Bookmark
Subscribe
2605
CUCM Longest Idle Timer - Consecutive Calls
mbuttnerMSI
I have a customer on 9.1 CUCM. They have a very basic hunt pilot->hunt list->line group.
There are 30 some phones in a single line group and they are configured for the default Distribution Algorithm, Longest Idle Timer. The lines have a busy trigger of 2.  What they are experiencing is a user will receive a hunt pilot call and then a few seconds later receive another from the hunt pilot.
I understand the difference between busy, available, and idle member. But the Longest Idle timer specifically states it will only distribute a call to idle members. An idle member is an individual not on a hunt group call. Yet users are receiving two hunt group calls?
Can someone explain what’s happening here? I already confirmed that the second and first call are actually Hunt Pilot calls. The SRND, System Guide and Admin guide just reconfirm my logic here that a user should not receive the next call.
5 Replies 5
Dennis Mink
If you change the busy trigger to 1, what happens then?
Please remember to rate useful posts, by clicking on the stars below.
yahsiel2004
Level 7
Level 7
Are any other users receiving calls. You may have them logged out of the hint group using the HLog softkey. Also if the users have DND on I believe that they will not get the call either.
Yosh
HTH Regards, Yosh
Busy trigger of 1 would skip over. I know because we have similar line groups with lines configured for busy trigger 1.
I turned on the Route tracing and pulled SDLs. Looking at the log. First call comes in, the Hunt List selects a phone. Line 05325060.002 and .003 choses the distribution algorithm and queries for idle or available. Then at Line 05325065.003 it checks the busy trigger which is 2 in this case. When the second call comes in it does the same, and queries the active call as 1 but it still delivers.
Shouldn't it only be querying for idle status? Thats what the distribution algorithm is defined as. If I were to select any other algorithm this is when "available" status would come into play.
First Call the, CCM selects a device from the HuntList
05325057.001 |13:32:56.514 |AppInfo  |HuntListCdrc::null0_CcSetupReq - Selecting a device.
05325057.002 |13:32:56.514 |AppInfo  |HuntListCdrc::selectDevices -- mTemporaryDeviceInfoList.size = 1.
05325058.000 |13:32:56.514 |SdlSig   |DmPidReq                               |initialized                    |DeviceManager(1,100,199,1)       |HuntListCdrc(1,100,181,2497)     |1,100,13,991.13362^192.168.100.14^CiscoUM1-VI1 |[T:N-H:0,N:0,L:0,V:0,Z:0,D:0]  Cepn=a3065101-c719-5bd8-73f7-edffe0cdc3b7 Id=0
05325058.001 |13:32:56.514 |AppInfo  |SMDMSharedData::findAliasRegInfo - AliasName = a3065101-c719-5bd8-73f7-edffe0cdc3b7 not in AliasInfo hashmap
05325058.002 |13:32:56.514 |AppInfo  |DeviceManager::star_DmPidReq - RequestedName=a3065101-c719-5bd8-73f7-edffe0cdc3b7 LookupName=a3065101-c719-5bd8-73f7-edffe0cdc3b7
05325058.003 |13:32:56.514 |AppInfo  |SMDMSharedData::findLocalDevice - Name=4005:e565da52-cd3c-56dd-651e-73e0a4e23b84 Key=a3065101-c719-5bd8-73f7-edffe0cdc3b7 isActvie=1 Pid=(1,167,291) found
Ditrubution method selected, route to device.
05325060.001 |13:32:56.514 |AppInfo  |HuntListCdrc::select_facility_DmPidRes: Execute a route action.
05325060.002 |13:32:56.514 |AppInfo  |HuntListCdrc::algorithmCategorization -- CDRC_SERIAL_DISTRIBUTION type=3
05325060.003 |13:32:56.514 |AppInfo  |HuntListCdrc::routeAction -- current device name=a3065101-c719-5bd8-73f7-edffe0cdc3b7, idle or available
05325060.004 |13:32:56.514 |AppInfo  |HuntListCdrc::distributeCall CI=32504289 BRANCH=0
05325060.005 |13:32:56.514 |AppInfo  |HuntListCdrc::SendCcNotifyReq.
