03-29-2011 11:01 AM - edited 03-16-2019 04:13 AM
Hi, thanks in advance for any help you guys can give me.
We have a overhead paging system connected to our voice router on an fxo port. Some times, users would accidentally call the paging line. Is there a command I can use to see who is connected to the fxo port and then disconnect them?
Vince
Solved! Go to Solution.
04-04-2011 11:27 AM
The "sh call active voice brief" will show the voice ports being used.
You can do a shut under the voice ports to drop the active calls on them.
03-29-2011 05:59 PM
You didn't provide enough detail, but I can tell you that the command: shutdown, on your voice gateway's voice-port, will disconnect the call.
Tell us more about your setup.
04-04-2011 11:08 AM
Hi Anthony,
Thanks for replying.
I'm running CUCM 7.1.3. I have a Cisco 2851 router with an FXO expansion module.
Here is the config for the voice-port that my paging system is on:
voice-port 1/0/4
connection plar 112001
Here is my dial-peer:
dial-peer voice 112001 pots
destination-pattern 112001
port 1/0/4
I have a route pattern configured to send 112001 to the 2851 router. The router then routes the call out to 1/0/4. Everything works fine.
I just need to know how to list active calls and forcefully disconnect one if needed.
04-04-2011 11:27 AM
04-04-2011 11:29 AM
Hi Payal,
Thanks for your reply. Is this the only way to disconnect the call? For instance, is there a way to disconnect the call legs without shuttng down the port?
04-04-2011 11:35 AM
From the CLI of the router, that is the only way i can think of to disconnect calls
04-05-2011 09:30 AM
Ok, Thanks Payal.
