is no failover to the preference 2 dial peer on the FXO port (same pattern just preference 2 and mapped to a port rather than SIP).
1. Why is there not failover?
2. Can I reduce the hunt time to a few seconds before it cancels SIP and switches to the PSTN peer?
3. Does this even work by default on CME, or will I need SRST on the router?
Nic.
6 Replies 6
Hi Nic,
It should work out of the box, you don't have to enable SRST. Please attach the configuration of the router, debug ccsip messages and debug voice ccapi inout for a call.
You can adjust timers in sip-ua section using timers command.
Kind regards,
Andrew C.
Kind regards, Andrew C.
Hi Andrew,
Config as follows:
dial-peer voice 1007 voip
corlist outgoing callMobile
description IP Mobile Calls
translation-profile outgoing 1
preference 1
destination-pattern 004........
session protocol sipv2
session target sip-server
voice-class codec 1
dtmf-relay rtp-nte
no vad
dial-peer voice 2017 pots
description POTS IP Mobile Calls BKCLID
preference 2
port 0/0/0
forward-digits 14
prefix 1831
no register e164
sip-ua
credentials username USERNAME password 7 PASSWORD realm REALM
authentication username USERNAME password 7 PASSWORD realm REALM
no remote-party-id
retry invite 2
timers trying 150
registrar dns:sipprovider.net expires 3600
sip-server dns:sipprovider.net
I attempted debug as requested, nothing showed up in my telnet session during a call attempt. Odd.
Nic.
Hi Nic,
The config seems fine for me, the only thing you can change is to specify the destination-pattern more strictly -
^004........$
It's difficult to say what's wrong without the debug, maybe you forgot to say 'term mon'?
Kind regards,
Andrew C.
Jonathan Schulenberg
I'm not saying this is the only problem, but one problem would be the default value of sip-ua > retry invite command. By default the value it has essentially causes a huntstop if all six retries fail. Try changing the command to four or less (I use two) and see if that makes a difference. Beyond that we need the details Andrew asked for.
http://www.cisco.com/en/US/docs/ios/voice/command/reference/vr_r1.html#wp1550337
sip-ua
retry invite 2
Please remember to rate helpful responses and identify helpful or correct answers.
Dennis Mink
Also test your pots dialpeer by shutting down your 1007 dialpeer and the making an outbound call
Sent from Cisco Technical Support Android App
Please remember to rate useful posts, by clicking on the stars below.
I shut down my 1007 for testing and the call failed. But normally it works fine. Very strange, I will do some testing next time I get the chance and report back. May take a couple days however before I can get on-site.
Nic.