05325060.006 |13:32:56.514 |AppInfo  |HuntListCdrc::executeRouteAction: EXTEND_CALL_TO_CURRENT_MEMBER -- Success
05325063.001 |13:32:56.514 |AppInfo  |LineControl(291) - 0 calls, 0 CiReq, busyTrigger=2, maxCall=3
05325063.002 |13:32:56.514 |Created  |                                       |                               |LineCdpc(1,100,168,11436)        |LineControl(1,100,167,291)       |                                         |NumOfCurrentInstances: 19
05325063.003 |13:32:56.514 |AppInfo  |LineControl(291) - Get call instance=1 for CI=32504289
05325063.004 |13:32:56.514 |AppInfo  |LineControl(291): restart0_CcSetupReq update State of cdpc (11436) to receive7
05325064.000 |13:32:56.514 |SdlSig   |CcSetupReq                             |null0                          |LineCdpc(1,100,168,11436)        |LineControl(1,100,167,291)       |1,100,13,991.13362^192.168.100.14^CiscoUM1-VI1 |[R:N-H:0,N:1,L:0,V:0,Z:0,D:0] CI=32504289 CI.branch=0  sBPL.plid=65 sBPL.l=1 sBPL.pl=5 sBPL.msd=0  FDataType=0opId=0ssType=0 SsKey=0invokeId=0resultExp=Fbpda=F pi.piid=30 pi.l=0 pi2.piid=30 pi2.l=0 pi3.piid=30 pi3.l=0 FQCGPN=ti=1nd=8601pi=0si1 preXCgpn=tn=0npi=0ti=1nd=8601pi=0si0 cgPart=5af7d28a-afef-e090-bfd6-885e7b5a2ea5 cgPat=8601 cgpn=tn=0npi=0ti=1nd=8601pi=1si1 cgpnVM= unXCgpn=tn=0npi=0ti=1nd=8601pi=1si0 cName=locale: 1 Name: VoiceMail UnicodeName: VoiceMail pi: 1 DD=tn=0npi=1ti=1nd=8758pi=0si1 origDD=tn=0npi=1ti=1nd=8758pi=0si1 preXCdpn=tn=0npi=0ti=1nd=8758pi=0si0 preXTagsList=SUBSCRIBER preXPosMatchList=8758 cdPart=e565da52-cd3c-56dd-651e-73e0a4e23b84 cdPat=8758 cdpn=tn=0npi=0ti=1nd=8758pi=0si1 cdpnVMbox= localPatternUsage=7 connectedPatternUsage=2 itrPart= itrPat= LRPart=e565da52-cd3c-56dd-651e-73e0a4e23b84 LRPat=8758 LR=tn=0npi=0ti=1nd=8758pi=0si1 LRVM= LRName=locale: 1 Name:  UnicodeName:  pi: 0 FQOCpdn=ti=1nd=8758pi=0si1 fFQLRNum=ti=1nd=8758pi=0si1 oPart=e565da52-cd3c-56dd-651e-73e0a4e23b84 oPat=8758 oCpdn=tn=0npi=0ti=1nd=8758pi=0si1 oCdpnVM= oRFR=0 oName=locale: 1 Name:  UnicodeName:  pi: 0 ts=SUBSCRIBER posMatches=8758 withTags= withValues= rdn.l=0IpAddrMode=0 ipAddrType=0 ipv4=192.168.100.14:0 region=Voicemail-REG capCount=4 ctiActive=F ctiFarEndDev=1 ctiCCMId=1 cgPtyDev=CiscoUM1-VI1 callInst=1 OLF=1Supp DTMF=3DTMF Cfg=1DTMF Payload=0isOffNetDev=F bc.l=3 bc.itr=1 bc.itc=0 bc.trm=0 bc.tm=4 maxForwards=70 cgpnMaskedByRedirect=F callingLRG=91745215-1f79-1224-9738-cedd559d82f4 featCallType=0 muteEnabled=0 associatedCallCI=0 