Error updating locale
jefflai2006
Hi all,
I need to change the phone language of 8845, from English to Simplified Chinese.
However, the ip phone 8845 fail to change to language to Chinese after I configure the "User Locale" in CCM Phone Profile.
Anyone had the same problem and any suggest ? Thanks a lot!
Some Details as below:
Locale version:10.5.2.2200-1
CCM version:10.5.2.13901-2
8845 version:11.5.1SR1-1
Manish Gogna
If you check the Read Me file for this locale, it does not include 8845 as one of the supported phone models
http://www.cisco.com/web/software/282074333/131507/cm-locale-10.5.2.2200_ReadMe.pdf
Manish
- Do rate helpful posts -
Manish Gogna
Manish
Thanks for your help. It's my careless mistake.
The document is useful.
Not a problem, its always recommended to check the Read Me files before installing any new firmware, locale, device pack or any special cop files.
Manish
