06-05-2012 07:46 AM - last edited on 03-25-2019 08:16 PM by ciscomoderator
I need how many CUWL PRO are needed to have a valid UCCX IVR Port License: I am not able to find documents on how to calculate how many licenses I should buy to cover 25 IVR ports.
Any help will be appreciated
Thanks in advance
Gianstefano Monni
Solved! Go to Solution.
06-11-2012 04:14 AM
See this recent discussion where I quote from the SRND : https://supportforums.cisco.com/thread/2150882
It doesn't seem to get a mention in the ordering guide...
Aaron
06-05-2012 11:40 AM
Take a look at the ordering guide : http://www.cisco.com/web/partners/downloads/partner/WWChannels/technology/ipc/downloads/cuwl_ordering_guide.pdf
On page 3 it lists the number of Pro Users you need per agent (UCCX being ordered per agent, not per port).
Aaron
06-05-2012 12:00 PM
OK, now i've found that according to this thread, the number of IVR port is = 2*Agent
So here we are
25 CUWL PRO = 1 Agent = 2 IVR Port
so 25 IVR Port = 313 CUWL PRO.
06-05-2012 12:35 PM
Gianstefano MonniThat is for Contact Center Express Premium edition. For Standard Edition which is what you get with CUWL you get 1 agent per 25 UWL licenses. With Standard you get full 300 IVR ports entitlement.
Keep in mind that if you require either Enhanced or Premium licenses you need to order them separately.
HTH,
Chris
06-06-2012 12:02 AM
Chris,
in my scenario our customer:
- has 300 CUWL standard
- wants the uccx (to use it as auto-attendant for 20 IVR ports)
so, AFAIK, we have two choices:
1. upgrade 300 CUWL Std to CUWL PRO, so we have about 12 Agent, 24 IVR ports
2. buy the UCCX Standard edition with full 300 IVR Ports?
does it sound correct??
Thanks in advance
Gianstefano
06-06-2012 05:53 AM
Correct, however since you do not need any agents you can upgrade only let's say 25 CUWL and get 1 agent seat with 300 IVR ports as you can mix and match CUWL licneses.
HTH,
Chris
06-10-2012 01:03 AM
It's very difficult to me to understand the licensing model.. taking into account documentation and costs, the best choice seems to buy 10 seat + UCCX standard, for a total of 20 ivr ports.
Chris, could you detail your solution: if I buy 25 CUWL PRO I'll get 300 IVR ports???? That sounds good, but I do not find any documentation about it.
G
06-10-2012 07:21 AM
Gianstefano
The ordering guide posted by Aaron explains that. When you order 25 CUWL pro licenses you get 1 UCCX Standard license. UCCX Standard license entities you to full 300 IVR standard ports.
Both Standard and Enhanced UCCX give you unlimited IVR licenses and only UCCX Premium is 2 IVR licenses for each agent seat. This is because Premium licenses provide a lot more functionality.
HTH,
Chris
06-11-2012 03:57 AM
Chris,
many thanks for your support. I am not able to find any documentation stating that with 25 CUWL PRO I'll get 300 IVR Ports... I mean, AFAIK, 25 CUWL Pro = 1 seat = 2 IVR ports. If possible, could you please provide a link to a official document ?
Thanks a lot for your help
Gianstefano
06-11-2012 04:14 AM
Aaron
06-11-2012 06:28 AM
Hi Aaron
many thanks for the update: finally I got it :-)
- 25 CUWL Pro -> 1 UCCX seat -> 2 Advanced IVR ports
- 1 UCCX Standard -> as much "basic" IVR ports as the underlying system supports (max 300)
So in my situation, the least cost solution is to buy "a la carte" UCCX Standard with the minimum number of seats (10 seats).
Many thanks for your help
Gianstefano
06-11-2012 07:01 AM
This is not correct, as this statement is invalid:
25 CUWL give you one UCCX Standard --> 300 IVR ports
Chris
06-11-2012 07:46 AM
From the CUWL Ordering Guide (Pg. 21)
Cisco Unified Contact Center Express: You are entitled to one Cisco Unified Contact Center Express Standard Agent for every 25 UWL PRO users you purchase. You must select the Cisco Unified Contact Center Express version. You may also select a Structured Query Language (SQL) server option, which is not included in the price of UWL. If you wish to upgrade these licenses to Enhanced or Premium agents, you should follow the same process you would if upgrading a standard agent purchased a la carte or through UCL. No high-availability option is available for Standard Agents.
AFAIK, this implies that 25 UWL PRO entitles to use 1 CUCCX agent, and 1 agent "gives" you 2 Advanced IVR Ports...
06-11-2012 07:54 AM
You have to understand the difference between:
UCCX Standard
UCCX Enhanced
UCCX Premium
Standard and Enhanced gives you unlimited IVR ports (300)
Premium is the only one that provides 2 ports for each agent seat
CUWL only entitles you to Standard, so you get all 300 ports.
Chris
06-11-2012 08:05 AM
Oh I see... thank you so much Chris. Now I get the point (or at least I think so).
So, our customer can:
- buy 25 CUWL Pro upgrade from STD and get a maximum of 300 IVR Ports (and 2 Standard Agent?)
- buy a UCCX "a la carte" with 10 Seats (10 standard Agent) and get 300 IVR Ports
Gianstefano