featurePriority=1 nonTargetPolicy=0 unconsumedDigits= suppressMOH=T numPlanPkid =b875b09c-acaf-e58f-2f01-1604872a6e56 networkDomain= bitMask=0 SetupReason=0 routeClass=1 sideACmDeviceType=4 protected=1 ControlProcessType=0 tokens=0 isPresent=F transitCount=0 geolocInfo={geolocPkid=, filterPkid=, geolocVal=, devType=4} locPkid=acf6b34a-3dc5-48d5-c0d3-9be25c1288c3 locName=Voicemail-LOC deductBW=F fateShareId=StandAloneCluster:32504288 videoTrafficClass=0 oFromAnalogDvc=F bridgeParticipantID= callingUsr= remoteClusterID= isEMCCDevice=F HP=b875b09c-acaf-e58f-2f01-1604872a6e56 HPName=locale: 1 Name:  UnicodeName:  pi: 0 lHPMemCEPN= cHPMemCEPN=TransparentData=null CanSupportSIPTandN=false TransId=0 AllowBitMask=0x0 UserAgentOrServer= OrigDDName=locale: 1 Name:  UnicodeName:  pi: 0 mCallerId= mCallerName=LatentCaps=null icidVal= icidGenAddr= oioi= tioi= ptParams= receivedPAID= routeHdr= routeCepn= requestURI= PCVFlag=F originallyHadISUP=F isIMSFinalRoute=F IMSMode=0 originalLRG= lastRedirectingLRG= nwLoc=0
05325064.001 |13:32:56.514 |AppInfo  |LineCdpc(11436): -dispatchToAllDevices-, sigName=CcSetupReq, device=SEP5475D02B2F9E
05325065.000 |13:32:56.514 |SdlSig   |CcSetupReq                             |restart0                       |StationD(1,100,58,339)           |LineCdpc(1,100,168,11436)        |1,100,13,991.13362^192.168.100.14^CiscoUM1-VI1 |[R:N-H:0,N:0,L:0,V:0,Z:0,D:0] CI=32504289 CI.branch=0  sBPL.plid=65 sBPL.l=1 sBPL.pl=5 sBPL.msd=0  FDataType=0opId=0ssType=0 SsKey=0invokeId=0resultExp=Fbpda=F pi.piid=30 pi.l=0 pi2.piid=30 pi2.l=0 pi3.piid=30 pi3.l=0 FQCGPN=ti=1nd=8601pi=0si1 preXCgpn=tn=0npi=0ti=1nd=8601pi=0si0 cgPart=5af7d28a-afef-e090-bfd6-885e7b5a2ea5 cgPat=8601 cgpn=tn=0npi=0ti=1nd=8601pi=1si1 cgpnVM= unXCgpn=tn=0npi=0ti=1nd=8601pi=1si0 cName=locale: 1 Name: VoiceMail UnicodeName: VoiceMail pi: 1 DD=tn=0npi=1ti=1nd=8758pi=0si1 origDD=tn=0npi=1ti=1nd=8758pi=0si1 preXCdpn=tn=0npi=0ti=1nd=8758pi=0si0 preXTagsList=SUBSCRIBER preXPosMatchList=8758 cdPart=e565da52-cd3c-56dd-651e-73e0a4e23b84 cdPat=8758 cdpn=tn=0npi=0ti=1nd=8758pi=0si1 cdpnVMbox= localPatternUsage=7 connectedPatternUsage=2 itrPart= itrPat= LRPart=e565da52-cd3c-56dd-651e-73e0a4e23b84 LRPat=8758 LR=tn=0npi=0ti=1nd=8758pi=0si1 LRVM= LRName=locale: 1 Name:  UnicodeName:  pi: 0 FQOCpdn=ti=1nd=8758pi=0si1 fFQLRNum=ti=1nd=8758pi=0si1 oPart=e565da52-cd3c-56dd-651e-73e0a4e23b84 oPat=8758 oCpdn=tn=0npi=0ti=1nd=8758pi=0si1 oCdpnVM= oRFR=0 oName=locale: 1 Name:  UnicodeName:  