ip phone background
mhabaseh1
I have cisco ip phone ( 8800 , 7900 , DX650 ), please help me about steps to change ip phone background.
How I can download the List.xml files and modify ??
8 Replies 8
You can do that in two ways.
  • Using List.Xml.
  • Using Common Phone Profile.
<CiscoIPPhoneImageList>
   <ImageItem Image=”TFTP:Desktops/320x212x12/TN-Fountain.png” URL=”TFTP:Desktops/320x212x12/Fountain.png”/>
   <ImageItem Image=”TFTP:Desktops/320x212x12/TN-FullMoon.png” URL=”TFTP:Desktops/320x212x12/FullMoon.png”/>
</CiscoIPPhoneImageList
https://www.cisco.com/c/en/us/td/docs/voice_ip_comm/cucm/admin/14/cucm_b_feature-configuration-guide-for-cisco14/cucm_mp_cb22707b_00_custom-phone-rings-12-0.html?bookSearch=true#task_6EF6FA87F95A898B4202D617BA3DD0E6
https://www.cisco.com/c/en/us/td/docs/voice_ip_comm/cuipph/8800-series/english/adminguide/P881_BK_C136782F_00_cisco-ip-phone-8800_series/P881_BK_C136782F_00_cisco-ip-phone-8811-8841_chapter_01010.html
Response Signature
how I can get or download List.Xml from cucm ?
Edit the below xml on  a notepad and save it  as List.xml . upload the file to CUCM TFTP.
 Read the Guides which we shared  . It contains detailed  information on   how to change the background.
Response Signature
You can do that from the webUI or from the CLI. There are a number of post on this topic if you search for it.
Response Signature
Use file list tftp List.xml  to see if the file exist on TFTP.
You can copy the file from CLi using file get tftp List.xml, Since i don't have List.XMl on my lab CUCM , i made a screenshot by downloading  Ringlist.xml. Hope that helps You.
Use URL to open from a browser http://{ call manager IP}:6970/List.xml
Response Signature
Jaime Valencia
Refer to the phone administration guide for each phone model you want to do this for, and there is a customization chapter that covers all this, the process is overall the same, but the specs of the image to use might change between endpoints, and they're listed in the admin guide per model. All the admin guides are available online.
This has been asked many, many times, you can also refer to previous questions at CSC.
java
if this helps, please rate
mhabaseh1
I’m checking setting in IP phone 8845, I can’t find background feature in the device
from where I can activate and appear background
