CUCM 10 subs
juan_cye_ccna
I have installed CUCM 10.0 and right now I am trying to install CUCM subscriber but I getting some error how it is shown in attached file.
I have confirmed all of these but the issue persists, How can I solve it?
Thanks in advance.
Hi Juan,
output shows NTP is unsynchronised.
regds,
aman
13 Replies 13
Jaime Valencia
Are both servers in the same LAN?
Can you post the output of what the error tells you to check??
java
if this helps, please rate
Hi Jaime,
yes both servers are in the same LAN. Error message says:
-verify network connectivity to pub and sub
-add sub´s hostname in CUCM pub
-check ntp in pub
I have checked all of these. Tests have been successful but so far I have not could finish the installation process.
I'd check the following:
1. NTP sync status on the pub node. Specifically take note of the stratum level.
2. Add forward and reverse DNS records for Pub and Sub nodes
3. Make sure you added Sub as server object (in CCMAdmin). Double check IP address or hostname (whichever applies to your design)
-Bill (@ucguerrilla)
HTH -Bill (b) http://ucguerrilla.com (t) @ucguerrilla
Hi Juan,
the attached snapshot points to ntp issue.
Can u post the output of utils ntp status from Publisher ?
regds,
aman
Hi Juan,
there is also a bug related to NTP
CSCuj81503 : Subscriber Installation halts because of NTP Issue.
Symptom:
Symptoms:Subscriber Installation halts at NTP Server on First Node is inaccessible information.
Conditions:
Description:Subscriber Installation halts because of NTP Issue.
Known Affected Releases: (1)
10.0(0.98000.402)
regds,
aman
Hi Juan,
regds,
aman
Hi Aman,
Thanks for your helping. I had to configure NTP on router because AD-NTP did not work to CUCM sub and UC sub.
Hi Aman,
this is output to NTP on pub:
admin:utils ntp status
ntpd (pid 3885) is running...
     remote           refid      st t when poll reach   delay   offset  jitter
 10.100.0.3      10.100.0.2       2 u   56   64  377    3.685  1187.75   6.438
unsynchronised
  time server re-starting
   polling server every 64 s
Current time in UTC is : Tue Jul  8 13:26:53 UTC 2014
Current time in America/Bogota is : Tue Jul  8 08:26:53 COT 2014
Hi William,
I checked all of these and are ok.
Have you added the subscriber in Publisher (system ->server) before installing subscriber ?
Suresh
I actually meant screenshots of each thing it told you to verify, but the problem is indeed, the NTP, which you said you had verified.
It clearly says it's unsynchronised in the output.
java
Hellow,
I habe exactly the same problem.
Would you please tell me how can I synchronize my NTP on the CLI ?
Best Regards
Anahita