pi: 0 ts=SUBSCRIBER posMatches=8758 withTags= withValues= rdn.l=0IpAddrMode=0 ipAddrType=0 ipv4=192.168.100.14:0 region=Voicemail-REG capCount=4 ctiActive=F ctiFarEndDev=1 ctiCCMId=1 cgPtyDev=CiscoUM1-VI1 callInst=1 OLF=1Supp DTMF=3DTMF Cfg=1DTMF Payload=0isOffNetDev=F bc.l=3 bc.itr=1 bc.itc=0 bc.trm=0 bc.tm=4 maxForwards=70 cgpnMaskedByRedirect=F callingLRG=91745215-1f79-1224-9738-cedd559d82f4 featCallType=0 muteEnabled=0 associatedCallCI=0 featurePriority=1 nonTargetPolicy=0 unconsumedDigits= suppressMOH=T numPlanPkid =b875b09c-acaf-e58f-2f01-1604872a6e56 networkDomain= bitMask=0 SetupReason=0 routeClass=1 sideACmDeviceType=4 protected=1 ControlProcessType=0 tokens=0 isPresent=F transitCount=0 geolocInfo={geolocPkid=, filterPkid=, geolocVal=, devType=4} locPkid=acf6b34a-3dc5-48d5-c0d3-9be25c1288c3 locName=Voicemail-LOC deductBW=F fateShareId=StandAloneCluster:32504288 videoTrafficClass=0 oFromAnalogDvc=F bridgeParticipantID= callingUsr= remoteClusterID= isEMCCDevice=F HP=b875b09c-acaf-e58f-2f01-1604872a6e56 HPName=locale: 1 Name:  UnicodeName:  pi: 0 lHPMemCEPN= cHPMemCEPN=TransparentData=null CanSupportSIPTandN=false TransId=0 AllowBitMask=0x0 UserAgentOrServer= OrigDDName=locale: 1 Name:  UnicodeName:  pi: 0 mCallerId= mCallerName=LatentCaps=null icidVal= icidGenAddr= oioi= tioi= ptParams= receivedPAID= routeHdr= routeCepn= requestURI= PCVFlag=F originallyHadISUP=F isIMSFinalRoute=F IMSMode=0 originalLRG= lastRedirectingLRG= nwLoc=0
05325065.001 |13:32:56.515 |AppInfo  |$URI CcmCcmdbHelper::buildLineStructGivenLiteDnData: pattern=4005, Primary URI=
05325065.002 |13:32:56.515 |AppInfo  |StationD - adding linestruct at index 1
05325065.003 |13:32:56.515 |AppInfo  |StationD:    (0000339) DEBUG whatToDo: line=1 calls=0 limit=3, busy=2. GCI=(1, 20749), cm_PL=(5, 0).
05325065.004 |13:32:56.515 |AppInfo  |StationD:    (0000339) DEBUG  whatToDo: busy trigger not hit... send to open appearance
Second call comes in
05326570.001 |13:33:08.639 |AppInfo  |HuntListCdrc::select_facility_DmPidRes: Execute a route action.
05326570.002 |13:33:08.639 |AppInfo  |HuntListCdrc::algorithmCategorization -- CDRC_SERIAL_DISTRIBUTION type=3
05326570.003 |13:33:08.639 |AppInfo  |HuntListCdrc::routeAction -- current device name=a3065101-c719-5bd8-73f7-edffe0cdc3b7, idle or available
05326570.004 |13:33:08.639 |AppInfo  |HuntListCdrc::distributeCall CI=32504279 BRANCH=0
05326570.005 |13:33:08.639 |AppInfo  |HuntListCdrc::SendCcNotifyReq.
