11-12-2012 03:45 PM - edited 03-16-2019 02:09 PM
Anybody knows why there is no recommended version for CME that apply to new version (at least 8.6)
which version should I install 8.6 or new 9.1 ??
regards
Cisco Unified CME and Cisco IOS Software Version Compatibility Matrix Revised: July 27, 2012 | |||||||||||||
Naming | Cisco Unified Communications Manager Express (Cisco Unified CME), formally known as Cisco Unified CallManager Express. | ||||||||||||
Documentation | See the Cisco Unified CME documentation list. | ||||||||||||
Features | |||||||||||||
Downloads | |||||||||||||
DDTS Information | |||||||||||||
Cisco IOS Release 1 | Cisco Unified CME Version | Cisco Unified CME GUI Version 2 | Version Specification Link 3 |
15.2(4)M | 9.1 | 9.1.0.0 | |||||||||||
15.2(2)T | 9.0 | 9.0.0.0 | |||||||||||
15.2(1)T | 8.8 | 8.8.0.0 | |||||||||||
15.1(4)M | 8.6 | 8.6.0.0 | |||||||||||
15.1(3)T | 8.5 | 8.5.0.0 | |||||||||||
15.1(2)T | 8.1 | 8.1.0.0 | |||||||||||
15.1(1)T | 8.0 | 8.0.0.0 | |||||||||||
15.0(1)XA | 8.0 | 8.0.0.0 | |||||||||||
15.0(1)M9 | 7.1 - Recommended Version | 7.1.1.0 | |||||||||||
12.4(24)T | 7.1 | 7.1.1.0 | |||||||||||
12.4(22)YB | 7.1 | 7.1.0.0 | |||||||||||
Solved! Go to Solution.
11-13-2012 07:45 AM
be warned to face some ugly issues, when choosing a version randomly.
For example on 8.6:
- No shared line between SIP and SCCP Devices
- No epansion module on 8961
Both should work on 9.1
I recommend to gather all the needed function, then check release notes and Admin Guides to be sure everything you need is supported.
11-14-2012 06:18 AM
Hi Filiberto,
I just thought I would add this guide to help you when determining
CME features/versions
Cisco Unified CME Features Roadmap
http://www.cisco.com/en/US/docs/voice_ip_comm/cucme/admin/configuration/guide/cmeroad.pdf
Cheers!
Rob
"And if I should fall behind
Wait for me" - Springsteen
11-12-2012 04:06 PM
Cisco is usually lacking when it comes to updating this. I have not deployed any 9.X yet, but 8.6 has been solid.
HTH,
Chris
11-12-2012 04:44 PM
Hi Chris,
Thanks a lot for your comments.
regards
11-13-2012 07:45 AM
For example on 8.6:
11-14-2012 06:15 AM
Hi slashdots,
Thanks for your tips.
regards
11-14-2012 06:18 AM
Hi Filiberto,
Cheers!
Rob
11-14-2012 06:30 AM
Hi Rob,
it's a very useful reference.
I like that you're always willing to help all people.
regards
11-14-2012 06:40 AM
Hi Filiberto,
You are always welcome my friend
Glad to be of some small help here.
Cheers!
Rob
