Extension mobility Phone 8832
jlcembellin
I have Extension mobility as enterprise service in callmanager 12.5. Extension mobility on 8845 and 7841 phones appears but on 8832 the EM service does not appear. How to access EM service on 8832 phones?
Thanks in advance.
Change the softkey to Public conference. It gives you option APPLICATION.
Then use APP softkey to access Extension Mobility. (I assume you have done all required configurations for EM)
Response Signature
8 Replies 8
I have no access to 8832 now, I can check this morning.
But Have you tried, the below.
Press Settings.
Step 2
Select Running applications.
Step 3
Select a running application and press Switch to to open and use the selectedapplication.
Step 4
Press Exit.
Response Signature
Is the "Extension Mobility" checkbox checked on the phone configuration page? If you have set up the service as an Enterprise Service, it should show up in the list of services on all phones, whether the "Extension Mobility" checkbox is checked on the phone or not. But stranger things have happened.
Maren
AFAIK none of the conference phones support the extension mobility service. That might be the reason for why it does not show up on it.
Response Signature
Hello Roger. As you can see in the feature report, extension mobility is supported on this phone.
Seems so. However it’s my experience with this that I never got it to work on conference phones. Hopefully someone else might have other experience.
Response Signature
Steven L
there should be an "Apps" softkey. EM is under that.
Response Signature
Thanks Nithin. It works.