05326570.006 |13:33:08.640 |AppInfo  |HuntListCdrc::executeRouteAction: EXTEND_CALL_TO_CURRENT_MEMBER -- Success
05326571.000 |13:33:08.640 |SdlSig   |CcSetupReq                             |restart0                       |LineControl(1,100,167,291)       |HuntListCdrc(1,100,181,2495)     |1,100,13,991.13354^192.168.100.14^CiscoUM1-VI1 |[R:N-H:0,N:0,L:0,V:0,Z:0,D:0] CI=32504279 CI.branch=0  sBPL.plid=65 sBPL.l=1 sBPL.pl=5 sBPL.msd=0  FDataType=0opId=0ssType=0 SsKey=0invokeId=0resultExp=Fbpda=F pi.piid=30 pi.l=0 pi2.piid=30 pi2.l=0 pi3.piid=30 pi3.l=0 FQCGPN=ti=1nd=8601pi=0si1 preXCgpn=tn=0npi=0ti=1nd=8601pi=0si0 cgPart= cgPat= cgpn=tn=0npi=0ti=1nd=+19132407451pi=1si3 cgpnVM= unXCgpn=tn=0npi=0ti=1nd=8601pi=1si0 cName=locale: 1 Name:  UnicodeName:  pi: 1 DD=tn=0npi=1ti=1nd=8758pi=0si1 origDD=tn=0npi=1ti=1nd=8758pi=0si1 preXCdpn=tn=0npi=0ti=1nd=8758pi=0si0 preXTagsList=SUBSCRIBER preXPosMatchList=8758 cdPart=e565da52-cd3c-56dd-651e-73e0a4e23b84 cdPat=8758 cdpn=tn=0npi=0ti=1nd=8758pi=1si1 cdpnVMbox= localPatternUsage=7 connectedPatternUsage=2 itrPart= itrPat= LRPart=e565da52-cd3c-56dd-651e-73e0a4e23b84 LRPat=8500 LR=tn=0npi=0ti=1nd=8500pi=0si1 LRVM= LRName=locale: 1 Name: VoiceMail UnicodeName: VoiceMail pi: 0 FQOCpdn=ti=1nd=8758pi=0si1 fFQLRNum=ti=1nd=8758pi=0si1 oPart=e565da52-cd3c-56dd-651e-73e0a4e23b84 oPat=8758 oCpdn=tn=0npi=0ti=1nd=8758pi=0si1 oCdpnVM= oRFR=0 oName=locale: 1 Name:  UnicodeName:  pi: 0 ts=SUBSCRIBER posMatches=8758 withTags= withValues= rdn.l=0IpAddrMode=0 ipAddrType=0 ipv4=192.168.100.14:0 region=Voicemail-REG capCount=4 ctiActive=F ctiFarEndDev=1 ctiCCMId=1 cgPtyDev=CiscoUM1-VI1 callInst=0 OLF=1Supp DTMF=3DTMF Cfg=1DTMF Payload=0isOffNetDev=F bc.l=3 bc.itr=1 bc.itc=0 bc.trm=0 bc.tm=4 maxForwards=70 cgpnMaskedByRedirect=F callingLRG=91745215-1f79-1224-9738-cedd559d82f4 featCallType=0 muteEnabled=0 associatedCallCI=0 featurePriority=1 nonTargetPolicy=0 unconsumedDigits= suppressMOH=T numPlanPkid =b875b09c-acaf-e58f-2f01-1604872a6e56 networkDomain= bitMask=0 SetupReason=0 routeClass=1 sideACmDeviceType=4 protected=1 ControlProcessType=0 tokens=0 isPresent=F transitCount=0 geolocInfo={geolocPkid=, filterPkid=, geolocVal=, devType=4} locPkid=acf6b34a-3dc5-48d5-c0d3-9be25c1288c3 locName=Voicemail-LOC deductBW=F fateShareId=StandAloneCluster:32504278 videoTrafficClass=0 oFromAnalogDvc=F bridgeParticipantID= callingUsr= remoteClusterID= isEMCCDevice=F HP=b875b09c-acaf-e58f-2f01-1604872a6e56 HPName=locale: 1 Name:  UnicodeName:  pi: 0 lHPMemCEPN= cHPMemCEPN=TransparentData=null CanSupportSIPTandN=false TransId=0 AllowBitMask=0x0 UserAgentOrServer= OrigDDName=locale: 1 Name:  UnicodeName:  pi: 0 mCallerId= mCallerName=LatentCaps=null icidVal= icidGenAddr= oioi= tioi= ptParams= receivedPAID= routeHdr= routeCepn= requestURI= PCVFlag=F originallyHadISUP=F isIMSFinalRoute=F IMSMode=0 originalLRG= lastRedirectingLRG= nwLoc=0
