Command to kill Pots call on router
vincehgov
Hi, thanks in advance for any help you guys can give me.
We have a overhead paging system connected to our voice router on an fxo port.  Some times, users would accidentally call the paging line.  Is there a command I can use to see who is connected to the fxo port and then disconnect them?
Vince
Payal Bhaduri
The "sh call active voice brief" will show the voice ports being used.
You can do a shut under the voice ports to drop the active calls on them.
6 Replies 6
Anthony Holloway
You didn't provide enough detail, but I can tell you that the command: shutdown, on your voice gateway's voice-port, will disconnect the call.
Tell us more about your setup.
Hi Anthony,
Thanks for replying.
I'm running CUCM 7.1.3.  I have a Cisco 2851 router with an FXO expansion module.
Here is the config for the voice-port that my paging system is on:
voice-port 1/0/4
    connection plar 112001
Here is my dial-peer:
dial-peer voice 112001 pots
    destination-pattern 112001
    port 1/0/4
I have a route pattern configured to send 112001 to the 2851 router.  The router then routes the call out to 1/0/4.  Everything works fine.
I just need to know how to list active calls and forcefully disconnect one if needed.
Payal Bhaduri
Hi Payal,
Thanks for your reply.  Is this the only way to disconnect the call?  For instance, is there a way to disconnect the call legs without shuttng down the port?
Payal Bhaduri
From the CLI of the router, that is the only way i can think of to disconnect calls
Ok, Thanks Payal.
