Incoming call to MGCP gateway failing with invalid IE contents
Deepak Mehta
Team,
I can make outbound calls fine however issue is with incoming.Call is initiated from PSTN phone - SB Phone
Below output is from SB MGCP gateway where call is coming in.
I have tried various options on MGCP gateway config in CUCM eg Display IE or redirecting IE support etc .Also on voice interface supplementary services command (isdn supp-service name calling ) is configured.
pr 13 17:58:06.555: ISDN Se0/1/0:15 Q931: RX <- SETUP pd = 8  callref = 0x0080
        Bearer Capability i = 0x8090A2
                Standard = CCITT
                Transfer Capability = Speech
                Transfer Mode = Circuit
                Transfer Rate = 64 kbit/s
        Channel ID i = 0xA98381
                Exclusive, Channel 1
        Facility i = 0x9F8B0100A11802010302010080105369746543204C6F63616C205053544E
                Protocol Profile =  Networking Extensions
                0xA11802010302010080105369746543204C6F63616C205053544E
                Component = Invoke component
                        Invoke Id = 3
                        Operation = CallingName
                                Name Presentation Allowed Extended
                                Name = SiteC Local PSTN
        Display i = 'SiteC Local PSTN'
        Calling Party Number
R3# i = 0x4181, '70054000'
                Plan:ISDN, Type:Subscriber(local)
        Called Party Number i = 0xA1, '70044001'
                Plan:ISDN, Type:National
Apr 13 17:58:06.559: ISDN Se0/1/0:15 Q931: TX -> RELEASE_COMP pd = 8  callref = 0x8080
        Cause i = 0x80E4 - Invalid information element contents>>>>>>>>>>>
Ok. It is greyed out because it is not supported on this setup. Please change the PCM type from a-law to u-law. Ensure you reset the mgcp process by doing
conf t
no mgcp
mgcp
Please rate all useful posts
7 Replies 7
Deepak Mehta
Any expert opinion here ...
As i have not been able to overcome this problem from last few days now.thank you
Try and remove the facility ie in cucm for the gateway. Go to the mgcp gateway in CUCM and uncheck the facility ie box. Then do a no mgcp, followed by mgcp to restart the mgcp process
Thank you, Ayodeji.
Facility IE option is grayed out, I am not too sure why.
Coulf it be becuase I am using E1 and PRI protocol is Euro?
I did try other enabling other options but I still see facility IE in incoming call.
could you please send the show run along with below debugs for one test
debug isdn q931
debug mgcp packets
debug mgcp events
debug mgcp error
Br,
Nadeem
Br, Nadeem Please rate all useful post.
Below GW config screenshot.You can see Facility IE is grayed out.
conf t
no mgcp
mgcp
Thank you so much !! it worked.
Appreciate your help .