05326571.001 |13:33:08.640 |AppInfo  |LineControl(291) - 1 calls, 0 CiReq, busyTrigger=2, maxCall=3
05326571.002 |13:33:08.640 |Created  |                                       |                               |LineCdpc(1,100,168,11440)        |LineControl(1,100,167,291)       |                                         |NumOfCurrentInstances: 19
05326571.003 |13:33:08.640 |AppInfo  |LineControl(291) - Get call instance=2 for CI=32504279
05326571.004 |13:33:08.640 |AppInfo  |LineControl(291): restart0_CcSetupReq update State of cdpc (11440) to receive7
05326572.000 |13:33:08.640 |SdlSig   |CcSetupReq                             |null0                          |LineCdpc(1,100,168,11440)        |LineControl(1,100,167,291)       |1,100,13,991.13354^192.168.100.14^CiscoUM1-VI1 |[R:N-H:0,N:1,L:0,V:0,Z:0,D:0] CI=32504279 CI.branch=0  sBPL.plid=65 sBPL.l=1 sBPL.pl=5 sBPL.msd=0  FDataType=0opId=0ssType=0 SsKey=0invokeId=0resultExp=Fbpda=F pi.piid=30 pi.l=0 pi2.piid=30 pi2.l=0 pi3.piid=30 pi3.l=0 FQCGPN=ti=1nd=8601pi=0si1 preXCgpn=tn=0npi=0ti=1nd=8601pi=0si0 cgPart= cgPat= cgpn=tn=0npi=0ti=1nd=+19132407451pi=1si3 cgpnVM= unXCgpn=tn=0npi=0ti=1nd=8601pi=1si0 cName=locale: 1 Name:  UnicodeName:  pi: 1 DD=tn=0npi=1ti=1nd=8758pi=0si1 origDD=tn=0npi=1ti=1nd=8758pi=0si1 preXCdpn=tn=0npi=0ti=1nd=8758pi=0si0 preXTagsList=SUBSCRIBER preXPosMatchList=8758 cdPart=e565da52-cd3c-56dd-651e-73e0a4e23b84 cdPat=8758 cdpn=tn=0npi=0ti=1nd=8758pi=1si1 cdpnVMbox= localPatternUsage=7 connectedPatternUsage=2 itrPart= itrPat= LRPart=e565da52-cd3c-56dd-651e-73e0a4e23b84 LRPat=8500 LR=tn=0npi=0ti=1nd=8500pi=0si1 LRVM= LRName=locale: 1 Name: VoiceMail UnicodeName: VoiceMail pi: 0 FQOCpdn=ti=1nd=8758pi=0si1 fFQLRNum=ti=1nd=8758pi=0si1 oPart=e565da52-cd3c-56dd-651e-73e0a4e23b84 oPat=8758 oCpdn=tn=0npi=0ti=1nd=8758pi=0si1 oCdpnVM= oRFR=0 oName=locale: 1 Name:  UnicodeName:  pi: 0 ts=SUBSCRIBER posMatches=8758 withTags= withValues= rdn.l=0IpAddrMode=0 ipAddrType=0 ipv4=192.168.100.14:0 region=Voicemail-REG capCount=4 ctiActive=F ctiFarEndDev=1 ctiCCMId=1 cgPtyDev=CiscoUM1-VI1 callInst=2 OLF=1Supp DTMF=3DTMF Cfg=1DTMF Payload=0isOffNetDev=F bc.l=3 bc.itr=1 bc.itc=0 bc.trm=0 bc.tm=4 maxForwards=70 cgpnMaskedByRedirect=F callingLRG=91745215-1f79-1224-9738-cedd559d82f4 featCallType=0 muteEnabled=0 associatedCallCI=0 featurePriority=1 nonTargetPolicy=0 unconsumedDigits= suppressMOH=T numPlanPkid =b875b09c-acaf-e58f-2f01-1604872a6e56 networkDomain= bitMask=0 SetupReason=0 routeClass=1 sideACmDeviceType=4 