Debug ccsip messages
seventeen
Hello community ,
I'm debugging a gateway to verify if the international call pass or no , can you help with an output or anything else so I can verify ?
5 Replies 5
b.winter
Hi, what do you mean with your question?
If you have problems with a call, make a test call and post the output of the debugs here, so other people can help you analyze it.
I hope your question is how to debug
if it’s a isdn pri line use debug isdn q931
debug voice ccapi inout also give more information
if it’s a sip trunk use debug ccapi messages
Response Signature
You can also post your debug here along with the calling party information and the international number they are trying to dial. We can help take a look.
Maren
 dial-peer voice 56 voip
--More--   description * Appel InterNational PSTN via Trunk SIP *
translation-profile outgoing outgoing-PSTN
preference 1
destination-pattern ^9T$
session protocol sipv2
session target ipv4:xx.xx.xx.xx
voice-class codec 1
dtmf-relay rtp-nte
no vad
seventeen
Hello , The problem was resolved after debugging the gateway , we haven't observed anything special so we conclude that the problem is due to the operator who is blocking the international call.
Thanks guys !
