ISR 4331 has no voice commands after swapping hardware
Scuromano
A 4331 gateway was sent by Cisco to replace one that had a timing issue.  The FXO card was swapped over to the new one but there are no voice commands in the IOS to configure it even through the router recognizes the card. I put the "old" IOS on the new router and moved over the PVDM4 card but still no voice commands.  What else?  License? I have attached the show license output from the new and old router.
Current version isr4300-universalk9.03.16.02.S.155-3.S2-ext.SPA.bin
HOw can I get the voice commands back?
Dennis Mink
sound like licenses mate. if your ISR was swapped out as part of an RMA, hook up with Cisco
Please remember to rate useful posts, by clicking on the stars below.
8 Replies 8
Jaca
What voice commands are you trying to use that are failing?
Try:
conf t
voice service voip
The router has a CME-SRST license.
Try:
conf t
telephony-service
max-ephone 10
exit
Post the results.
Dennis Mink
It was a license issue.  Moved over the PVDM4 card and the old IOS (which was newer than the one on the replacement router) to the "new" router and still no voice commands.  Then, we contacted Cisco for a new license.  They emailed it.  We put it on the router and now there are voice commands.
R0g22
Add an output for "show license all" from the ISR-4k please.
can u share the show inventory and show diag from 4331 router?
regds,
aman
Here is the show license output, for future reference:
Old Router:
Gateway#sh license
Index 1 Feature: appxk9
        Period left: Not Activated
        Period Used: 0  minute  0  second
        License Type: EvalRightToUse
        License State: Active, Not in Use, EULA not accepted
        License Count: Non-Counted
        License Priority: None
Index 2 Feature: uck9
        Period left: Life time
        License Type: Permanent
        License State: Active, In Use
        License Priority: Medium
Index 3 Feature: securityk9
Index 4 Feature: ipbasek9
Index 5 Feature: FoundationSuiteK9
Index 6 Feature: AdvUCSuiteK9
Index 7 Feature: cme-srst
        License Type: RightToUse
        License Count: 160/0  (In-use/Violation)
        License Priority: Low
Index 8 Feature: hseck9
Index 9 Feature: throughput
Index 10 Feature: internal_service
New router:
Gateway#sh license
        License Count: 0/0  (In-use/Violation)
uck9 license is not in use.
Since this was a replacement done by Cisco, you can open up a case with GLO and rehost your licenses from the old chassis and install it on the new one.
For the time being, you can run a "license accept end user agreement" command in global config mode, wr and reload the router to activate the license in a evaluation period. This would be valid for 8 weeks and 4 days.
Mahmoud Belhaj
License issue