protected=1 ControlProcessType=0 tokens=0 isPresent=F transitCount=0 geolocInfo={geolocPkid=, filterPkid=, geolocVal=, devType=4} locPkid=acf6b34a-3dc5-48d5-c0d3-9be25c1288c3 locName=Voicemail-LOC deductBW=F fateShareId=StandAloneCluster:32504278 videoTrafficClass=0 oFromAnalogDvc=F bridgeParticipantID= callingUsr= remoteClusterID= isEMCCDevice=F HP=b875b09c-acaf-e58f-2f01-1604872a6e56 HPName=locale: 1 Name:  UnicodeName:  pi: 0 lHPMemCEPN= cHPMemCEPN=TransparentData=null CanSupportSIPTandN=false TransId=0 AllowBitMask=0x0 UserAgentOrServer= OrigDDName=locale: 1 Name:  UnicodeName:  pi: 0 mCallerId= mCallerName=LatentCaps=null icidVal= icidGenAddr= oioi= tioi= ptParams= receivedPAID= routeHdr= routeCepn= requestURI= PCVFlag=F originallyHadISUP=F isIMSFinalRoute=F IMSMode=0 originalLRG= lastRedirectingLRG= nwLoc=0
05326572.001 |13:33:08.640 |AppInfo  |LineCdpc(11440): -dispatchToAllDevices-, sigName=CcSetupReq, device=SEP5475D02B2F9E
05326573.000 |13:33:08.640 |SdlSig   |CcSetupReq                             |restart0                       |StationD(1,100,58,339)           |LineCdpc(1,100,168,11440)        |1,100,13,991.13354^192.168.100.14^CiscoUM1-VI1 |[R:N-H:0,N:0,L:0,V:0,Z:0,D:0] CI=32504279 CI.branch=0  sBPL.plid=65 sBPL.l=1 sBPL.pl=5 sBPL.msd=0  FDataType=0opId=0ssType=0 SsKey=0invokeId=0resultExp=Fbpda=F pi.piid=30 pi.l=0 pi2.piid=30 pi2.l=0 pi3.piid=30 pi3.l=0 FQCGPN=ti=1nd=8601pi=0si1 preXCgpn=tn=0npi=0ti=1nd=8601pi=0si0 cgPart= cgPat= cgpn=tn=0npi=0ti=1nd=+19132407451pi=1si3 cgpnVM= unXCgpn=tn=0npi=0ti=1nd=8601pi=1si0 cName=locale: 1 Name:  UnicodeName:  pi: 1 DD=tn=0npi=1ti=1nd=8758pi=0si1 origDD=tn=0npi=1ti=1nd=8758pi=0si1 preXCdpn=tn=0npi=0ti=1nd=8758pi=0si0 preXTagsList=SUBSCRIBER preXPosMatchList=8758 cdPart=e565da52-cd3c-56dd-651e-73e0a4e23b84 cdPat=8758 cdpn=tn=0npi=0ti=1nd=8758pi=1si1 cdpnVMbox= localPatternUsage=7 connectedPatternUsage=2 itrPart= itrPat= LRPart=e565da52-cd3c-56dd-651e-73e0a4e23b84 LRPat=8500 LR=tn=0npi=0ti=1nd=8500pi=0si1 LRVM= LRName=locale: 1 Name: VoiceMail UnicodeName: VoiceMail pi: 0 FQOCpdn=ti=1nd=8758pi=0si1 fFQLRNum=ti=1nd=8758pi=0si1 oPart=e565da52-cd3c-56dd-651e-73e0a4e23b84 oPat=8758 oCpdn=tn=0npi=0ti=1nd=8758pi=0si1 oCdpnVM= oRFR=0 oName=locale: 1 Name:  UnicodeName:  pi: 0 ts=SUBSCRIBER posMatches=8758 withTags= withValues= rdn.l=0IpAddrMode=0 ipAddrType=0 ipv4=192.168.100.14:0 region=Voicemail-REG capCount=4 ctiActive=F ctiFarEndDev=1 ctiCCMId=1 cgPtyDev=CiscoUM1-VI1 callInst=2 OLF=1Supp DTMF=3DTMF Cfg=1DTMF Payload=0isOffNetDev=F bc.l=3 bc.itr=1 bc.itc=0 bc.trm=0 bc.tm=4 maxForwards=70 cgpnMaskedByRedirect=F callingLRG=91745215-1f79-1224-9738-cedd559d82f4 featCallType=0 muteEnabled=0 associatedCallCI=0 featurePriority=1 nonTargetPolicy=0 unconsumedDigits= suppressMOH=T numPlanPkid =b875b09c-acaf-e58f-2f01-1604872a6e56 networkDomain= bitMask=0 SetupReason=0 routeClass=1 sideACmDeviceType=4 protected=1 ControlProcessType=0 tokens=0 isPresent=F transitCount=0 geolocInfo={geolocPkid=, filterPkid=, geolocVal=, devType=4} locPkid=acf6b34a-3dc5-48d5-c0d3-9be25c1288c3 locName=Voicemail-LOC deductBW=F fateShareId=StandAloneCluster:32504278 videoTrafficClass=0 oFromAnalogDvc=F bridgeParticipantID= callingUsr= remoteClusterID= isEMCCDevice=F HP=b875b09c-acaf-e58f-2f01-1604872a6e56 HPName=locale: 1 Name:  UnicodeName:  pi: 0 lHPMemCEPN= cHPMemCEPN=TransparentData=null CanSupportSIPTandN=false TransId=0 AllowBitMask=0x0 UserAgentOrServer= OrigDDName=locale: 1 Name:  UnicodeName:  pi: 0 mCallerId= mCallerName=LatentCaps=null icidVal= icidGenAddr= oioi= tioi= ptParams= receivedPAID= routeHdr= routeCepn= requestURI= PCVFlag=F originallyHadISUP=F isIMSFinalRoute=F IMSMode=0 originalLRG= lastRedirectingLRG= nwLoc=0
05326573.001 |13:33:08.640 |AppInfo  |StationD:    (0000339) DEBUG whatToDo: line=1 calls=1 limit=3, busy=2. GCI=(1, 20746), cm_PL=(5, 0).
05326573.002 |13:33:08.640 |AppInfo  |StationD:    (0000339) DEBUG  whatToDo: busy trigger not hit... send to open appearance
Need to add that it then delivers it to the next member in the line group after the RNA expires but what is causing the customer pain is the enduser sees a Missed Call after getting off the phone. When we set the "log off of Hunt No Answer" this user would be logged out and would have to hit the Hlog softkey to log back in.
Simple terms, longest idle timer should prevent the same user from receiving consecutive calls. Yet we are seeing users receiving calls when they are not idle.
This would be expected behavior in top-down, circular, broadcast, but not Longest Idle Timer. What am I missing?
Rob Huffman
Hi there,
I'm just curious if this behavior changed with the "Call Queuing" feature
that rolled out in CUCM 9.0. I see this line reference in the related guide;
Queuing-enabled hunt pilot calls can only be  received by line members one call at a time. Two queuing-enabled hunt  pilot calls cannot be offered to a line member (no matter what the busy  trigger is set to). This does not limit a line member to only receive  calls directly to their DN or from non-queuing hunt pilots.
http://www.cisco.com/en/US/docs/voice_ip_comm/cucm/admin/9_0_1/ccmfeat/CUCM_BK_CEF0C471_00_cucm-features-and-services-guide_chapter_0111.html
Just wondering if you changed the Hunt Pilot config to "Queuing" if it would make
any difference.
Cheers!
Rob
"Talk about a dream
Try to make it real"
- Springsteen
